2012 a6 3.0t break and rotor change
i have 2012 a6 3.0t what are diamaters of rotors
i am looking at these
2012 Audi A6 Quattro Premium Cross-Drilled and Slotted Black Front and Rear Brake Kit
from BrakePerformance
i went to napa and he was ask which diameter is mine and i did not so tat is the reason i am reserved to buy these on line because i do not know diameter
Kit
LIFETIME WARRANTY, USA MANUFACTURED and GUARANTEED FIT. Includes Premium Semi Metallic or Ceramic Brake Pads. With 345mm Diameter Front Rotorsi went to napa and he was ask which diameter is mine and i did not so tat is the reason i am reserved to buy these on line because i do not know diameter
Your fronts should be 356mm. The 345mm is for the 2.0T. If you want some drilled and slotted for an unbelievable deal, Powerstop rotors on Amazon are currently on sale, $100 cheaper than I paid for them 6 months ago:
EBR1206XPR 356mm Front Rotors: EBR1209XPR 330mm Rear Rotors:
You can also find them at Rock Auto, which has the rears for about $30 cheaper right now.
Great info on the Powerstop links
Would a 2014 Audi A6 2.0T with the 20" sport tire factory option have the standard 345mm fronts or the larger 356mm front rotors?
Audi A6 2009 A6 front and rear rotors
Thlemons
06-04-2015 02:53 AM
Just to confirm, on '01 A6 2.7T Quattro i have the 8-pad HP2 caliper, 321x30mm rotors and 16.7mm....
brat2.ua
16
10-14-2008 09:43 AM
fehong
02-16-2006 06:53 AM
yrk2.7t@curbside
9
08-10-2002 08:55 AM
