0-60 time
Old 02-18-2014, 01:17 PM
Go123's Avatar
Default 0-60 time
Audi states the 0-60 time on the 3.0 TFSI, is 5.3 seconds. Has anyone been able to achieve this. The best I can get is around 5.8 with dynamic and ESC off and using the parking brake on to start, creating a quicker launch. Any suggestions to get their stated time which is typically higher than actual.
Old 02-18-2014, 01:21 PM
Go123's Avatar
Also I am using the dynolicious fusion app for my times.
Old 02-18-2014, 01:39 PM
q5q7's Avatar
just some numbers:
2012 a6 3.0
car & driver 5.1 secs
motortrend 4.8 secs
it depends on elevation, octane, road surface, whether you brake torque..
Old 02-18-2014, 02:01 PM
Go123's Avatar
Originally Posted by q5q7
just some numbers:
2012 a6 3.0
motortrend 4.8 secs
So what Audi states is not just WOT, but tweaking the start, brake holding until higher revs, maybe minimal fuel and higher than 91 octane and traction off?
Old 02-18-2014, 02:54 PM
Banned
in2dwww's Avatar
...tire pressure, vehicle weight, ambient temp, also play a role in 0-60 times. Did you turn off the A/C? Do you have the MMI off as well?
I recall Top Gear stating they did two laps of the track in the new VW golf. One lap with the Sport button engaged, and one lap without. The lap without was faster.
Old 02-18-2014, 03:34 PM
Banned
Mike_L's Avatar
I got 5.8 by just nailing the throttle. I'm sure I could get sub 5 if I tried. Supercharged vehicles are very finicky. If everything isn't perfect, they're much slower than they're capable of. If everything is just right though, they'll reward you.
And of course with the Piggyback I got mid 4's by mashing the gas.
Old 02-18-2014, 08:03 PM
forza1976's Avatar
You still enjoying that tune Mike? Any plans to hit a drag strip when the weather is acceptable?
Old 02-18-2014, 09:23 PM
Banned
feralc's Avatar
My car does 4.13
I am sure my car did closer to 5 seconds when it was stock, I live at sea level though
Old 02-18-2014, 09:24 PM
HaveBlue's Avatar
I was eyeing the Chipwerke box too since it is removable. I'm guessing it modifies the bypass. I think it was Mike's review previously I read. Wouldn't mind bumping the speed limiter too but the Simos box doesn't seem to play nice with Unisettings. Kinda silly when a 25-$30K Hyundai will go 150mph. Then again the Stasis warranty is probably worth the coin from everyone I've seen who has it. FYI VCDS has a 0-60 and 1/4 mile routine if you happen to have it. Just need some empty road... That seems tougher to find.
Old 02-19-2014, 06:06 AM
dicktahoe's Avatar
"I am sure my car did closer to 5 seconds when it was stock, I live at sea level though"
I understood the Supercharger helps the engine maintain Sea-level HP at high elevation--6,000-8,000 feet. Am I missing something?
Quick Reply: 0-60 time
