AU: 3.0T fouling spark plug
Hi all,
The story goes like this. I decided to change my water pump, thermostat and PCV. Not without its complications, though eventually got it done. Probably 100km in, my car starts misfiring in Cylinder 3. I found the spark plug was wet and fouled, put another plug in to see if it was possibly an accumulation over time thing, well, 30km later, I found out it wasn't as it began missing again and the plug was wet. Here is the interesting point...
The car was running fine, no issue whatsoever, then bam, misfiring and EPC mode. My research said it is either my injector or coil pack, so I switched my coil pack to another cylinder to see if that spark plug fouled next, but no, 40km later, no issue presenting in driving or on either of the two cylinders spark plugs (the main suspect one and the one I moved the coil pack onto). So I have some sort of intermittent problem and am lost. If it were easier, I would swap the injector around, wondering if this might resonate with anyone?
Thanks
Thanks
Kcoyne6673 (02-19-2022)
Leaking supercharger intercooler. Not really common but I have seen and heard of it happening. The intercooler is built right into the supercharger. You can remove the supercharger and pressure test the intercooler with a garden hose.
UPDATE:
So I have had the 3rd cylinder plug fouling a few times, no pattern. I change the plug, sometimes get a few hundred or even more. Then the first cylinder plug started to foul here and there. Just today, 1st and 2nd cylinder. Changed my plugs over, a tonne of grey smoke coming out of the exhaust.
Here is the video
I am now thinking I should mention. When I first installed my intake runner flaps, I forgot to spring them back and had them trapped and drove the car a bit like that. I am now considering the possibility it is related, as I can't think of anything that was obviously out of place when I opened it back up.
vulcan46@earthlink.net
40
08-12-2022 08:10 PM
nazTT
07-30-2001 08:58 AM
