Blinking gearshift indicator
I have a 2004 Audi A4 that flashes red behind the dashboard “P R N D S” gear indicator. Can someone tell me how to get the fault code and what this might be? The manual says it is in failsafe mode if this happens. When I begin to drive, it won’t click into gear until I have revved the engine slightly. This car has been a money pit…I wonder how much this is going to cost me now…
Thanks, any help would be appreciated.
How many miles have you done ??
The gearbox oil should be changed every 40,000 miles
It could just need an oil change or it could be the ECU or worse
You need vagcom/vcds to check fault codes
Get it done asap
Best case £150
Worse case £4,000
Get it done asap
Best case £150
Worse case £4,000
Blackpool, do you have the vag-com info for the remote top?
VAG-COM Label File
; Audi A4 Cabriolet (8H)
; Component: J256 - Convertible Top (#26)
; P/N: 8H0-959-255-???
; includes measuring blocks
; created on 21/Jul/2006 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification: 27/Oct/2007
; requires VAG-COM 402.3 or newer
; measuring blocks
001,0,Convertible Top Status (Actual)
001,1,Convertible Top,Control Switch,Range: Open/Closed/Not Oper./Not OK
001,2,Switches &&,Positions I,See Label File
; xxxxxxx? = Convertible Top Open Position Switch (F171)
; xxxxxx?x = Convertible Top Closed Position Switch (F202)
; xxxxx?xx = Convertible Top Lock Switch Open (F294)
; xxxx?xxx = Convertible Top Lock Switch Closed (F295)
; xxx?xxxx = Convertible Top Front Lock Switch (F172)
; xx?xxxxx = Switch Point for Bow UP
; x?xxxxxx = Switch Point for Bow OPEN
; ?xxxxxxx = Switch Point for Bow DEAD CENTER
001,3,Switches &&,Positions II,See Label File
; xx--xxx? = Compartment Cover Open Position Switch (F201)
; xx--xx?x = Left Convertible Top Compartment Cover Switch (F290)
; xx--x?xx = Convertible Top Compartment Latch Switch UNLOCK (F293)
; xx--?xxx = Compartment Cover Locked Right Switch 1 (F200)
; ?x--xxxx = Convertible Top Compartment Encolsure Position Switch (F292)
001,4,Top Frame,Position (G356),Range: 0.0...255.0
002,1,Vehicle Speed,,Range: 0.0...254.0 km/h\n\n255.0 km/h = Invalid
002,2,Voltage,(Terminal 30),Range: 6.0...18.0 V\nSpecification: 10.6/11.5...16.0 V
002,3,Rear Lid,Contact Switch,Range: Lid Open/Lid Closed
002,4,Window Regulator,Operation,See Label File
; xxxxxxx1 = Window Regulator Driver: Up
; xxxxxx1x = Window Regulator Driver: Down
; xxxxx1xx = Window Regulator Passenger: Up
; xxxx1xxx = Window Regulator Passenger: Down
; xxx1xxxx = Window Regulator Rear Left: Up
; xx1xxxxx = Window Regulator Rear Left: Down
; x1xxxxxx = Window Regulator Rear Right: Up
; 1xxxxxxx = Window Regulator Rear Right: Down
003,0,Window Positions
003,1,Window Position,Driver's Door,Range: 0.0...100.0
003,2,Window Position,Passenger Door,Range: 0.0...100.0
003,3,Window Position,Rear Left Door,Range: 0.0...100.0
003,4,Window Position,Rear Right Door,Range: 0.0...100.0
004,1,Operation,Requirements,See Label File
; 1x-xx-xx = Surroundings NOT OK
; x1-xx-xx = End Position NOT OK
; xx-1x-xx = Request: Lock Cylinder Closed
; xx-x1-xx = Request: Lock Cylinder Open
; xx-xx-1x = Rear Lid Locked
; xx-xx-x1 = Request: Rear Lid Locking
004,2,Conv. Top Disabl.,due Runtime Error,Range: Yes/No
004,3,Status,Terminal 15,Range: ON/OFF
004,4,Status,Terminal 87,Range: ON/OFF
005,0,Rear Window Heating
005,1,Rear Window,Heating,Range: ON/OFF
005,2,Rear Window,Heater Relay,Range: ON/OFF
006,0,Convertible Top Status (At Fault)
006,1,Convertible Top,Control Switch,Range: Open/Closed/Not Oper./Not OK
006,2,Switches &&,Positions I,See Label File
006,3,Switches &&,Positions II,See Label File
; xx--x?xx = Convertible Top COmpartment Latch Switch UNLOCK (F293)
006,4,Top Frame,Position (G356),Range: 0.0...255.0
007,0,Convertible Top Status (Before Fault - While OK)
007,1,Convertible Top,Control Switch,Range: Open/Closed/Not Oper./Not OK
007,2,Switches &&,Positions I,See Label File
007,3,Switches &&,Positions II,See Label File
007,4,Top Frame,Position (G356),Range: 0.0...255.0
; measuring blocks
The blinking gearshift indicator is almost certainly the ECU unit.
Eventually you'll experience problems with the reverse .. slipping.
You can get the ECU unit fixed ..
I sent mine away and it was back fixed in two days for €120 .. Problem Solved.
delbeef
07-10-2005 08:05 PM
shehatezme
12-23-2003 04:46 AM
Ray K
07-13-2001 07:21 AM
