Retrofitted: Ambient lightning (Just like the Extended LED Interior Lighting Pack)
#21
Hi
Hi Guys, I recently bought an Audi Q7 in Australia.. when I ordered it I wasn't aware of the ambient lighting package and now I'm regretting it a lot after seeing it.
When I exit or lock the car there is this red LED light which comes up on the doors but it goes away in few seconds. So my question is that is it possible to keep this red led lights on the doors on permanently or any other way to get the ambience package installed?
#22
#23
In the UK there are 3 LED options. On the SE the locations are limited. But on the Sport and the S Line all locations get the LEDs but fixed to a single colour. The Extended LED option allows for the colours to be changed. Does anyone know if on the Sport and S Line are the RGB LEDs installed but fixed to a single colour via coding or are the LED themselves a single colour unit?
#24
Hi
I love your mod. As an electronics/software/techie person, I wonder whether we could look into the data signals required for this and mock them up? I have used multicolour RGB LED strips before, but never put much thought to the control harness. I imagine there would be a power circuit and then additional lines to specify hue and flash. Would that account for the 4 wires in the Audi module? If so, wouldnt the info coming from the MMI be similar to the modules you buy commercially? Anyway, food for thought.
Thanks
Robyn
Thanks
Robyn
#25
I have wanted to retrofit this ambient light option since i collected my Q7 last year. The chinese site taobao is selling the retrofit kit for Q7 and A4. And the parts only have led modules, conductors, led lights, and the wiring. No extra module was mentioned.
I guess for this to work, we need to find the wiring diagram for the led modules. And then purchase the necessary wiring or maybe modules and find the correct codes.
Anyone has the wiring diagram to share? If not, then i need to purchase it. Thanks.
#27
You can check out this link https://item.taobao.com/item.htm?id=...u=t2dmg8j26111
Dont think need to buy the vents and the centre console as we can just buy the led conductors and modules will do.
#28
Is there any new info on this topic? Has anyone successfully or even attempted to upgrade to full RGB LEDs?
I would love to have this feature but I'm in a P+ so from reading these threads it sounds like a huge headache.
I guess if I couldn't change the colors thru the MMI I would be okay with just replacing the white LED with a colored LED.
Anyone replace all the white LEDs with colored?
#29
I have dropped the idea because too many parts need to be replaced. Good luck to you.
#30
Thanks
steve
