Adding S6/S7 rear valence and quad tips
Old 04-01-2014, 05:42 PM
  #51
Banned
Mike_L's Avatar
Its ridiculously overpriced. The C6 ones are like $200, and the C7s are 3 times that. Thats why I said "screw it".
Old 04-03-2014, 07:23 AM
  #52
2008A6's Avatar
So, i thought I saw someone recently post that the C7 A6 muffler does not have that plugged second exhaust opening for the second outlet the way the A7 muffler does. This would require a different mod (single pipe to twin tips) from the A7 where you can have 2 pipes coming out of the muffler.
Has this been confirmed that they are in fact different?
Old 04-03-2014, 08:09 AM
  #53
DB22's Avatar
I have looked at my 3.0T and a 2.0T A6 and they both have a muffler with a single offset outlet. Equally offset, on the other side of the muffler, is a flat round area where the second pipe would be. I plan on cutting out that second hole, adding a stub and then adding the second tip to the new stub.
Old 04-03-2014, 08:36 AM
  #54
Banned
Mike_L's Avatar
I was just gonna use these. Much easier than making a hole in the muffler.
http://www.ebay.com/itm/Exhaust-Tips-Audi-A6-S6-4F-A4-S4-Endrohre-Auspuff-Exhaust-Trim-Duplex-links-/371034456976?pt=Motors_Car_Truck_Parts_Accessories&hash=item5663608390&vxp=mtr
Old 04-03-2014, 08:46 AM
  #55
DB22's Avatar
Exhaust Tips Audi A6 S6 4F A4 S4 Endrohre Auspuff Exhaust Trim Duplex Links | eBay
Good idea Mike because I'm not sure how boring the muffler would change the sound.
Old 11-15-2015, 10:03 AM
  #56
Carr04Avant's Avatar
Mike, curious if you ever went with this product, vs cutting out the second muffler exhaust blanks. Thinking about going this route, unless cutting the second openings has a positive change to the stock exhaust note....
Old 11-15-2015, 10:24 AM
  #57
may try to go the honeycomb route if I can find it for a decent price.
Old 11-16-2015, 12:05 PM
  #58
08A6's Avatar
There are some folks on here who have simply cut out (widened) the opening in the stock S-line valence to allow for the quad tips, looks exactly as you have pictured here.
Old 03-30-2016, 07:16 PM
  #59
Sport Line's Avatar
I did this mod when I had a a7 and it was a terrible idea! Opening that sealed stub will give the worst drone possible! It's just simply underivable around 1600-2500rpm on higher gears and that's where the a7 supercharged stays most of the time on regular driving, city or hwy. It looked good , especially because I did the carbon fiber rs7 diffuser with oem tips , so I keep the double pipes look but one only remain opened . For sound improvement and a bit better exhaust flow resonator delete it's the best mod ,if you don't want to change to much of the oem set up
Old 05-08-2016, 06:25 PM
  #60
mikaelehenry's Avatar
Where'd you get the AWE exhaust tips (just the tips alone)?
Originally Posted by JerryS4
One more photo from the rear view, below. Yes they are a bit more out than the stock A7 ones but that is how I wanted them. Why hide when the AWE tips are AWE-some. This is my version of the S7 so it is less than total stealth mode.
While getting the tips done, I noticed that Ross-Tech was in Lansdale, PA and only 10 minutes away. I drove over and they did me a big favor and enabled a few VAG-COM codes: engine start dials sweep, gear indicator and remote window open. Great guys there.
Quick Reply: Adding S6/S7 rear valence and quad tips
