2013 S6 Tachometer/Speedometer lights
The S6 (probably A6 too) has lights around the tachometer (RPM) guage that light up when you turn on the engine. The red line is also indicated by these lights - the red line is dynamic and moves based on the engine temperature.
Question - in various videos of the S6, I've seen the speedometer guage also light up when the engine is turned on. But on my S6, I see not such thing - the light don't come on or there are no lights. Is that normal?
I know BMW's have lights around the speedo to indicate cruise control speed...are these lights a feature with the adaptive cruise control only or something?
Not sure what you mean about no red LED sweep on the speedometer. Your video shows it does both, exactly like mine after the Vag-Com sweep flag is set on my A6.
Yea that's an S6 video someone posted on youtube...my A6 does only the Tach LEDs, cool that yours does both. In the VCDS software, I checked Needle test active to get the needle sweep...but unless there's another setting to also get those speedo LEDs, something is different between our cars.
Adaptive Cruise Control is required to get the lights around the speedometer, the rpm lights are on all A6/S6 sd far as I know as long as they have the 7" color DIS.
