DSG flush required?
#51
If a filter change isn't required in our cars, everything they did in the video under the car with the overfill/temperature-measure/drain-excess is basically the same as what will be required on our cars.
The video at least gives you a good idea of what's involved regarding the fluid change.
CFM
CFM
#52
I was under the impression as well that you have to go into the system to depressurize the system before opening it up to drain the fluid. I don't think all DSG models have the same service steps, which is important to note. Another reason I got AudiCare....
#53
I see people saying $500 is not a lot of money, I've seen the price range from the upwards of $700! It's insane. You can buy all the tools and materials you need to do it for less than $300, and then be able to use all those tools for other jobs that the dealer would charge an arm and a leg for!
If I can do it you can too.. A friend and I did it and filmed doing a fluid service in 3 hours. You just gotta take a deep breath and look at what you're really paying for.
Here's my 8 minute DIY video:
https://www.youtube.com/watch?v=3UtSTZqW6Wc
I have listed the tools I used and recommended alternatives. The OBDEleven scan tool is not something I have yet, but looks like it would do the trick for $80. (And you can definitely forego the pump tool kit for $80)
#54
There are two oil circuits in the tranny, the DSG side for the mechatronics and hydraulics controls, and the mechanical side that bathes in MTF. The mechanical side has a pressure accumulator that would need to be depressurized in order to replace the MTF. I'm not sure what the service schedule is for the mechanical side.
#55
Breadbooze, you seems know this DSG well. So which one (DSG side or mechanical side) are we talking about to be changed at 40,000 miles according to Audi's schedule? Thanks!
#56
The DSG side is 40k, the mechanical side isn't published but I assume it to be 100k. In the process of figuring out how to do the DSG fluid change I changed out the MTF as well. I understand now why there is no filter on the DSG side- it's all hydraulics and there really isn't any exposure to gears or parts that wear down over time.
#57
I assume you used same fluid for both compartments. Did you use factory reader to de-pressurize the MTF or you have a trick to do it yourself? A bit detail or better yet a step by step tutorial would be great. I have been doing auto maintenance even including timing belts for all my cars for years. This is my first European car though so a bit uncertain. Thanks in advance!
#58
Thank you for the info, breadbooze!
#59
The process for the MTF change involved sucking it out from the side fill port (I got about 3.5L out) and refilling until it leaks out. I couldn't figure out how to depressurize the the accumulator using obd11 so I rowed through the gears with a "dry" gearbox and monitored the oil pressure until it dropped. It's probably not the ideal way of doing it, I'm sure there's a way to turn off the oil pressure pump and equalize pressure that way. You'll get a few faults in the transmission module doing it that way, they'll go away after the fluid is replaced and faults cleared.
#60
While DSG fluid can be used for both, Audi put in a GL-4 75W gear oil (that's what the service tech thinks it is), or part number G052549A2 if you want what the factory used. I put up a set by step for the DSG side in the allroad forum here- https://www.audiworld.com/forums/a4-...hange-2945427/
Does anyone know if this is the case? Additionally is this DSG the OB5/DL501 model?
