When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Cleaned the car yesterday and at the end I randomly decided to open the hood. I haven't done so in a really long time.
What I found...
The engine bay area, as you look at the car with the hood open on to right side towards the driver.<br/><br/>Very miniscule sand particles.
This is on the other side too. I took a pic but only after I kinda cleaned it.
The only way I can think of how that sand got there is from when I drove from Toronto to Lake Placid, and on the way, through the mountains, we took more scenic (ie, windy and hilly) routes that were a blast to drive in, but the roads were covered in sand not salt to combat the snow.
Should this even be here though? The only way it could have gotten here is the front wheels kicking it up into the engine bay. I thought it was supposed to be sealed off more properly though.
How do I clean it? Can I take a hose out and water the engine bay down, or for once or twice a year, better to take it into a shop for them to do the engine bay cleaning? And will they protect the components of the engine bay that should be protected when doing a full wash?
Engine bay becoming dirty is normal. Though it is significantly less here compared to when I was in India.
And while it is safe to hose down the engine bay, I wouldn't advise it. I'd use a damp microfiber to clean up the dirt and engine cover and the like. Maybe even use a little shampoo to clean up stubborn stains? Wipe it dry afterwards and you should be fine. You even get trim dressers to clean the plastic engine cover and stuff.
That's right above the wheel wells with few cracks (the plastic cover) to let dirt in. Mines are all white from northeastern winter salt/dust. I brushed it a bit then blow them off. The main engine area under the hood is generally fine though.
That's right above the wheel wells with few crack open (the plastic cover) to let dirt come in. Mines are all white from northeaster winter salt/dust. I brushed it a bit then blow them off. The main engine area under the hood is generally fine though.
Exactly - Ok cool - feel much better not - thanks!
Yup. After blowing it off, if there are any residues, you can wipe it with a damp microfiber. I use a mixture of water and shampoo to wipe it off and then dry it using a dry microfiber.
Thanks again - yup just did that, and yeah the rest of the engine bay was really clean. A very very thin layer of dust, but pretty impressed over all given that I've actually taken it on 2 longer road trips and in both cases we've either had really bad weather or very salty dry roads.
Follow up question - took another picture. I'm really not sure what this part of the car is, but, it looks like it needs to have a cover on it, does it not?
