Adding engine oil
I had to add 1qt of oil twice now. The car has 16K miles. I've owned it for the last 5K miles. The second time it asked for oil was after 2K from the oil change. How often do you need to add oil? If you had this issue fixed by a dealer, what was the repair?
Car: 2012 A6 3.0 P+. Comments from same engine owners are appreciated. Thanks.
I am wondering if people with oil issues, how many owned their cars as ordered new virgin cars, or off the lot cars with literally no miles on them. One thing I noticed when I was test driving A6s was that most sales people would start a cold car drive off the lot and mash the pedal to impress on me how powerful the car is. They is absolutely horrible wear and tear on a new engine. Then the test drive is sometimes short so they get in a cold engine, rev it up toward red line then before it has had any length of time to run at operating temperature the car is back and turned off. This is one reason I never buy a car with more than 20-25 miles on it, and seeing as my ordered A6 arrived with 19 miles on it I would feel good with any lot car with under 25, meaning it has not really been driven. My car has 300 miles on it and I have been driving like granny until the car is up around 600 miles, I have done this on every new car I have owned and never had an oil issue.
12k miles now, no oil added between the regular changes, less than 20 miles when I got it, easy until 1000 miles and then normal driving (no high revs until warm), 60% interstate, 40% suburban
Snagitseven, the message on the dash lit up asking to "add 1qt of oil, but safe to continue driving". I park in the garage and the floor is clean from oil stains, so maybe it's not a leak.
Would you wait another 2K-3K miles and see if the car requests another quart and then take it to the dealer or would you take it now? I am just afraid to have the dealer re-work the engine and screw something up in a different place.
My concern and reason to take it the dealer is that if the car is screwing up and telling you to add oil when you don't need it you could have unknowingly overfilled it and this could lead to problems. On the other hand it could be that at the last oil change they didn't put enough oil in and the car was correct in telling you to ad oil. This happened to me years ago when I had a Nissan. The dealer subsequently found out that the equipment dispensing the bulk oil was giving erroneous readings.
1) The car was asking for another quart of oil approximately every 4000 miles or so. Covered under TSB 2030197/10. The fix involved replacing the breather assembly and installing new gaskets and seals, updating the ECM programming, and doing "oil test part 1." This was apparently a complicated fix that involved removing and reinstalling the supercharger.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
