Quattro A4 - Tire swap from front to back?
Recently on a dealer visit my front tires were measured at 7/32 and rear ones at 9/32.
Do I need to rotate/swap the front with the rear two so that the back and front wear uniformly?
P.S. - Other Info - One of my rear tires is only 8 months old vs @16 months of the other 3.
Yes, you can rotate them front to back, same side. Front tires wear more quickly than rear tires. I do this with two sets of wheels & tires - summer and winter. So I'm rotating tires about every 4,000 miles which is overkill but my tire wear is very even as a result. You can buy a tread depth gauge at an autoparts store to monitor them yourself and rotate them when they are noticeably different. I would try to keep the tread depths on each axle the same so the axle is balanced side-to-side and you aren't stressing the quattro system by consistently spinning one tire faster than the other.
Depending on where you live, if you have a lot of on or off ramps and roundabouts(like here in NJ), your left side front will wear quicker. So in this case, its also good to switch side to side as well. However, if your tire shoulders are wearing evenly, you can just do front to rear swaps.
Depending on the tire model, they might have a specified rotational direction (indicated with arrows on the side) that you should keep. (On a previous car I actually had tires that were both asymmetric and with specified rotation, so these were defined at purchase for left or right side.) I swap front/rear each season.
I have the pirelli cinturato p7 all season plus 245/40R18. Not sure if it has a specified rotation.
This kept in mind, I read somewhere that the 2 tyres which have better / higher tread should (against what I'd assume to be normal based on no knowledge at all =) ) be put on the BACK axle. Why is this?
This is controversial, and some experts don't agree. I think the key here is what an "untrained" driver has an easier time handling, and after some thought it makes sense to me. I think it was Tirerack, but I remember reading a different blurb about front tire vs. rear tire replacement and the "profesional drivers" had no problems, but they put their sales team in the driver's seat and the sales team had a much easier time maintaining control with new tires in the rear. I have no idea what affect modern traction control or four wheel drive systems would have on this, as I'm sure that muddies the waters even more.
