Retrofitted: Ambient lightning (Just like the Extended LED Interior Lighting Pack)
#83
Another question I have, is whether I can swap out the other white LEDs with blue ones usig the same LEDs without throwing a code.
I went to change the plastic center console trim with a leather one and found the light strip behind it, easily accessible and removable. I was able to trim the LED housing to make the blue LED (linked in the first post) fit but wanted to know if it might throw a code if I cut out the existing white only LED and solder on the blue one.
I have blue in my footwell but still looking for blue to swap on the door panels etc
#84
#85
please post some pics when you get it working!
#86
ach maybe and then I had to shove the LED in there good to get it to close. Worth it though.
I did the centre so far and will do the doors next.
#87
do you have pics of the modified housing and new LED before install?
#88
I will put up some pics when I change the LEDs in the doors.
#89
I forgot to specify that you have to do an MMI reset to make it appear.
yes in the MMI I have not yet found the contour lighting and the contour lighting color (door handle).
yes that requires a coding that I do not know
it is necessary to change the modules but also the harnesses or to make them even.
Thanks in advance.
danshonin
