Guide: Enable Google Earth/Traffic on Canada spec Audi
Old 01-30-2017, 12:52 PM
  #31
s_Fanous's Avatar
Originally Posted by Johannes Schauss
There is a long codding readout available for a fully loaded a4 German car in the obd11 wiki.
Can you please provide the URL to this readout?
Old 01-31-2017, 03:00 AM
  #32
Johannes Schauss's Avatar
http://audiwiki.bitt-c.at/index.php/...,_Drive_Select
If we could have somebody follow s_Fanous instruction and perform a backup on a US specd b9 car. That would help us determine what Canadian cars are missing to activate the sim card feature. I suspect at this point Canadian specd cars are either actually missing a physical part or there are corresponding code changes in other modules required, beside the 5F module.
Old 02-01-2017, 08:06 AM
  #33
s_Fanous's Avatar
Originally Posted by ekyp
To enable Google Earth (this will require using your mobile phone's data connection as hotspot):
Step 1: Set the following adaptation in module 5F (this can be done by VagCOM HEX-CAN-USB or OBDEleven) :
IDE03471-ENG117836-Vehicle configuration-VZAPro - ON
So, I finally got around to activating Google Earth on my vehicle and was just wondering if anyone knew what VZAPro does exactly? It's mostly the only adaptation that is not clear from the name and seems to be Off in US cars.
Old 02-01-2017, 05:23 PM
  #34
ekyp's Avatar
I believe VZA means 'Traffic Sign Display / Verkehrszeichen-Anzeige'
I think I tried to turn this off and it doesn't make a difference.
Old 02-02-2017, 02:07 PM
  #35
s_Fanous's Avatar
So I managed to perform a complete delta between a stock A4 prestige with Audi Connect and my car (A4 technik without Audi Connect)
Code:
bluetooth: sniff mode = on	off
brand-specific display of connect application = de.audi.mmiconnect	Null
car_function_adaptations_gen2-menu_display_ecall = activated	not activated
car_function_adaptations_gen2-menu_display_ecall_over_threshold_high = activated	not activated
car_function_adaptations_gen2-menu_display_eni = activated	not activated
car_function_adaptations_gen2-menu_display_eni_over_threshold_high = activated	not activated
car_function_list_bap_gen2-ecall_0x33 = activated	not activated
car_function_list_bap_gen2-ecall_0x33_msg_bus = databus infotainment	not activated
car_function_list_bap_gen2-eni_0x37 = activated	not activated
car_function_list_bap_gen2-eni_0x37_msg_bus = databus infotainment	not activated
confirmation of installation change = 30 73	0f a6
country identification; country of sale = us	ca
dimming_illumination_for_display_unit-y4 = 16%	17%
fee-based traffic information (tmc) = 65533	65535
number attempted dialing attempts for roadside assistance = 3	Null
tuner for satellite radio; preparation = 5	Null
vehicle configuration-advanced_range_display = on	off
vehicle configuration-gracenote_online_coverarts = on	off
vehicle configuration-gracenote_online_other = on	off
vehicle configuration-mirror_link = function_off_hmi_off	off
vehicle configuration-my_audi = on	off
vehicle configuration-online_media = on	off
vehicle configuration-online_navigation = on	off
vehicle configuration-online_poi = on	off
vehicle configuration-online_poi_voice = on	off
vehicle configuration-online_portal_browser_services = on	off
vehicle configuration-online_street_view = on	off
vehicle configuration-remote_hmi = on	off
vehicle configuration-sds_region_flag = no_region	region_nar
vehicle configuration-smartphone_interface_for_rhmi = activated	deactivated
vehicle configuration-uota = on	off
vehicle configuration-wifi_hotspot = on	off
The above output can be read as follows
Adaptation Name = Prestige_Value Technik_Value
So for example this line
means the value was "on" in the Prestige and "off" in the Technik. Anyways I tried playing around to get the Internal SIM Card to work to no avail. The closest I got was when I enabled Audi Connect in the MMI (vehicle configuration-remote_hmi = on). When you open Audi Connect it'll complain that there is no Data Connection and prompt you to configure it. If you follow the prompts that will open up a dialog to enter the APN/Username/Password. The problem is the Apply button in this does nothing
Anyways my next thought was to look into the Long Coding, and I was able to compare the long coding in both vehicles which is as follows
Code:
5F Information Control Unit 1
Byte 08 -> 13 / 53 - 0001 0011 / 0101 0011
Byte 15 -> 00 / 10 - 0000 0000 / 0001 0000
Byte 19 -> E4 / E5 - 1110 0100 / 1110 0101
The Prestige has 3 more bits set (The red bits above) as opposed to the Technik. I have not attempted to change any of them so far.
What I also did was compare the Canadian Q7 with Audi Connect 5F coding in this thread to the A4 Prestige and this is the output
Code:
Byte 01 -> 37 / 94 - 0011 0111 / 1001 0100
Byte 02 -> 06 / 01 - 0000 0110 / 0000 0001
Byte 18 -> 1B / 02 - 0001 1011 / 0000 0010
What I noticed is that the Q7 and Prestige have the same Byte 08 values as opposed to the Technik. Also, the Q7 has the same values for Bytes 15 and 19 as the Technik which is different in the Prestige. In a nutshell Byte 08 might be the necessary change. If I'm courageous enough and find some time I might go ahead and try to change Byte 08 in my Technik to match the Q7/Prestige and see what happens
Old 02-03-2017, 05:19 AM
  #36
mlavio829's Avatar
That's a great find!
Have you found the courage to try it yet?
I'm unfamiliar with Long Coding and have only done adaptations so far.
Is there away to find out what Byte 08 does before trying it?
If it doesn't work, it would be interesting if somehow it's possible to reroute the data connection of the E-Sim that it is looking for, and route it to the tethered phone.
Old 02-03-2017, 06:03 AM
  #37
s_Fanous's Avatar
This is what OBD11 shows about byte 8.
I think the bit in question is the one which I have drawn a red rectangle around but I can't be 100% sure unless some kind US owner takes a screenshot and we can compare. Having said that, even if it is the bit in question, I have no idea what VDA-NF_IN means and from the looks of the other bits within byte 8 I'm not too encouraged seeing as they seem to mostly be controlling audio related features.
I'm starting to have doubts about the ability to activate the external SIM card if the vehicle was not initially equipped with Audi Connect and the accompanying embedded SIM card. It would help if a US owner without Audi Connect would confirm that they have managed to enable the SIM card slot.
Old 02-04-2017, 02:07 PM
  #38
chimcu's Avatar
OBDeleven vehicle history log
Date: 2017-02-04 17:52
VIN: XXXXXXXXXXXXXXXXX
Car: Audi Q7
Year: 2017
Engine: CREC
Mileage: 1831 KM
Backup
Control unit: 28 Climate Control Unit Rear
System description: Klima Zone 2
Software number: 4M0919158D
Software version: 0092
Hardware number: 4M0919158D
Hardware version: H52
ODX name: EV_AirCondiFondBHTCAU736
ODX version: 001013
Backup name: 28-climate control unit rear
Long coding:
00000000000000010080008000000000000000000000000000 0000000000
Adaptations:
OBD_activation:
Not activated
EntwID_activation:
Display:
Not activated
Flaps:
Not activated
Potentiometer:
Not activated
Climate:
Not activated
CapSense:
Not activated
Massflow:
Not activated
Clima-OBD:
Not activated
System:
Not activated
LIN1:
Not activated
LIN2:
Not activated
OBD_channel:
Speed of motors:
Production mode:
not active
Deactivate production mode:
Deactivating
Roller test bench mode, functional:
Not activated
Tolerance range for flap end stops:
Mileage: 1831 km
Date: 2017-02-04 17:49
Backup
Control unit: 3C Lane Change Assistant
System description: MRR1Rear
Software number: 4M0907566B
Software version: 0230
Hardware number: 4M0907566
Hardware version: H13
ODX name: EV_RearRadarS1BoschAU736
ODX version: 001015
Backup name: 3c-lane change assistant
Long coding:
1EE002
Adaptations:
Production mode:
Activate
Deactivating
Activating and deactivating all development messages:
Group 1:
Not activated
Brightness characteristic of warning display:
normal
Mileage: 1831 km
Date: 2017-02-04 17:48
Backup
Control unit: 44 Steering Assistance
System description: EPS_MLBEVO1BS
Software number: 4M0909144H
Software version: 0005
Hardware number: 4M0909144B
Hardware version: H20
Serial number: 0000359884
ODX name: EV_EPSVWBSAU736
ODX version: 009023
Backup name: 44-steering assistance
Long coding:
90000101000100
Mileage: 1831 km
Date: 2017-02-04 17:47
Backup
Control unit: 50 Seat Adjustment 3rd Row
System description: MEM-SR3
Software number: 4M0959760G
Software version: 0015
Hardware number: 4M0959760G
Hardware version: 008
Serial number: 00000178678508
ODX name: EV_SCM3rdRowCONTIAU736
ODX version: 005007
Backup name: 50-seat adjustment 3rd row
Long coding:
FF041020F1000000000F000000000900000021210900000000 000000440000
Adaptations:
Group 1:
not active
Group 2:
not active
Group 3:
not active
Group 4:
not active
Group 5:
not active
Group 6:
not active
Group 7:
not active
Group 8:
not active
active
Production mode:
Deactivate massage function:
not active
Resetting standardization:
All
backrest_range_for_automatic_adjustment_3rd_row:
32
vehicle_velocity_monitoring:
active
Mileage: 1831 km
Backup
Control unit: 52 Door Electronics Passenger Side
System description: TSG BFS
Software number: 4M0959792E
Software version: 0055
Hardware number: 4M0959792C
Hardware version: 009
Serial number: 0000214949632
ODX name: EV_DCU2PasseSideMAXHCONT
ODX version: 001005
Backup name: 52-door electric passenger
Long coding:
005D9B005E001080000120B0
Adaptations:
Production mode:
Reduce reverse threshold:
Deactivating
Activate test mode for the fold-in mirror:
Deactivating
Deactivate speed control for power windows:
Deactivating
Reduce switch-on time of lighting:
Deactivating
Power windows operable with terminal 15 off:
Deactivating
Activate test mode for power windows:
Deactivating
Deactivate closing aid:
Deactivating
Deactivating
Reversing_Threshold_Passenger_Side_Front:
90 %
Mileage: 1831 km
Date: 2017-02-04 17:46
Backup
Control unit: 5F Information Control Unit
System description: MU-P-LNS-US
Software number: 4M1035880
Software version: 0918
Hardware number: 4M1035880
Hardware version: 033
Serial number: A724J0GB000519
ODX name: EV_MUHig6C3Gen2HBAS
ODX version: 001115
Backup name: 5f-info control
Long coding:
013706020000000053220002041A00002F001BE401700104BE
Adaptations:
Regional codes:
Parameter_Set_DVD_Region_Code:
Parameter_Set_BlueRay_System_Region_Code:
Automatic ring break diagnostic:
No automatic start
Vehicle dimensions:
Length:
0 mm
Width:
0 mm
Height:
0 mm
Summertime-automatic:
automatic
Production mode:
000000
Number 2 for Info call:
0000000000000000000000000000000000000000000000
Number 2 for roadside assistance:
Number 1 for Info call:
Number 1 for roadside assistance:
Sporadic ring break detection:
Visual
Awakening ability on optical databus:
Off
Country code for mobile network:
Number 1 (roaming) for roadside assistance:
Telephone data services:
On
Roadside assistance mode:
Corresponding setting in MMI
Number attempted dialing attempts for roadside assistance:
Establishing a connection:
Electrical test of loudspeakers:
Mode:
automatic
Parameter_AC-Diagnostics_Channel_1_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_1_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_2_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_2_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_3_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_3_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_4_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_4_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_5_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_5_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_6_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_6_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_7_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_7_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_8_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_8_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_9_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_9_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_10_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_10_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_11_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_11_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_12_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_12_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_13_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_13_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_14_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_14_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_15_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_15_Test_Volume:
22
Parameter_AC-Diagnostics_Channel_16_Test_Frequency:
19000 Hz
Parameter_AC-Diagnostics_Channel_16_Test_Volume:
22
Fee-based traffic information (TMC):
65535
Infotainment recorder:
activated
Wheel pulse:
Wheel circ.:
0 mm
Check tone frequency:
High note frequency range:
4000 Hz
Medium note frequency range:
1000 Hz
Low note frequency range:
100 Hz
Confirmation of installation change:
Key:
7cf1
Copy multimedia data:
Data medium:
On
Optical drive:
Off
Telephone:
Data & language service active
Bluetooth:
On
Bluetooth: Sniff mode:
Off
Audio management mute function:
Muting of audio sources
Audio_Managment_Soundset_Menu:
Off
WLAN:
On
Dimming_Ambient_Illumination_Information_Control_U nit:
X1:
Y1:
X2:
50
Y2:
50
X3:
100
Y3:
100
BAP_Debug_Mode_Release:
Release:
not_released
CD eject button:
CD eject button:
Enabled
Developer mode:
Not activated
Selection of release codes for a SWaP function:
ffffffff
p_HMI_Display:
p_HMI_Display:
10 %
p_damping_Display:
p_damping_Display:
5 ms
Dimming_Ambient_Illumination_Operating_and_Display _Unit:
X1:
Y1:
50
X2:
100
Y2:
X3:
50
Y3:
100
Dimming_Illumination_for_Display_Unit:
X1:
Y1:
1 %
X2:
20
Y2:
2 %
X3:
50
Y3:
5 %
X4:
100
Y4:
12 %
X5:
150
Y5:
33 %
X6:
253
Y6:
100 %
Country identification, country of sale:
CA
Infotainment_CAN_Messages:
Off
MIB_CAN_Messages:
Off
Dimming_Functional_Illumination_for_Operating_Unit :
X1:
Y1:
10 %
X2:
50
Y2:
100 %
X3:
220
Y3:
253 %
X4:
Y4:
2 %
X5:
Y5:
10 %
X6:
80
Y6:
100 %
Parameter for connection transfer (UMTS):
1E_EcLo:
1E_RSCP:
15
1F_EcLo:
1F_RSCP:
15
3A_EcLo:
3A_RSCP:
2D_EcLo:
2D_RSCP:
11
Vehicle configuration:
VZAPro:
Off
online_POI:
Off
online_POI_voice:
Off
online_portal_browser_services:
Off
online_navigation:
Off
online_street_view:
Off
WIFI_Hotspot:
Off
my_audi:
Off
picture_navi:
Off
online_dictation:
Off
remote_HMI:
Off
advanced_range_display:
Off
gracenote_online_coverarts:
Off
gracenote_online_other:
Off
gracenote_local_coverarts:
On
gracenote_local_other:
On
UPnP:
On
OPS_display_in_dash_board_display_unit:
Off
Joker_button_1:
Not present
Joker_button_2:
Not present
LTE_modul:
activated
Support_second_phone:
On
Support_of_threeway_calling:
On
Dtmf_without_active_call:
On
Support_for_response_and_hold:
Off
Sim_card_mode_switch:
Present
Phone_module_operation_mode:
only data service act.
PSD_Protocol_Version:
PSD_1.5
RVC_video_input:
LVDS
Station_Logo_DB_Mode:
TPEG_availability:
Off
VZO:
Off
LGI:
Off
ProbeCar_vzo:
Off
online_media:
Off
ProbeCar_lgi:
Off
Google_GAL:
On
Apple_DIO:
On
SDS_Region_Flag:
REGION_NAR
UOTA:
Off
WiFi_Client_HMI:
Off
RSE_software_component:
Deactivated
Mirror_link:
Smartphone_interface_for_rhmi:
Deactivated
sd_slot_deactivation:
no restriction
map_sms_support:
On
map_email_support:
On
map_instant_messaging_support:
On
sim_data_only_sms_support:
Off
esim_data_only_sms_support:
Off
allow_message_editing:
On
vehicle_readiness_sound:
Not activated
MirrorLink_Country_Code:
MIB_EU
vehicle_leaving_sound (2):
Not activated
MirrorLink_RGB_Preference:
RGB565
conditioning_variant:
Car_Function_Adaptations_Gen2:
menu_display_ACC:
Not activated
menu_display_ACC_operation_clamp_15_off:
Not activated
menu_display_ACC_over_threshold_high:
Not activated
menu_display_ACC_standstill:
Not activated
menu_display_ACC_after_disclaimer:
Not activated
menu_display_ambient_illumination:
activated
menu_display_ambient_illumination_clamp_15_off:
Not activated
menu_display_ambient_illumination_over_threshold_h igh:
activated
menu_display_ambient_illumination_standstill:
Not activated
menu_display_ambient_illumination_after_disclaimer :
Not activated
menu_display_pdc:
activated
menu_display_pdc_clamp_15_off:
Not activated
menu_display_pdc_over_threshold_high:
Not activated
menu_display_pdc_standstill:
Not activated
menu_display_pdc_after_disclaimer:
Not activated
menu_display_awv:
Not activated
menu_display_awv_clamp_15_off:
Not activated
menu_display_awv_over_threshold_high:
Not activated
menu_display_awv_standstill:
Not activated
menu_display_awv_after_disclaimer:
Not activated
menu_display_Lane_Departure_Warning:
activated
menu_display_Lane_Departure_Warning_clamp_15_off:
Not activated
menu_display_Lane_Departure_Warning_over_threshold _high:
activated
menu_display_Lane_Departure_Warning_standstill:
Not activated
menu_display_Lane_Departure_Warning_after_disclaim er:
Not activated
menu_display_lane_assistant:
activated
menu_display_lane_assistant_clamp_15_off:
Not activated
menu_display_lane_assistant_over_threshold_high:
activated
menu_display_lane_assistant_standstill:
Not activated
menu_display_lane_assistant_after_disclaimer:
Not activated
menu_display_exterior_illumination:
activated
menu_display_exterior_illumination_clamp_15_off:
Not activated
menu_display_exterior_illumination_over_threshold_ high:
activated
menu_display_exterior_illumination_standstill:
Not activated
menu_display_exterior_illumination_after_disclaime r:
Not activated
menu_display_windows:
Not activated
menu_display_windows_clamp_15_off:
Not activated
menu_display_windows_over_threshold_high:
Not activated
menu_display_windows_standstill:
Not activated
menu_display_windows_after_disclaimer:
Not activated
menu_display_clima_configuration:
activated
menu_display_clima_configuration_clamp_15_off:
Not activated
menu_display_clima_configuration_over_threshold_hi gh:
activated
menu_display_clima_configuration_standstill:
Not activated
menu_display_clima_configuration_after_disclaimer:
Not activated
menu_display_auxiliary_heating:
Not activated
menu_display_auxiliary_heating_clamp_15_off:
Not activated
menu_display_auxiliary_heating_over_threshold_high :
Not activated
menu_display_auxiliary_heating_standstill:
Not activated
menu_display_auxiliary_heating_after_disclaimer:
Not activated
menu_display_board_computer:
activated
menu_display_board_computer_clamp_15_off:
Not activated
menu_display_board_computer_over_threshold_high:
activated
menu_display_board_computer_standstill:
Not activated
menu_display_board_computer_after_disclaimer:
Not activated
menu_display_rdk:
activated
menu_display_rdk_clamp_15_off:
Not activated
menu_display_rdk_over_threshold_high:
Not activated
menu_display_rdk_standstill:
activated
menu_display_rdk_after_disclaimer:
Not activated
menu_display_wiper:
activated
menu_display_wiper_clamp_15_off:
Not activated
menu_display_wiper_over_threshold_high:
activated
menu_display_wiper_standstill:
Not activated
menu_display_wiper_after_disclaimer:
Not activated
menu_display_sia:
activated
menu_display_sia_clamp_15_off:
Not activated
menu_display_sia_over_threshold_high:
activated
menu_display_sia_standstill:
Not activated
menu_display_sia_after_disclaimer:
Not activated
menu_display_seat_configuration:
activated
menu_display_seat_configuration_clamp_15_off:
Not activated
menu_display_seat_configuration_over_threshold_hig h:
activated
menu_display_seat_configuration_standstill:
Not activated
menu_display_seat_configuration_after_disclaimer:
Not activated
menu_display_central_locking:
activated
menu_display_central_locking_clamp_15_off:
Not activated
menu_display_central_locking_over_threshold_high:
activated
menu_display_central_locking_standstill:
Not activated
menu_display_central_locking_after_disclaimer:
Not activated
menu_display_compass:
Not activated
menu_display_compass_clamp_15_off:
Not activated
menu_display_compass_over_threshold_high:
Not activated
menu_display_compass_standstill:
Not activated
menu_display_compass_after_disclaimer:
Not activated
menu_display_charisma:
activated
menu_display_charisma_clamp_15_off:
Not activated
menu_display_charisma_over_threshold_high:
activated
menu_display_charisma_standstill:
Not activated
menu_display_charisma_after_disclaimer:
Not activated
menu_display_oil_level:
activated
menu_display_oil_level_clamp_15_off:
Not activated
menu_display_oil_level_over_threshold_high:
activated
menu_display_oil_level_standstill:
Not activated
menu_display_oil_level_after_disclaimer:
Not activated
menu_display_vin:
activated
menu_display_vin_clamp_15_off:
Not activated
menu_display_vin_over_threshold_high:
activated
menu_display_vin_standstill:
Not activated
menu_display_vin_after_disclaimer:
Not activated
menu_display_clock:
activated
menu_display_clock_clamp_15_off:
Not activated
menu_display_clock_over_threshold_high:
activated
menu_display_clock_standstill:
Not activated
menu_display_clock_after_disclaimer:
Not activated
menu_display_air_damper:
activated
menu_display_air_damper_clamp_15_off:
Not activated
menu_display_air_damper_over_threshold_high:
activated
menu_display_air_damper_standstill:
Not activated
menu_display_air_damper_after_disclaimer:
Not activated
menu_display_headup_display:
Not activated
menu_display_headup_display_clamp_15_off:
Not activated
menu_display_headup_display_over_threshold_high:
Not activated
menu_display_headup_display_standstill:
Not activated
menu_display_headup_display_after_disclaimer:
Not activated
menu_display_central_unit_master:
activated
menu_display_central_unit_master_clamp_15_off:
Not activated
menu_display_central_unit_master_over_threshold_hi gh:
activated
menu_display_central_unit_master_standstill:
Not activated
menu_display_central_unit_master_after_disclaimer:
Not activated
menu_display_hybrid:
Not activated
menu_display_hybrid_clamp_15_off:
Not activated
menu_display_hybrid_over_threshold_high:
Not activated
menu_display_hybrid_standstill:
Not activated
menu_display_hybrid_after_disclaimer:
Not activated
menu_display_ugdo:
activated
menu_display_ugdo_clamp_15_off:
Not activated
menu_display_ugdo_over_threshold_high:
Not activated
menu_display_ugdo_standstill:
Not activated
menu_display_ugdo_after_disclaimer:
Not activated
menu_display_night_vision:
Not activated
menu_display_night_vision_clamp_15_off:
Not activated
menu_display_night_vision_over_threshold_high:
Not activated
menu_display_night_vision_standstill:
Not activated
menu_display_night_vision_after_disclaimer:
Not activated
menu_display_side_view:
Not activated
menu_display_side_view_clamp_15_off:
Not activated
menu_display_side_view_over_threshold_high:
Not activated
menu_display_side_view_standstill:
Not activated
menu_display_side_view_after_disclaimer:
Not activated
menu_display_reversible_belt_pre_load:
activated
menu_display_reversible_belt_pre_load_clamp_15_off :
Not activated
menu_display_reversible_belt_pre_load_over_thresho ld_high:
activated
menu_display_reversible_belt_pre_load_standstill:
Not activated
menu_display_reversible_belt_pre_load_after_discla imer:
Not activated
menu_display_MFL_jocker:
Not activated
menu_display_MFL_jocker_clamp_15_off:
Not activated
menu_display_MFL_jocker_over_threshold_high:
Not activated
menu_display_MFL_jocker_standstill:
Not activated
menu_display_MFL_jocker_after_disclaimer:
Not activated
menu_display_road_sign_identification:
activated
menu_display_road_sign_identification_clamp_15_off :
Not activated
menu_display_road_sign_identification_over_thresho ld_high:
activated
menu_display_road_sign_identification_standstill:
Not activated
menu_display_road_sign_identification_after_discla imer:
Not activated
menu_display_attention_identification:
Not activated
menu_display_attention_identification_clamp_15_off :
Not activated
menu_display_attention_identification_over_thresho ld_high:
Not activated
menu_display_attention_identification_standstill:
Not activated
menu_display_attention_identification_after_discla imer:
Not activated
menu_display_adaptive_key:
activated
menu_display_adaptive_key_clamp_15_off:
Not activated
menu_display_adaptive_key_over_threshold_high:
activated
menu_display_adaptive_key_standstill:
Not activated
menu_display_adaptive_key_after_disclaimer:
Not activated
menu_display_car_mirror:
Not activated
menu_display_car_mirror_clamp_15_off:
Not activated
menu_display_car_mirror_over_threshold_high:
Not activated
menu_display_car_mirror_standstill:
Not activated
menu_display_car_mirror_after_disclaimer:
Not activated
menu_display_driving_school:
Not activated
menu_display_driving_school_clamp_15_off:
Not activated
menu_display_driving_school_over_threshold_high:
Not activated
menu_display_driving_school_standstill:
Not activated
menu_display_driving_school_after_disclaimer:
Not activated
menu_display_weariness_recognition:
Not activated
menu_display_weariness_recognition_clamp_15_off:
Not activated
menu_display_weariness_recognition_over_threshold_ high:
Not activated
menu_display_weariness_recognition_standstill:
Not activated
menu_display_weariness_recognition_after_disclaime r:
Not activated
menu_display_BCmE:
Not activated
menu_display_BCmE_clamp_15_off:
Not activated
menu_display_BCmE_over_threshold_high:
Not activated
menu_display_BCmE_standstill:
Not activated
menu_display_BCmE_after_disclaimer:
Not activated
menu_display_user_eco_rating:
Not activated
menu_display_user_eco_rating_clamp_15_off:
Not activated
menu_display_user_eco_rating_over_threshold_high:
Not activated
menu_display_user_eco_rating_standstill:
Not activated
menu_display_user_eco_rating_after_disclaimer:
Not activated
menu_display_Brake_Function:
Not activated
menu_display_Brake_Function_clamp_15_off:
Not activated
menu_display_Brake_Function_over_threshold_high:
Not activated
menu_display_Brake_Function_standstill:
Not activated
menu_display_Brake_Function_after_disclaimer:
Not activated
menu_display_Start_Stop_reasons:
Not activated
menu_display_Start_Stop_reasons_clamp_15_off:
Not activated
menu_display_Start_Stop_reasons_over_threshold_hig h:
Not activated
menu_display_Start_Stop_reasons_standstill:
Not activated
menu_display_Start_Stop_reasons_after_disclaimer:
Not activated
menu_display_angle_of_slope:
activated
menu_display_angle_of_slope_clamp_15_off:
Not activated
menu_display_angle_of_slope_over_threshold_high:
activated
menu_display_angle_of_slope_standstill:
Not activated
menu_display_angle_of_slope_after_disclaimer:
Not activated
menu_display_battery_management:
Not activated
menu_display_battery_management_clamp_15_off:
Not activated
menu_display_battery_management_over_threshold_hig h:
Not activated
menu_display_battery_management_standstill:
Not activated
menu_display_battery_management_after_disclaimer:
Not activated
menu_display_RearSeatEntertainment:
Not activated
menu_display_RearSeatEntertainment_clamp_15_off:
Not activated
menu_display_RearSeatEntertainment_over_threshold_ high:
Not activated
menu_display_RearSeatEntertainment_standstill:
Not activated
menu_display_RearSeatEntertainment_after_disclaime r:
Not activated
menu_display_special_functions:
Not activated
menu_display_special_functions_clamp_15_off:
Not activated
menu_display_special_functions_over_threshold_high :
Not activated
menu_display_special_functions_standstill:
Not activated
menu_display_special_functions_after_disclaimer:
Not activated
menu_display_trailer_assistant:
Not activated
menu_display_trailer_assistant_clamp_15_off:
Not activated
menu_display_trailer_assistant_over_threshold_high :
Not activated
menu_display_trailer_assistant_standstill:
Not activated
menu_display_trailer_assistant_after_disclaimer:
Not activated
menu_display_TV_Tuner:
Not activated
menu_display_TV_Tuner_clamp_15_off:
Not activated
menu_display_TV_Tuner_over_threshold_high:
Not activated
menu_display_TV_Tuner_standstill:
Not activated
menu_display_TV_Tuner_after_disclaimer:
Not activated
menu_auxiliary_climatization:
Not activated
menu_auxiliary_climatization_clamp_15_off:
Not activated
menu_auxiliary_climatization_over_threshold_high:
Not activated
menu_auxiliary_climatization_standstill:
Not activated
menu_auxiliary_climatization_after_disclaimer:
Not activated
menu_display_Pedestrian_Assist:
Not activated
menu_display_Pedestrian_Assist_clamp_15_off:
Not activated
menu_display_Pedestrian_Assist_over_threshold_high :
Not activated
menu_display_Pedestrian_Assist_standstill:
Not activated
menu_display_Pedestrian_Assist_after_disclaimer:
Not activated
menu_display_Seat_Pneumatic:
Not activated
menu_display_Seat_Pneumatic_clamp_15_off:
Not activated
menu_display_Seat_Pneumatic_over_threshold_high:
Not activated
menu_display_Seat_Pneumatic_standstill:
Not activated
menu_display_Seat_Pneumatic_after_disclaimer:
Not activated
menu_display_Curve_Assist:
Not activated
menu_display_Curve_Assist_clamp_15_off:
Not activated
menu_display_Curve_Assist_over_threshold_high:
Not activated
menu_display_Curve_Assist_standstill:
Not activated
menu_display_Curve_Assist_after_disclaimer:
Not activated
menu_display_eCall:
activated
menu_display_eCall_clamp_15_off:
Not activated
menu_display_eCall_over_threshold_high:
activated
menu_display_eCall_standstill:
Not activated
menu_display_eCall_after_disclaimer:
Not activated
menu_display_ENI:
activated
menu_display_ENI_clamp_15_off:
Not activated
menu_display_ENI_over_threshold_high:
activated
menu_display_ENI_standstill:
Not activated
menu_display_ENI_after_disclaimer:
Not activated
menu_display_SportHMI:
Not activated
menu_display_SportHMI_clamp_15_off:
Not activated
menu_display_SportHMI_over_threshold_high:
Not activated
menu_display_SportHMI_standstill:
Not activated
menu_display_SportHMI_after_disclaimer:
Not activated
menu_display_Adblue:
Not activated
menu_display_Adblue_clamp_15_off:
Not activated
menu_display_Adblue_over_threshold_high:
Not activated
menu_display_Adblue_standstill:
Not activated
menu_display_Adblue_after_disclaimer:
Not activated
menu_display_Spoiler:
Not activated
menu_display_Spoiler_clamp_15_off:
Not activated
menu_display_Spoiler_over_threshold_high:
Not activated
menu_display_Spoiler_standstill:
Not activated
menu_display_Spoiler_after_disclaimer:
Not activated
menu_display_Efficiency_Assist:
activated
menu_display_Efficiency_Assist_clamp_15_off:
Not activated
menu_display_Efficiency_Assist_over_threshold_high :
activated
menu_display_Efficiency_Assist_standstill:
Not activated
menu_display_Efficiency_Assist_after_disclaimer:
Not activated
menu_display_Display_Configuration:
Not activated
menu_display_Display_Configuration_clamp_15_off:
Not activated
menu_display_Display_Configuration_over_threshold_ high:
Not activated
menu_display_Display_Configuration_standstill:
Not activated
menu_display_Display_Configuration_after_disclaime r:
Not activated
menu_soundcontrol:
Not activated
menu_soundcontrol_clamp_15_off:
Not activated
menu_soundcontrol_over_threshold_high:
Not activated
menu_soundcontrol_standstill:
Not activated
menu_soundcontrol_after_disclaimer:
Not activated
Testmode_Video_speed_cutoff:
speed_limit:
0 km/h
pin:
Base volume of speech output:
50 %
Dashboard_Display_Configuration:
navigation_map_transmission_mode:
LVDS_map_FPK
navigation_map_compression_mode:
RLE
navigation_map_resolution:
resolution_1
crossroad_detail_map_transmission_mode:
LVDS_map_FPK
crossroad_detail_map_compression_mode:
RLE
coverart:
On
stationart:
On
call_picture:
On
crossroad_detail_map_resolution:
resolution_1
fastlist_most:
On
ability_switch_nav_maps:
Off
dynamic_icon:
Car_Function_List_CAN_Gen2:
MFL:
available
MFL_msg_bus:
Databus Infotainment
reserved:
Not available
reserved_1:
Not available
Oil_level:
available
Oil_level_msg_bus:
Terminal 15
PDC_audio_lowering:
available
PDC_audio_lowering_msg_bus:
Terminal 15
VIN:
available
VIN_msg_bus:
Terminal 15
Driving_school:
Not available
Driving_school_msg_bus:
Not available
Adaptive_key_msg_bus:
Terminal 15
Adaptive_key:
available
reserved_2:
Not available
reserved_3:
Not available
Bluetooth: Preferred connection profile for phone book data:
PBAP
Interface for external media, activation:
Connection 1:
activated
Connection 2:
activated
Connection 3:
Not activated
Connection 4:
Not activated
Audio Management Input Gain Generation 2:
TV tuner:
-128
Radio (FM):
-128
Radio (AM):
-128
Digital radio (DAB):
-128
Satellite radio:
17
Tuner_TI:
-128
Media_AUXIN:
-128
Media_AUX_Adapter:
-128
Media_CDA:
-128
Media_DVD:
-128
Media_MFP:
-128
Media_BTDevice:
-128
TA_Tuner_FM:
-128
Media_Bluray:
-128
Media_HDMI:
-128
Tuner_Online:
-128
Media_Airplay:
-128
Media_UPNP:
-128
Media_Cloud:
-128
Tuner_Personal:
-128
Tone_Beep:
Tone_Warning:
-128
Tone_Touchscreen:
-128
Tone_Messaging:
-128
Exbox_DMB:
-128
Mirrorlink:
-128
TTS_Nav:
-6
TTS_SDS:
-6
Phone_Voice:
-128
Phone_Ringer_MFP:
-128
Phone_Ringer_OB:
-128
HFP:
-128
TV_AV_IN:
-128
Radio_Level_Quality_Offsets:
Set_AM_Quality_Level_Offset:
Set_FM_Quality_Level_Offset:
Audio_Management_Audio_Delay_Lines_Gen2:
Main_Unit_Delay_On_Off:
On
Amplifier_Delay_On_Off:
On
Main_Unit_Delay_Time:
150.00 ms
Amplifier_Delay_Time:
150.00 ms
Headphone_Delay_On_Off:
Off
Headphone_Delay_Time:
0.00 ms
Headphone_wireless_Delay_On_Off:
Off
Headphone_wireless_Delay_Time:
0.00 ms
Car_Function_List_BAP_Gen2:
climatic_master_0x01:
activated
climatic_master_0x01_msg_bus:
Terminal 15
climatic_slave_0x02:
activated
climatic_slave_0x02_msg_bus:
Terminal 15
auxilary_heating_0x03:
Not activated
auxilary_heating_0x03_msg_bus:
Not activated
headup_displ_0x04:
Not activated
headup_displ_0x04_msg_bus:
Not activated
ACC_0x05:
Not activated
ACC_0x05_msg_bus:
Not activated
air_suspension_0x06:
activated
air_suspension_0x06_msg_bus:
Terminal 15
tire_pressure_system_0x07:
activated
tire_pressure_system_0x07_msg_bus:
Terminal 15
interieur_light_0x08:
activated
interieur_light_0x08_msg_bus:
Terminal 15
exterieur_light_0x09:
activated
exterieur_light_0x09_msg_bus:
Terminal 15
parking_assist_0x0A:
activated
parking_assist_0x0A_msg_bus:
Terminal 15
VPS_0x0B:
activated
VPS_0x0B_msg_bus:
Terminal 15
wiper_comfort_0x0C:
activated
wiper_comfort_0x0C_msg_bus:
Terminal 15
central_locking_0x0D:
activated
central_locking_0x0D_msg_bus:
Terminal 15
mirror_0x0E:
Not activated
mirror_0x0E_msg_bus:
Not activated
MFA_0x0F:
activated
MFA_0x0F_msg_bus:
Terminal 15
driver_seat_0x10:
activated
driver_seat_0x10_msg_bus:
CAB_4
clock_0x11:
activated
clock_0x11_msg_bus:
service_interval_display_0x12:
activated
service_interval_display_0x12_msg_bus:
Terminal 15
unit_master_0x13:
activated
unit_master_0x13_msg_bus:
Terminal 15
UGDO_0x14:
activated
UGDO_0x14_msg_bus:
Terminal 15
compass_0x15:
Not activated
compass_0x15_msg_bus:
Not activated
clima_slave_2_0x16:
Not activated
clima_slave_2_0x16_msg_bus:
Not activated
charisma_0x17:
activated
charisma_0x17_msg_bus:
Terminal 15
Night_Vision_0x18:
Not activated
Night_Vision_0x18_msg_bus:
Not activated
LDW_HCA_0x19:
activated
LDW_HCA_0x19_msg_bus:
Terminal 15
SWA_0x1A:
activated
SWA_0x1A_msg_bus:
Terminal 15
AWV_0x1B:
Not activated
AWV_0x1B_msg_bus:
Not activated
Hybrid_0x1D:
Not activated
Hybrid_0x1D_msg_bus:
Not activated
SideView_0x1E:
Not activated
SideView_0x1E_msg_bus:
Not activated
Reversible_Seat_Belt_Tightener_0x1F:
activated
Reversible_Seat_Belt_Tightener_0x1F_msg_bus:
Terminal 15
Passanger_Seat_0x20:
Not activated
Passanger_Seat_0x20_msg_bus:
Not activated
traffic_sign_recognition_0x21:
activated
traffic_sign_recognition_0x21_msg_bus:
Terminal 15
weariness_rcognition_0x22:
Not activated
weariness_rcognition_0x22_msg_bus:
Not activated
BCmE_0x23:
Not activated
BCmE_0x23_msg_bus:
Not activated
Brake_0x26:
Not activated
Brake_0x26_msg_bus:
Not activated
Start_Stop_reasons_0x27:
Not activated
Start_Stop_reasons_0x27_msg_bus:
Not activated
Amplifier_0x2D:
Not activated
Amplifier_0x2D_msg_bus:
Not activated
TV_tuner_0x2C:
Not activated
TV_tuner_0x2C_msg_bus:
Not activated
RearSeatEntertainment_0x2E:
Not activated
RearSeatEntertainment_0x2E_msg_bus:
Not activated
MFL_Jocker_0x34:
Not activated
MFL_Jocker_msg_bus_0x34:
Not activated
Special_Functions_0x35:
Not activated
Special_Functions_msg_bus_0x35:
Not activated
Trailer_Assistant_0x36:
Not activated
Trailer_Assistant_msg_bus_0x36:
Not activated
Range_Data_0x39:
Not activated
Range_Data_msg_bus_0x39:
Not activated
Angle_Of_Slope_0x24:
activated
Angle_Of_Slope_0x24_msg_bus:
Terminal 15
Battery_Management_0x25:
Not activated
Battery_Management_0x25_msg_bus:
Not activated
eCall_0x33:
activated
eCall_0x33_msg_bus:
ENI_0x37:
activated
ENI_0x37_msg_bus:
Pedestrian_Assist_0x3A:
Not activated
Pedestrian_Assist_msg_bus_0x3A:
Not activated
Seat_Pneumatic_0x3B:
Not activated
Seat_Pneumatic_msg_bus_0x3B:
Not activated
efficiency_assist_0x3C:
activated
efficiency_assis_msg_bus_0x3C:
Terminal 15
Seatmemory_driver_rear_0x3E:
Not activated
Seatmemory_driver_rear_msg_bus_0x3E:
Not activated
Seatmemory_codriver_rear_0x3F:
Not activated
Seatmemory_codriver_rear_msg_bus_0x3F:
Not activated
Parameter 2 for connection transfer (UMTS):
Scan Tune Level 2G:
Scan Tune Level 3G:
Internal SIM card, use:
automatic
FM tuner, mono/stereo setting:
l_hf_stereo_lower_threshold:
20 dBµV
l_nf_max_stereo_channel_separation:
50 dB
t_hysteresis_mono_to_stereo:
0.1 s
Brand-specific display of connect application:
Surroundings display, virtual camera positions:
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
xpos:
32767
ypos:
32767
zpos:
32767
rollangle:
65535
yawangle:
65535
pitchangle:
65535
focallength:
4294967295
Installation list, specified installations:
Instrument cluster control module:
Yes
Information electronics control module 2:
No
DVD changer:
No
TV tuner:
No
Digital Sound System Control Module:
Yes
Radio:
No
Information electronics control module 1:
Yes
Smart Display Carrier 1:
No
Control unit for head up display:
No
Multimedia Operating Unit:
No
Wireless Charger 2:
No
Wireless Charger 1:
No
Smart Control Carrier 2:
No
Smart Control Carrier 1:
No
Smart Display Carrier 2:
No
reserved_5:
No
Tuner for satellite radio, preparation:
SDARS_Preparation:
Voice operation for telephone:
apple_device:
not installed
other_devices:
not installed
Fahrzeug Funktionsliste BAP 2. Generation, Erweiterung:
spoiler_0x40:
Not activated
spoiler_0x40_msg_bus:
Not activated
display_configuration_0x45:
Not activated
display_configuration_0x45_msg_bus:
Not activated
Soundcontrol_0x44:
Not activated
Soundcontrol_0x44_msg_bus:
Not activated
front_traffic_assist_0x41:
Not activated
front_traffic_assist_0x41_msg_bus:
Not activated
climate_mastet_0x42:
Not activated
climate_mastet_0x42_msg_bus:
Not activated
connection_manager_0x47:
Not activated
connection_manager_0x47_msg_bus:
Not activated
wireless_charging_0x48:
Not activated
wireless_charging_0x48_msg_bus:
Not activated
statistic_0x4A:
Not activated
statistic_0x4A_msg_bus:
Not activated
sunroof_front_0x4B:
Not activated
sunroof_front_0x4B_msg_bus:
Not activated
sunroof_rear_0x4C:
Not activated
sunroof_rear_0x4C_msg_bus:
Not activated
fas_profile_0x4D:
Not activated
fas_profile_0x4D_msg_bus:
Not activated
Bluetooth Audio Codec:
Audio_codec:
ff
Key_code_monitoring:
monitoring_keycode_0x00_0x07:
ff
monitoring_keycode_0x08_0x0F:
ff
monitoring_keycode_0x10_0x17:
ff
monitoring_keycode_0x18_0x1F:
ff
monitoring_keycode_0x20_0x27:
ff
monitoring_keycode_0x28_0x2F:
ff
monitoring_keycode_0x30_0x37:
ff
monitoring_keycode_0x38_0x3F:
ff
monitoring_keycode_0x40_0x47:
ff
monitoring_keycode_0x48_0x4F:
ff
monitoring_keycode_0x50_0x57:
ff
monitoring_keycode_0x58_0x5F:
ff
monitoring_keycode_0x60_0x67:
ff
monitoring_keycode_0x68_0x6F:
ff
monitoring_keycode_0x70_0x77:
ff
monitoring_keycode_0x78_0x7F:
ff
monitoring_keycode_0x80_0x87:
ff
monitoring_keycode_0x88_0x8F:
ff
monitoring_keycode_0x90_0x97:
ff
monitoring_keycode_0x98_0x9F:
ff
monitoring_keycode_0xA0_0xA7:
ff
monitoring_keycode_0xA8_0xAF:
ff
monitoring_keycode_0xB0_0xB7:
ff
monitoring_keycode_0xB8_0xBF:
ff
monitoring_keycode_0xC0_0xC7:
ff
monitoring_keycode_0xC8_0xCF:
ff
monitoring_keycode_0xD0_0xD7:
ff
monitoring_keycode_0xD8_0xDF:
ff
monitoring_keycode_0xE0_0xE7:
ff
monitoring_keycode_0xE8_0xEF:
ff
monitoring_keycode_0xF0_0xF7:
ff
monitoring_keycode_0xF8_0xFF:
ff
Engine type:
Engine_type_adaption_1:
Value_from_BAP_protocol
Engine_type_adaption_2:
Navigation receiver GNSS configuration:
Default:
On
GPS:
On
Galileo:
On
Glonass:
On
Compass:
On
external_gps_1:
Off
external_gps_2:
Off
Delay_time_phone:
activated
Traffic_light_online_functions:
On
Mileage: 1831 km
Date: 2017-02-04 17:45
Backup
Control unit: 69 Trailer Function
System description: Anhaenger
Software number: 4M0907383C
Software version: 0214
Hardware number: 4M0907383
Serial number: 0420704347
ODX name: EV_TrailFunctGener2Hella
ODX version: 001008
Backup name: 69-trailer function
Long coding:
0210000200000000
Adaptations:
Production mode:
Activate start-up mode:
not active
Control module switch-off, counter:
Control module:
0 min
Data bus:
0 min
Control module switch-off, switch-off time:
Control module:
30 min
Data bus:
15 min
Mileage: 1831 km
Backup
Control unit: 6C Camera System Rear View
System description: Areaview 2
Software number: 4M0907428E
Software version: 0315
Hardware number: 4M0907428
Serial number: C854607JG0051387
ODX name: EV_CamSysRVAV2CE2MLBEv
ODX version: 004015
Backup name: 6c-camera system rear
Long coding:
02350602BB0FA10008404000
Mileage: 1831 km
Date: 2017-02-04 17:44
Backup
Control unit: 6D Deck Lid Control Unit
System description: HDSG-Modul
Software number: 8W8959107B
Software version: 0161
Hardware number: 8W8959107
Serial number: 31026432900000
ODX name: EV_DeckLidCONTIAU736
ODX version: 001014
Backup name: 6d-deck lid
Long coding:
00B0
Adaptations:
Program opening stop:
663
Offset for maximum programmable opening stop:
90
Minimum opening height of tailgate:
170
Offset for opening height after basic setting:
Detection area upper:
100
Opening height in production mode:
60 %
not active
Deactivating
Production mode:
Activation due to excessive pressure on rear lid:
not active
not active
Opening and closing rear lid:
not active
Tone sensor:
not active
Activation of rear lid with reduced speed:
not active
Calibration:
not active
Checking the rear lid button:
not active
Tailgate reverse path:
Reverse path when closing:
100
Reverse path when opening:
Deactivation of tailgate:
active
Dectivation of the luggage compartment cover:
active
Deactivation of tailgate while in trailer operation:
Release button in rear lid handle:
active
Using button to close lock. mechanism in tailgate handle:
active
Button for opening rear lid in luggage compartment:
active
Rear lid lock button in luggage compartment:
active
Sensor for rear lid opening:
active
Remote ctrl, opening with button for tailgate unlock. mechan.:
not active
Remote ctrl, closing with button for tailgate unlock. mechan.:
not active
Opening with button for remote unlocking of tailgate:
not active
Closing with remote unl.button of tailgate when using a trailer:
not active
Using sensor to open tailgate:
not active
Using sensor to close tailgate:
not active
Öffnen mit Taster 2 für Fernentriegelung der Heckklappe:
not active
Schließen m. Taster 2 f. Fernentr. d. Heckkl. b. Anhängerbetr.:
not active
Ausstattungen aktivieren:
Engine 2:
active
Motor 2, sensor system:
not active
Tone sensor:
active
Clamping strip 1:
not active
Clamping strip 2:
not active
Clamping strip 3:
not active
Clamping strip 4:
not active
Temperature sensor 1:
active
Temperature sensor 2:
active
Closing assist motor:
active
Luggage compartment cover, tolerance of the block counter:
20
Luggage compartment cover, maximum no. of block drives:
Luggage compartment cover, reverse path after obstacle recogn.:
Open:
Close:
Luggage compartment cover, detection area:
Detection area lower:
30
30
Luggage compartment cover, adjust. track tolerance:
88
Luggage compartment cover, number bloom drives:
100
Luggage compartment cover, excess limitation in exclusion area:
not active
Mileage: 1831 km
Backup
Control unit: 81 Gear Shift Control Module
System description: GSM-LL
Software number: 4M1713041F
Software version: 0073
Hardware number: 4M1713041F
Hardware version: H09
Serial number: 20161019000073
ODX name: EV_GSMWaehlZFAU736
ODX version: 001016
Backup name: 81-gear shift control
Long coding:
Adaptations:
ENUM_ActivationOfDevelopementMessages:
Off
Mileage: 1831 km
Date: 2017-02-04 17:43
Backup
ODX version: 001016
Long coding:
Adaptations:
Off
Mileage: 1831 km
Backup
Control unit: A5 Front Sensors Driver Assistance System
System description: BVS
Software number: 4M0907217D
Software version: 0042
Hardware number: 4M0907217A
Hardware version: H14
ODX name: EV_BVSMLBevKOSTAAU736
ODX version: 002026
Backup name: a5-front sensor das
Long coding:
0407030600000204032023A3AD00000090000020C020
Adaptations:
Calibration target position:
Target 1, calibration mark 1, x-coordinate:
1069.00 mm
Target 1, calibration mark 1, y-coordinate:
550.00 mm
Target 1, calibration mark 1, z-coordinate:
1619.50 mm
Target 1, calibration mark 2, x-coordinate:
1069.00 mm
Target 1, calibration mark 2, y-coordinate:
-550.00 mm
Target 1, calibration mark 2, z-coordinate:
1619.50 mm
Target 1, calibration mark 3, x-coordinate:
1069.00 mm
Target 1, calibration mark 3, y-coordinate:
550.00 mm
Target 1, calibration mark 3, z-coordinate:
1179.50 mm
Target 1, calibration mark 4, x-coordinate:
1069.00 mm
Target 1, calibration mark 4, y-coordinate:
-550.00 mm
Target 1, calibration mark 4, z-coordinate:
1179.50 mm
Driving axis angle:
0 '
Axle offset:
Front axle transverse position:
13.10 mm
Rear axle transverse position:
-5.50 mm
Body height wheel house edge:
Body height left front wheel house edge:
792.00 mm
Body height right front wheel house edge:
795.75 mm
Body height left rear wheel house edge:
811.50 mm
Body height right rear wheel house edge:
809.75 mm
Distance to calibration field:
1500.00 mm
Calibration result:
Static calibration, pitch angle:
3.21 °
Static calibration, yaw angle:
-1.18 °
Static calibration, roll angle:
-1.19 °
Static calibration, camera height:
1289 mm
Intervention moment:
Selection via menu
Directional stabilization assist driver inact deactiv threshold:
Medium
Directional stab. assist., intensity, power steering support:
Medium
Directional stab. assist., intensity, steering wheel vibration:
Medium
Personalization of lane dept. warning Cl. 15 on:
Last setting
Windshield heat. direct. stabilize. assist. activation duration:
2 min
Deactivating
Not activated
Mileage: 1831 km
Date: 2017-02-04 17:42
Backup
Control unit: CA Sunroof
System description: SAD_STG_1
Software number: 4M0907594G
Hardware number: 4M0907594
Hardware version: 013
ODX name: EV_SunRoofCONTIAU736
ODX version: 006008
Backup name: ca-sunroof
Long coding:
2A8000053602
Mileage: 1831 km
Backup
Control unit: CF Lane Change Assistant 2
Software number: 4M0907590B
Hardware number: 4M0907590
ODX name: EV_RearRadarS2BoschAU736
ODX version: 001015
Backup name: cf-lane change assist 2
Long coding:
1EE002
Mileage: 1831 km
Date: 2017-02-04 17:41
Backup
Control unit: 19 Gateway
System description: Gateway
Software number: 8W8907468D
Software version: 0308
Hardware number: 8W8907468D
Hardware version: H30
Serial number: 0185D011516A23
ODX name: EV_CGateCONTIAU491
ODX version: 002040
Backup name: 19-gateway
Long coding:
03010001000006405407000000590030C41200000C00000001 75078E10000000
Adaptations:
Production mode:
Drahtlosnetzwerkverbindung:
Deactivating
Onboard data collector:
Deactivating
Buttons for multi-function steering wheel:
Deactivating
Energy management:
Deactivating
Deactivating
Gateway:
coded
Parking Assistance:
Not coded
Tire Pressure Monitoring 1:
Not coded
Steering Column Electronics:
coded
Central Electrics:
coded
All Wheel Control:
Not coded
Steering Assistance:
coded
Dash Board:
coded
Active Steering:
Not coded
Climate Control Unit Rear:
coded
Head Up Display:
Not coded
Actuator For Structure-Borne Sound:
Not coded
Lock Electronics:
Not coded
Deck Lid Control Unit:
coded
Aerodynamics Control Unit:
Not coded
Night Vision:
Not coded
Reductant Control Module:
Not coded
Special Function 2:
Not coded
Special Function:
Not coded
Electronic Roof Control:
Not coded
Assembly Mounting:
Not coded
High Beam Assistance:
Not coded
Steering Column Locking:
Not coded
Access Startsystem Interface:
Not coded
Brake Boost:
Not coded
DC/DC Converter Control Module:
Not coded
Thermal Management:
Not coded
Battery Charger:
Not coded
Air Conditioning:
coded
Trailer Function:
coded
Door Electronics Driver Side:
coded
Door Electronics Passenger Side:
coded
Seat Adjustment Driver Side:
coded
Seat Adjustment Passenger Side:
coded
Gear Shift Control Module:
coded
Adaptive Cruise Control 2:
Not coded
Adaptive Cruise Control:
Not coded
Information Control Unit 2:
Not coded
Rear Axle Steering:
coded
Microphone Control Unit:
Not coded
Actuator For Exterior Noise:
Not coded
Camera System Rear View:
coded
Auxiliary Parking Heater:
Not coded
coded
Engine control module (ECM):
coded
Transmission Control Module:
coded
Engine Control Module 2:
Not coded
Battery Energy Control Module:
Not coded
Drive Motor Control Module:
Not coded
Chassis Control:
coded
Sun Roof:
coded
Seat Adjustment Rear Driver Side:
Not coded
Seat Adjustment Rear Passenger Side:
Not coded
Central Module Comfort System:
coded
Display Control Unit:
Not coded
Control Unit Wireless Charging:
Not coded
Display Control Unit Rear:
Not coded
Longitudinal Control:
Not coded
Seat Adjustment 3rd Row:
coded
Rear Light:
Not coded
Battery Energy Control Module 2:
Not coded
Front Corner Radar 1:
Not coded
Front Corner Radar 2:
Not coded
Control Module 2 For Sunroof:
Not coded
Message mirroring:
Target bus:
not active
Data bus CAN 1:
not active
Data bus CAN 2:
not active
Data bus CAN 3:
not active
Data bus CAN 4:
not active
Data bus CAN 5:
not active
Data bus CAN 6:
not active
Data bus Flexray A:
not active
Data bus LIN 1:
not active
Data bus LIN 2:
not active
Data bus LIN 3:
not active
Production process data 1:
000000000000
Group 1:
not active
Group 2:
not active
Group 3:
not active
XCP:
not active
Normal bus behavior during diagnosis:
active
Driving_Profile_Selection_Parameter:
Driving_Profile_Selection_Toogle_Time_Adaptation_1 :
500 ms
Driving_Profile_Selection_Toogle_Time_Adaptation_2 :
1500 ms
Driving_Profile_Selection_Toogle_Time_Adaptation_3 :
500 ms
Driving_Profile_Selection_Toogle_Time_Adaptation_4 :
500 ms
Driving_Profile_Selection_Touch_Contact_Time_Adapt ion:
6000 ms
Driving_Profile_Selection_Indication_Control_Adapt ion:
6000 ms
Driving_Profile_Selection_Kombi_Offset_Adaption:
0 ms
Driving_Profile_Selection_Sync_Time_Adaptation:
500 ms
Driving_Profile_Selection_Request_Repetition_Time_ Adaptation:
180000 ms
Driving_Profile_Selection_Fiddle_Proofing_Time_Ada ptation:
10000 ms
Driving_Profile_Selection_Fiddle_Proofing_Limit_Ad aptation:
120
Driving_Profile_Selection_Fiddle_Proofing_Lock_Ada ptation:
60000 ms
Driving_Profile_Selection_Counter_Master_Reset:
active
Driving_Profile_Selection_Number_of_Keys:
Pause recommendation:
activated
Battery adaptation:
Rated battery capacity:
92 Ah
Battery technology:
Fleece
Battery manufacturer:
JCB
Battery serial number:
461025P01C
Transport mode:
Not activated
Static current measuring mode:
Not activated
Not activated
Deactivation of start-stop function:
Regular operation
Switch_on_ban_independent_car_heater:
Switch_on_ban_activation:
Regular operation
Set_point_target_time:
80 min
energy_management_deactiv_stage:
Regular operation
Anforderung Autonomer Betrieb:
Automatic recharging of starter battery:
Regular operation
Vorkonditionierung des Innenraums:
Regular operation
High-voltage system, start request:
Regular operation
HVK_Warning:
Regular operation
Adaption_high_voltage_zero_potential:
Regular operation
WakeUpMonitor_Configuration:
Start_Delay:
0 s
Wake_Delay:
20 min
Max_Time_Keeping_Awake:
20 min
Max_Num_Logical_Wakeup:
40 counts
Max_Num_Physical_Wakeup:
10 counts
Max_Num_Knock_Out:
3 counts
Max_Num_Cluster_Sleep:
20 counts
Max_Num_Cluster_Start:
20 counts
Max_Num_CWUP:
30 counts
Max_Num_NF:
20 min
Max_Num_Sb:
20 min
WakeUpMonitor_Activation:
Activation:
activated
Activation_Bus_Activity:
activated
Activation_Keeping_Awake:
activated
Activation_Logical_Wakeup:
activated
Activation_Physical_Wakeup:
activated
Activation_Knock_Out:
activated
Activation_Cluster_Sleep:
activated
Activation_Cluster_Start:
activated
Activation_CWUP:
activated
Activation_NFU:
activated
Activation_SBU:
activated
BCmE general functionality:
BCmE Consumers:
not active
BCmE LiveTips:
not active
BCmE LED_filter:
not active
BCmE_auxiliary_heater:
not active
BCmE_current_range_calculation:
not active
BCmE_LiveTip_activiation:
BCmE_activate_instrument_cluster:
not active
BCmE_warmup_while_standing:
not active
convertibe_ac_off:
not active
stop_inhibited_throttle_while-standing:
not active
BCmE_driving_level_d:
not active
BCmE_ac_close_window_and_roof:
not active
BCmE_ac_close_roof:
not active
BCmE_ac_close_window:
not active
BCmE_start_stop_deactivated_via_push_button:
not active
BCmE_car_ready_for_start_stop_do_not_declutch:
not active
BCmE_shift_gearin_observe_shift_advice:
not active
BCmE_engine_start_no_throttle:
not active
BCmE_engine_brake_do_not_declutch:
not active
BCmE_aerodynami_Close_wi_dow_and roof:
not active
BCmE_aerodynamic-Close-roof:
not active
BCmE_aerodynamic_Close_window:
not active
Adaptation of range calculation:
Init. value average consumption BMS electric (forecast horizon):
24.10 kWh/100 km
Init. value cons. eng. range cons.:
10.30 l/100 km
Init. value average range consumption, electric traction:
23.30 kWh/100 km
Init. value of average speed electrical trip:
40.10 km/h
Init. value absolute forecast deviation air-condition. interior:
100 W
Init. value average performance A/C components:
10 W
Init. value average perf. low voltage basic consumer:
990 W
Init. value RWDS load profile:
24 A
Init. value of elec. average consumption on street class 0:
23.10 kWh/100 km
Init. value of elec. average consumption on street class 1:
23.10 kWh/100 km
Init. value of elec. average consumption on street class 2:
23.10 kWh/100 km
Init. value of elec. average consumption on street class 3:
23.10 kWh/100 km
Init. value of elec. average consumption on street class 4:
23.10 kWh/100 km
Init. value of elec. average consumption on street class 5:
23.10 kWh/100 km
Init. value of elec. average consumption on street class 6:
23.10 kWh/100 km
Initialization of CNG range consumption:
6.10 kg/100 km
Initialization of LPG range consumption:
10.20 l/100 km
Initial value of average fuel consumption on street class 0:
10.20 l/100 km
Initial value of average fuel consumption on street class 1:
10.20 l/100 km
Initial value of average fuel consumption on street class 2:
10.20 l/100 km
Initial value of average fuel consumption on street class 3:
10.20 l/100 km
Initial value of average fuel consumption on street class 4:
10.20 l/100 km
Initial value of average fuel consumption on street class 5:
10.20 l/100 km
Initial value of average fuel consumption on street class 6:
10.20 l/100 km
Mileage: 1831 km
Date: 2017-02-04 17:38
Backup
Control unit: 17 Dash Board
System description: FBenRDW
Software number: 4M0920790B
Software version: 0302
Hardware number: 4M0920790B
Hardware version: H15
ODX name: EV_DashBoardAU736
ODX version: 001022
Backup name: 17-dashboard
Long coding:
08A600E178880008022369401800600000000000
Adaptations:
Speed warning:
Unit:
Kilometers per hour
active
Speed:
150
dimming_characteristic_curve_adjustment_bargraph_m ain_colour:
X1:
Y1:
X2:
a
Y2:
X3:
32
Y3:
X4:
64
Y4:
a
X5:
dc
Y5:
50
X6:
fd
Y6:
64
dimming_characteristic_curve_adjustment_middle_dis play_main_field:
X1:
Y1:
X2:
a
Y2:
X3:
32
Y3:
X4:
64
Y4:
a
X5:
dc
Y5:
50
X6:
fd
Y6:
64
dimming_characteristic_curve_adjustment_indicator_ lights:
X1:
Y1:
X2:
a
Y2:
X3:
32
Y3:
X4:
64
Y4:
a
X5:
dc
Y5:
50
X6:
fd
Y6:
64
dimming_characteristic_curve_adjustment_gauge:
X1:
Y1:
X2:
14
Y2:
14
X3:
1e
Y3:
1e
X4:
32
Y4:
32
X5:
46
Y5:
46
X6:
64
Y6:
64
dimming_characteristic_curve_adjustment_clock_dial _day:
X1:
Y1:
X2:
a
Y2:
X3:
32
Y3:
e
X4:
64
Y4:
1e
X5:
96
Y5:
32
X6:
fd
Y6:
64
dimming_characteristic_curve_adjustment_clock_dial _night:
X1:
Y1:
X2:
a
Y2:
X3:
32
Y3:
e
X4:
64
Y4:
1e
X5:
96
Y5:
32
X6:
fd
Y6:
64
dimming_characteristic_curve_adjustment_internal_p hototransistor:
X1:
Y1:
X2:
32
Y2:
32
X3:
64
Y3:
64
X4:
96
Y4:
c8
X5:
1f4
Y5:
fd
Illumination_algorithm:
Scale_switching_algorithm:
lds
Pointer_illumination_algorithim:
terminal_58xs_bus
outside_temperature:
p_time_constant_pt1:
40 s
p_time_constant_slow_damping:
2.00
p_speed_threshold:
20 km/h
p_tendency_threshold:
1.00 °C
p_kmt_at_delta:
25 °C
p_blocking_time_after_v_bigger_0:
15 s
p_storage_time_engine_off:
180 min
p_mileage_after_v_bigger_0:
5.00 km
p_ice_warning_exit_temperature:
6 °C
p_ice_warning_entry_temperature:
4 °C
p_tendency_damping:
15 s
Source for synchronization of time:
GPS
send_messages:
not active
Configuration of Development CAN-Messages:
Block 1:
off
Block 2:
off
Block 3:
off
Block 4:
off
Block 5:
off
Block 6:
off
Block 7:
off
Block 8:
off
Block 9:
50ms
Block 10:
off
Block 11:
off
Block 12:
off
Block 13:
off
Block 14:
off
Block 15:
off
Block 16:
off
Block 17:
off
Block 18:
off
Block 19:
off
Block 20:
off
Block 21:
off
Block 22:
off
Block 23:
off
Block 24:
off
Block 25:
off
Block 26:
off
Block 27:
off
Block 28:
off
Block 29:
off
Block 30:
off
Block 31:
off
Block 32:
off
Block 33:
off
Block 34:
off
Block 35:
off
Block 36:
off
Block 37:
off
Block 38:
off
Block 39:
off
Block 40:
off
Offset for tank calibration values:
Offset sensor 1:
0.20 L
Offset sensor 2:
0.00 L
Offset sensor 3:
12.70 L
Offset sensor 4:
12.70 L
Complete tank calibration:
0.00 L
Units adjusted:
Temperature:
°C
Distance:
Kilometers
Speed:
Kilometers per hour
Pressure:
Bar
Volume:
Liter
Time:
12h AM_PM
Date:
mm_dd_yy
Consumption gasoline / diesel - LPG (liquefied petroleum gas):
Liters per 100 km
Operating range consumption, CNG (compressed natural gas):
kg per 100 km
Average consumption, electric drive:
kWh per 100 km
Language version:
US English
Day counter:
91 d
WIV: Resetting ESI:
no warning
SIE: time from inspection:
36 d
SIE: minimum value km-driving distance/inspection:
15000 km
SIE: maximum value of time between inspections:
730 d
SIE: maximum value km-driving distance/inspection:
15000 km
SIE: oil quality:
Poor oil quality
SIE: soot entry:
0 km
SIE: thermal load:
7900 km
SIE: distance driven from inspection:
1800 km
WIV: minimum value of time between inspections:
365 d
SIA: maximum value of distance to service:
15000 km
SIA: maximum value of time to service:
365 d
Fix: Max. distance until next mileage-related inspection:
30000 km
FIX: Maximum time until next time-dependent inspection:
730 d
FIX: Distance covered since last mileage-dependent inspection:
1800 km
FIX: Time since last time-dependent inspection:
36 d
Service notification in days:
30 d
FIX: Reset value for next mileage-dependent inspection:
30000 km
FIX: Reset value for next mileage-dependent inspections:
1095 d
Distance:
1831 km
Hour:
17 h
Minute:
36 min
Year:
2017 a
Month:
2 mon
Day:
4 d
Display depiction:
Version 1
Lap counter:
No display
Digital speedometer:
Display
Deactivate seat belt warning:
No
Release:
not_released
Ignition active message, actuator:
Driver door
Not activated
Initialize sensor for fuel level:
initialisation:
No
Cylinder shut-off:
No display
No-voltage display:
No display
tank_validation:
validation_deactivated
Driving profile for operating range consump.with electric drive:
25
Average consumption, low voltage auxiliary consumer:
0.20
Average consumption, high voltage auxiliary consumer:
0.50
Operating range average voltage:
10.00 A
Drive profile for road-specif. remain.oper.range for el. drive:
s_erw_rwdv_antrieb_high_class_0:
25.00
s_erw_rwdv_antrieb_high_class_1:
25.00
s_erw_rwdv_antrieb_high_class_2:
25.00
s_erw_rwdv_antrieb_high_class_3:
25.00
s_erw_rwdv_antrieb_high_class_4:
25.00
s_erw_rwdv_antrieb_high_class_5:
25.00
s_erw_rwdv_antrieb_high_class_6:
25.00
Driving profile for road-related range remaining:
s_vkmrw_rwdv_high_class_0:
10.90
s_vkmrw_rwdv_high_class_1:
10.00
s_vkmrw_rwdv_high_class_2:
10.00
s_vkmrw_rwdv_high_class_3:
10.00
s_vkmrw_rwdv_high_class_4:
10.00
s_vkmrw_rwdv_high_class_5:
10.00
s_vkmrw_rwdv_high_class_6:
10.00
Driving profiled for range remaining:
10.00 l/100 km
Driving profile for range remaining LPG:
0.00 l/100 km
Driving profiled for range remaining CNG:
0.00 kg/100 km
total_range_gas:
state:
active
selection_consumption_factor:
consumption_factor_CAN
consumption_profile:
consumption_profile_calculation
consumption_factor:
1.40
Display correction of consumptions and operating range:
100 %
Display correction of consumption and operating range, gas:
100 %
Display correct. of consump. and operating range, elec.:
100 %
Control module:
20 min
Data bus:
30 min
designvariant_activation:
Version 1:
not active
Version 2:
not active
Version 3:
not active
Version 4:
not active
Version 5:
not active
Version 6:
not active
Version 7:
not active
Version 8:
not active
Deactivating
Production mode:
not active
time_parameter_display:
tDDWUP:
0.00
tDD15_on:
0.50
tDD15_off:
0.25
hmi_t_FTuerAUF:
300 ms
phev_stat_intervall:
5.00
100 m
0 min
Picture_Upload_Download:
not active
Configuration of displayable contents:
Upshift display in center panel:
No display
Display, engine running required:
No display
Akustik, Fahrstufe R:
active
Mileage: 1831 km
Date: 2017-02-04 17:36
Backup
Control unit: 16 Steering Column Electronics
System description: Lenks.Modul
Software number: 4M0907129GR
Software version: 0009
Hardware number: 4M0907129GR
Hardware version: H11
ODX name: EV_SMLSKLOAU736
ODX version: 006008
Backup name: 16-steering
Long coding:
Adaptations:
steering wheel heater:
Temperature:
34 °C
Analysis 1:
Off
Analysis 2:
Off
Analysis 3:
Off
Analysis 4:
Off
Analysis 5:
Off
Mileage: 1831 km
Date: 2017-02-04 17:35
Backup
Control unit: 15 Airbag
System description: Airbag10.44
Software number: 4M0959655A
Software version: 0086
Hardware number: 4M0959655A
Hardware version: H71
Serial number: 003M50015KV1
ODX name: EV_AirbaAU10BPAAU736
ODX version: 005012
Backup name: 15-airbag
Long coding:
AEFCFCC000800000A0F00033C24C00000000
Subsystems:
Subsystem: BeltPretRevFL
Long coding: 88001B
Subsystem: BeltPretRevFR
Long coding: 88001B
Subsystem: SideSensor_Df
Long coding: 2D2D2D
Subsystem: SideSensor_Pf
Long coding: 2D2D2D
Subsystem: SideSensor_Dr
Long coding: 2D2D2D
Subsystem: SideSensor_Pr
Long coding: 2D2D2D
Subsystem: FrontSensor_D
Long coding: 2D2D2D
Subsystem: FrontSensor_P
Long coding: 2D2D2D
Subsystem: CentrSensorXY
Long coding: 2D2D2D
Adaptations:
Airbag adaptations:
Passenger airbag igniter:
activated
Driver airbag igniter:
activated
Front passenger side airbag igniter:
activated
Driver thorax airbag igniter:
activated
Front passenger rear thorax airbag igniter:
activated
Driver side rear thorax airbag igniter:
activated
Front passenger head curtain airbag igniter:
activated
Driver head curtain airbag igniter:
activated
Frt.passenger side rear curtain airbag igniter:
not defined
river side rear curtain airbag igniter:
not defined
Front passenger knee airbag igniter:
not defined
Driver knee airbag igniter:
not defined
Frt.pass. side seat belt tensioner igniter 3:
not defined
Driver side seat belt tensioner igniter 3:
not defined
Front passenger side seat belt tension igniter:
activated
Driver side seat belt tension igniter:
activated
Passenger side rear safety belt tension igniter:
activated
Driver side rear safety belt tension igniter:
activated
Center rear seat belt tensioner igniter:
not defined
Igniter for active head restraint on frt. passenger side:
not defined
Driver side active head restraint igniter:
not defined
Igniter for battery interrupt:
activated
Rollover protection system:
not defined
Key switch:
Airbag deactivation key switch not parameterized
Seat occupied recognition:
activated
Igniter for window airbag:
not defined
Pedestrian protection igniter engine hood:
not defined
Igniter for battery interrupt, high voltage battery:
not defined
Igniter for battery open circuit 2nd battery:
not defined
Reserved:
activated
Reserved:
activated
Reserved:
activated
Calibration data, pre-crash:
Raw-Data:
C1407DFFFEFB736F001500006A5A00F0571C
Adaptation pre-crash:
Seat belt tensioner, left:
activated
Seat belt tensioner, right:
activated
Reserved:
activated
Reserved:
activated
Reserved:
not defined
Reserved:
activated
Reserved:
activated
Reserved:
activated
Reserved:
not defined
Reserved:
activated
Reserved:
activated
Reserved:
activated
Reserved:
not defined
Reserved:
activated
Reserved:
activated
Reserved:
activated
Programming, left belt tensioner:
Slave Parameter Data:
88001B01300E00FF28292A2B2CFFFFFF070E00FF303132FFFF FFFFFF070E00FFFFFFFFFFFFFFFFFF320E00FF40414243FFFF FFFF070E00FF48494AFFFFFFFFFF00021E010100FFFF000A16 010110FFFF001410010110FFFF0DAC1A090000FF0F000A0081 0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFF001E14010010FFFF0DAC14090010FFFF000A00810000 FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFF
Mileage: 1831 km
Backup
Control unit: 09 Central Electrics
System description: BCM1 MLBevo
Software number: 8W0907063CG
Software version: 0266
Hardware number: 8W0907063BG
ODX name: EV_BCM1BOSCHAU736
ODX version: 018006
Backup name: 09-central electrics
Long coding:
07501563E0691CCD050F571958BF9CB911033D019000000000 0000002200160108690123025709
Mileage: 1831 km
Date: 2017-02-04 17:33
Backup
Control unit: 08 Air Conditioning
System description: Klima Zone 4
Software number: 4M0820043AB
Software version: 0093
Hardware number: 4M0820043AB
Hardware version: H52
ODX name: EV_AirCondiFrontBHTCAU736
ODX version: 001013
Backup name: 08-air cond
Long coding:
6608090C554800111068028080000000000000000000000000 0000000000
Adaptations:
OBD_activation:
Not activated
EntwID_activation:
Display:
Not activated
Flaps:
Not activated
Potentiometer:
Not activated
Climate:
Not activated
CapSense:
Not activated
Massflow:
Not activated
Clima-OBD:
Not activated
System:
Not activated
LIN1:
Not activated
LIN2:
Not activated
OBD_channel:
Speed of motors:
Store recirculation air setting for terminal 15 off:
According to country version
Ignore compressor switch-off by Engine Control Module:
Do not ignore
Post-heating of parking heater:
10 min
After-run of parking heater or parking ventilation:
activated
After-run time of auxiliary heater with A/C off:
120 s
Retrofitting of parking heater without CAN:
not installed
Offset of fresh air blower speed:
Temperature offset, summer operation:
Temperature offset, winter operation:
Air quality sensor sensitivity:
Medium
MMI display time for controls at rear:
10 s
Window condensation reduction at high humidity:
Matching coding
Leakage air to footwell:
Automatic
Shut-off temperature for solar sunroof:
5 °C
not active
Window condensation parameter for start-stop function:
A/C comfort parameter for start-stop function:
Production mode:
not active
Deactivate production mode:
Deactivating
Roller test bench mode, functional:
Not activated
Tolerance range for flap end stops:
Runtime for compressor run-in basic setting:
60 s
Interior target temperature for production routines:
22 °C
Blower regulator for production routines:
Air distribution for production routines:
Air distribution upper body vents and footwell
Recirculation air for production routines:
Recirculating air
HVAC_Version:
HVAC_Version:
SWZ
Compressor control in efficiency mode:
Eco mode
Seat occupancy-depending A/C:
None
Mileage: 1831 km
Backup
Control unit: 06 Seat Adjustment Passenger Side
System description: MEM-BFS
Software number: 4M1959760
Software version: 0031
Hardware number: 4M1959760
Hardware version: 008
Serial number: 00000225466194
ODX name: EV_SCMPasseSideCONTIAU736
ODX version: 006009
Backup name: 06-seats
Long coding:
001430000000B2010000010101010000000000000000000000 000000000000
Adaptations:
installation position:
Front passenger side memory seat
vehicle_velocity_monitoring:
active
Resetting standardization:
All
Activating and deactivating all development messages:
Group 1:
not active
Group 2:
not active
Group 3:
not active
Group 4:
not active
Group 5:
not active
Group 6:
not active
Group 7:
not active
Group 8:
not active
Production mode:
Deactivate massage function:
not active
active
Reset counter for compressor for multicontour seat:
Activate
Mileage: 1831 km
Date: 2017-02-04 17:32
Long coding
Old value:
001410000000B0010000010101010000000000000000000000 000000000000
New value:
Mileage: 1831 km
Backup
Control unit: 03 Brakes
System description: ESP9 Premium
Software number: 4M0907379Q
Software version: 0657
Hardware number: 4M0907379N
ODX name: EV_ESP9BOSCHAU536K
ODX version: 012013
Backup name: 03-brakes
Long coding:
28AA149C30A50A9B91A75896187F5692E6268A14280C50891A 186A49676451
Adaptations:
Tire press monitor.display, warning sensitivity:
Tire press. monitor. sys, position display:
RKA_Datalog_Mode:
datalog off
RKA_Simulation_Mode:
RKA Simulation-Code:
Reset_RKA_Maximal_System_Runtime:
Data:
valid value stored
RKA_Stop-Start:
Param to DOP:
use real Kl.15
Text_Warning:
active
ESP_ASR:
ESC_Vollsystem
Tripping threshold for start-up assist.:
normal
VIN_Monitoring:
active
Install. position of wheel speed sens.:
Wheel FL:
regularly
Wheel FR:
regularly
Wheel RL:
regularly
Wheel RR:
regularly
Driving_Steering_Recommendation:
active
Fading_Assistant_FBS_HFC_HPS:
active
Brake disc wiper:
normal
Brake direction holding function:
Off
EWB_S100:
Not activated
EWB_S101:
Not activated
EWB_S102:
Not activated
EWB_DEV_ESP_01:
Not activated
EWB_DEV_EPB_01:
Not activated
EWB_DEV_RKA_01:
Not activated
Internal System Error Number:
ESP coasting operation:
Roller operation ESP, status:
not active
Axis for vehicle speed measurement:
Front axle activated
Not activated
Automatic closing if error in button for parking brake:
Not activated
Start assist.,boundary cond. for driver's presence during start:
After manual closing of the parking brake:
Driver side door contact and belt switch
After automatic closing of the parking brake:
Extended driver presence recognition
Production mode:
Deactivating
Vehicle holding function:
Deactivating
Deactivating
Vehicle production mode:
Deactivating
Deactivating
Hold management in production mode:
EPBi_P_Mode_lokal:
Deactivating
Hold management in transport mode:
Local activation:
Deactivating
Transportmodus automatisch übernehmen:
Activate
Driver warn. during hill descent:
active
auto_hold_seatbelt_evaluation:
Deactivating
Powertrain_Protection:
Protection:
active
Prohibition of setting rear axle drive, µ-split braking:
HAL-Stellverbot:
activated
Prohibit. of sett.rear wh.drive, countersteer. when overst.:
HAL-Stellverbot:
activated
DSDL_EOLCheck:
not active
Dimmung_EPB_TaLa:
Pos1_KL_58xd:
Pos2_KL_58xd:
Pos3_KL_58xd:
10
Pos4_KL_58xd:
25
Pos5_KL_58xd:
60
Pos6_KL_58xd:
100
Glaettung_PWM_Dimmung:
not active
Nominal_Voltage_dimming:
Nennspannung_Dimmung:
13.00 V
Analysedaten, Status:
activated
HDC_switch_on_configuration:
Vorschlag: button_only
Mileage: 1831 km
Backup
Control unit: 02 Transmission
System description: 0D5 30TSIUSA
Software number: 4M0927158L
Software version: 1006
Hardware number: 0D5927156H
Hardware version: H03
ODX name: EV_TCMALX52011
ODX version: 002010
Backup name: 02-transmission
Long coding:
100000
Adaptations:
Single gear display:
D off/S off
Distance data:
not active
not active
Park decoupling:
not active
Automatic upshift:
active
Steering wheel tiptronic switch:
active
Deactivating
Production mode:
Production Mode:
not active
Adaption Stategy Mode:
not active
ECU_W:
00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000
Mileage: 1831 km
Date: 2017-02-04 17:31
Backup
Control unit: 01 Engine
System description: 3.0l V6 TFSI
Software number: 4M0907551A
Software version: 0003
Hardware number: 06E907425
Hardware version: H10
ODX name: EV_ECM30TFS0214M0907551A
ODX version: 001005
Backup name: 01-engine
Long coding:
2A2A0032053E010D74280000000000000000000000000000
Adaptations:
Idle RPM correction:
Idle Speed Offset:
0 1/min
Engine run-in oil pressure:
not active
000000
Production mode:
000000
Activation of start-stop function:
active
Protective function:
Enabled
Not activated
Deactivation of warm travel request:
active
Operating mode selec.:
CNG operation:
Not activated
DI operation:
Not activated
Not activated
Data bus:
30 min
Mileage: 1831 km
Date: 2017-02-04 17:27
Long coding
Old value:
New value:
Mileage: 1307 km
Date: 2017-01-27 17:40
Long coding
Old value:
New value:
Mileage: 1307 km
Long coding
Control unit: 36 Seat Adjustment Driver Side
Old value:
005C3B000000B0010000010101010000000000000000000000 000000000000
New value:
005C3B000000B2010000010101010000000000000000000000 000000000000
Mileage: 1307 km
Date: 2017-01-27 17:39
Long coding
Old value:
New value:
Mileage: 1307 km
Long coding
Old value:
005C1B000000B0010000010101010000000000000000000000 000000000000
New value:
Mileage: 1307 km
Date: 2017-01-27 17:38
Long coding
Old value:
New value:
Mileage: 1307 km
Adaptation
Control unit: 5F Information Control Unit
Name: Fee-based traffic information (TMC)
Values:
Old value: 1024
New value: 65535
Mileage: 858 km
Date: 2017-01-19 18:11
Adaptation
Values:
Old value: 1537
New value: 1024
Mileage: 858 km
Date: 2017-01-19 18:05
Long coding
Old value:
08A700E178880008022369401800600000000000
New value:
Mileage: 858 km
Date: 2017-01-19 18:04
Adaptation
Values:
Old value: 65535
New value: 1537
Mileage: 808 km
Date: 2017-01-16 20:01
Adaptation
Name: Vehicle configuration
Values:
SDS_Region_Flag:
Old value: no_region
New value: REGION_NAR
online_portal_browser_services:
Old value: On
New value: Off
online_media:
Old value: On
New value: Off
my_audi:
Old value: On
New value: Off
picture_navi:
Old value: On
New value: Off
gracenote_online_other:
Old value: On
New value: Off
WIFI_Hotspot:
Old value: On
New value: Off
VZAPro:
Old value: On
New value: Off
online_dictation:
Old value: On
New value: Off
gracenote_online_coverarts:
Old value: On
New value: Off
online_street_view:
Old value: On
New value: Off
online_POI_voice:
Old value: On
New value: Off
online_navigation:
Old value: On
New value: Off
online_POI:
Old value: On
New value: Off
WiFi_Client_HMI:
Old value: On
New value: Off
Mileage: 721 km
Date: 2017-01-14 19:54
Long coding
Old value:
New value:
Mileage: 721 km
Date: 2017-01-14 19:36
Long coding
Old value:
New value:
Mileage: 721 km
Adaptation
Values:
Old value: Off
New value: On
online_street_view:
Old value: Off
New value: On
online_dictation:
Old value: Off
New value: On
online_POI_voice:
Old value: Off
New value: On
map_instant_messaging_support:
Old value: Off
New value: On
my_audi:
Old value: Off
New value: On
SDS_Region_Flag:
Old value: REGION_NAR
New value: no_region
Old value: Off
New value: On
picture_navi:
Old value: Off
New value: On
online_navigation:
Old value: Off
New value: On
VZAPro:
Old value: Off
New value: On
Sim_card_mode_switch:
Old value: Not present
New value: Present
online_media:
Old value: Off
New value: On
online_POI:
Old value: Off
New value: On
Old value: Off
New value: On
WIFI_Hotspot:
Old value: Off
New value: On
Mileage: 699 km
Date: 2017-01-14 00:59
Adaptation
Values:
WiFi_Client_HMI:
Old value: Off
New value: On
Mileage: 699 km
Date: 2017-01-14 00:56
Long coding
Old value:
New value:
Mileage: 699 km
Date: 2017-01-14 00:31
Long coding
Old value:
New value:
Mileage: 699 km
Long coding
Old value:
080100E178880008022369401800600000000000
New value:
Mileage: 699 km
Date: 2017-01-14 00:26
Long coding
Old value:
New value:
Mileage: 423 km
Date: 2017-01-07 17:21
Long coding
Old value:
New value:
Mileage: 423 km
Long coding
Old value:
088100E178880008022369401800600000000000
New value:
Mileage: 423 km
Date: 2017-01-07 17:20
Long coding
Old value:
New value:
Mileage: 423 km
Long coding
Old value:
008100E178880008022369401800600000000000
New value:
Mileage: 423 km
Date: 2017-01-07 17:19
Long coding
Old value:
New value:
Mileage: 423 km
Long coding
Old value:
New value:
Mileage: 423 km
Date: 2017-01-07 17:18
Long coding
Old value:
New value:
Mileage: 423 km
Long coding
Old value:
New value:
Mileage: 423 km
Date: 2017-01-07 16:58
Long coding
Old value:
New value:
Mileage: 370 km
Date: 2017-01-07 11:02
Long coding
Old value:
New value:
Mileage: 370 km
Old 02-04-2017, 02:08 PM
  #39
chimcu's Avatar
fyi.. I there was a few module i couldn't backup.. eg.. 46 (description data not found error)
Old 02-04-2017, 04:23 PM
  #40
s_Fanous's Avatar
Thanks a lot chimcu
Does your car have Audi Connect? None of the expected adaptations (Vehicle configuration-my_audi, Vehicle configuration-remote_hmi, ...) within 5F are on so I'm very confused.
TIA
Quick Reply: Guide: Enable Google Earth/Traffic on Canada spec Audi
