Anyone know what might be causing this fault?
Code:
Address 46: Central Conv. (J393) 1 Fault Found: 03637 - Roof Electronics Control Module; Function Limitation due to Overtemp 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 2 Reset counter: 148 Mileage: 27701 km Time Indication: 0 Date: 2015.09.02 Time: 13:51:42
I've cleared it once and it came back immediatly.
Any ideas?
Code:
Any ideas?
Is the car still under warranty?
If you have the VCDS cable, perhaps you can check the temp sensor's accuracy after it has been sitting overnight. That sensor should be reading very close to ambient temperature.
I've had this fault code show up consistently for 3 years since when the car was new and the sunroof has always worked fine in all conditions. My service tech, who often sees this code, attributes this to an overly sensitive sensor and not an issue with the motor. When I run a scan, I just ignore it.
A modern cars have digital networks, there are many errors that occur simply from starting or operating the car. The software is designed to log but not report many of these minor errors or you would constantly see warnings on your instrument display.
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
Aman Singh Parhar
11-29-2016 05:03 AM
