2014 Steering Problem
Old 06-15-2013, 07:27 PM
  #11
snagitseven's Avatar
Originally Posted by u2jrmw
Oh boy. I am just about to close on a low mileage 2013 A6 that is half way across the country. I am not going to drive this car before I buy it, so this steering thread has me freaked out a little. It seems it is widespread and without any real pattern on packages, is that fair?
Some of you here will just be pleased I finally found a car to buy, and I am really excited about it, but now I am worried what I am getting even though it is a CPO.
If you haven't done so already, please read my post #7 and stop worrying.
Old 06-16-2013, 07:12 PM
  #12
Bob Petruska's Avatar
Default 2 steering rack versions were used in 2013
the latest and current 2013 steering rack came out in Jan. 2013, so yes there may have been a mod done a few months ago and this is why some 2013 owners may have the problems and others won't. The latest parts list for 2014 models indicates that this same Jan. 2013 rack is being used.
Old 06-16-2013, 07:17 PM
  #13
Go123's Avatar
Do you know if the 2014 has any new parts in general, or is the build basically the same as Jan 2013 with some updated software.
Old 06-17-2013, 03:59 PM
  #14
Default Probably the same steering rack system...
If any changes are made Audi would have given it a different part number. They sure wouldn't want to go backwards in performance by puting in a steering rack that made things worse if a rack replacement would be required at some pint in the vehicle's future.
On the issue of the problem steering, it really looks like a software issue. Search the web carefully and you will find a post were creative individuals disabled a portion of the steering code settings using a VAGCOM and the problem went away. I read many years ago where Audi/VW were developing the electric assist steering and in doing so were going to also use it to help individuals in a slide/skid, etc situation get out it easier by nudging the steering wheel in the wrong direction that would force the driver by human reaction to respond with steering wheel input in the other correct direction. This auto correct now seems to be overly sensitive in any driving coditions from cross winds to rutted roads. I'm sure the Audi engineers can eliminate this autocorrection feature in 1 minute to make drivers happy, but they also probably want to keep this safety feature and looking for some middle of the road compromise.
Old 06-17-2013, 07:31 PM
  #15
Bob, If it was only a software adjustment that could be corrected in one minute, I'm sure someone would would have reported a fix by now after several months of Audi recognizing the complaints. It could very well be something more than just a simple software fix. My service manager is still waiting for something to come down from AOA. Thankfully, so far at 11K miles, my steering issue is very mild in comparison to some other folks.
Old 06-17-2013, 08:57 PM
  #16
Default Read this post
All the way through....
http://www.audizine.com/forum/showth...es-VAG-COM-Fix
Old 06-17-2013, 10:05 PM
  #17
DeerHunter's Avatar
From memory, it seems that the referenced fix works for the A4 but not the A6 (and, in fact, causes major errors on our cars).
Old 06-18-2013, 05:28 AM
  #18
I participated in that audizine thread. I also started this thread:
https://www.audiworld.com/forums/sho...light=steering
and this one whereby, as Deerhunter recalled, does not work for C7s - lots of issues making that Vag change.
https://www.audiworld.com/forums/sho...1#post24428500
Read all the way through.
Old 06-18-2013, 05:59 AM
  #19
Go123's Avatar
It sounds like it is a mechanical and software issue.
snagitseven, which rack does your 2013 have?
Does anyone with the newer steering rack have any issues?
Old 06-18-2013, 06:10 AM
  #20
I have no clue - I had one of the very first 2013 A6's. Wasn't even aware there was a "new" steering rack, if indeed, one really exists. If this is a fact, what is the documentation, different part numbers, etc.? What is the source?
Quick Reply: 2014 Steering Problem
