When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
So I've got Dynamic mode set to -25mm, and Individual mode set to "comfort" suspension in the MMI but lowered 35mm via CETE which gives the same ride height as Dynamic -25mm. Comparing stock comfort mode versus my individual setting with comfort dampers and CETE -35mm, no discernable difference in ride quality at all. The only difference in ride quality is switching into Dynamic mode where the dampers stiffen up. I find the car still has tons of ground clearance, no less than my Tesla or any other sedan really, in dynamic mode -25mm / comfort mode -35mm. Hope that helps.
It does, thanks. So did you use a particular source for the CETE install instructions? No splicing or irreversible wiring involved is there?
When logged into a Europrice account you can see CETE documentation at the bottom of each CETE product page. Sort of a PSA as not all resellers have the documents publicly listed like this. If you need any help with the install don't hesitate to email: contact@europrice.us
Purchased the CETE from Martin @ Nemesis, he provided all the installation documentation. I also watched the video posted in Sam Adams' build thread, the video helped more than the PDF instructions. It was genuinely a simple install, a bit time consuming but certainly no special skills involved and no tools required other than zip ties and wire taps the kit comes with. Actually I did use a straightened out coat hanger to assist with fishing the wires up through the grommet under the trunk floor, if you consider that a tool.
Connecting to the pair of canbus cables in the trunk was done with high quality wire taps provided in the CETE kit. Clean and simple, no actual wiring involved. The canbus wires are 'right there' when you take the side panel off in the trunk, no hunting around for them or mistaking the wrong wires.
I'm trying to decide if I want these RS replicas in 21" to replace my current 21's...they will be 21x9.5. I have Dew silver with black optic...so the black inside needs to be gloss to match.
