A6/C7 air filter change?
New member here and proud owner of a 2013 A6 2.0T, have about 25k miles on it and want to swap out the engine and cabin air filters.Sadly can't seem to find the instructions for the C7 for this anywhere, esp. the engine air filter.
If someone has done it and can post instructions and/or link to them, that would be greatly appreciated.
Thanks much.
Thanks much.
Thanks much.
Thanks much.
The cabin filter is accessed under the glove box - you can find a video on youtube that shows how to do that.
You may need to search in google but it doesn't come up for the C7 when I took a quick look.
Thanks: I understand Audi's official recommendations but an air filter is something that can be beneficial is changed more aggressively, thought not sure if I want to pay the stealership to do it.
The engine air filter video/instructions for the C7 is what I am looking for mainly.
On a side note, does every follow the 20k mile oil change interval recommended in the manual? I got my first one done at the stealership for free at 5k per the book abut at 16k, decided to get a full synthetic engine oil change, along with life-time wheel alignments and rotation at a local shop. Probably going to do the next one at 27-28k.
This video shows a C7 cabin air filter to be in the engine compartment. There may be two.
This video is for the A6 C6 ... the C7 should be similar.
I saw the one for C6 tdi earlier but the one in my 2.0T tfsi (gas/petrol) unlike the diesel shown above is significantly different, for one I cannot see any visible clips around the section like in the above video.
Don't have a video to share, but I have changed engine air filter myself. The key is to remove the air pipe coming out of the engine. There is a o-ring tighten the pipe with robber hose coming out the engine. Loosen the o-ring allowing the air pipe to disconnect from the robber hose. On the other end of the pipe, press the tab to allow it to rotate off the air box, and pull the pipe out with the air filter. After 25K, my air filter was pretty dirty.
Where did you get your alignment done? I have asked my local Firestone if they can align Audis but they haven't been able to answer. Wasn't sure if there was anything special about these cars are not. Also, my Audi dealer has been on me to change out my cabin filter. I just can't justify the labor cost.
