When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
My car has been produced. Got a call today from the Audi dealer. I will get in 2 weeks it seems.
I have the basic steering wheel (standard here in Europe) that looks like this:
It has that small star symbol that I'm not sure what can be used for.
I am asking because as I want to swap my current steering wheel with this gem below I found on ebay:
heating option
The only problem (and huge bonus) is that it has a heating option as you can see in the image.
1. Does the car need recoding after upgrading to a heated steering wheel for it to work? Or it's just plug and play it will work after pressing the button?
2. The airbag I assume can be swapped between my current steering wheel and the chrome one. I assume it is the same, right?
3. If the heating button is replacing the spot of the button with a star * , what will I miss without it?
Your help and info is welcome. Thanks in advance guys!
Hate to point out the obvious, but what do you think will happen to your insurance if you're in an accident and they figure out that you've done something non-standard related to the airbag? Any dependents you might have could regret your decision.
What do you mean by non-standard? I will put my brand new airbag in the chrome steering wheel. They are the same, same size, part number (the whole steering wheels are the same except the chrome part, the other is plastic). I do not get your point...
Let's say you need to change your airbag...what do you do? It's the same thing...
Proper coding should enable the heating function and disable the "joker" button (used as shortcut to one of the MMI features). Airbag may be different, you will need to confirm the part numbers to be certain. After proper coding the airbag should work just like it did with the old steering wheel.
Thank you for the info.
Coding for the heating button i expected, but do I also need coding for the airbag? Even if the airbag remains exactly the same ( it is the same part number same size same shape, everything)
Long story short: do you need coding for the airbag also?
