Won't start if it sets for two days
Guys at the shop are saying i have a slow battery leak somewhere,but after keeping the car for 3 days with a meter hooked up no leak was found.I let the car set for 2 days after getting the car back and it wont start,dead battery? but it starts quickly with a jump start.Battery is testing OK.Anyone ever had this problem ?
Got one from Walmart and she hasn't called me about the starting problems since.
<a href="http://www.dognmonkey.com/audi/replace-battery-a4-b6-cabriolet.html">Replacing battery on A4 cabriolet</a>
Cheers,
Louis
Refs-
If the car has a semi-conventional charging system, that could be a bad diode in the alternator. It would not show up on some drain tests, depending on what is hooked up and where, because the alternator will suck the battery out via the charging lead to the positive terminal, which is often separate from all the other fused circuits and skipped unless you test that one specifically.
With a bad diode you will still charge "almost" normally, but the bad diode acts as a drain when the engine is off. Worth checking, and easy to check with a fast ohmmeter test on the charging lead.
carl viking
40
Yesterday 02:45 PM
Audi A7 MINT M130 Wheels for RS7 - 20x9
RCCurtis
09-01-2015 03:09 PM
