Audi A6 C7 2013: TPS Fault, Parking Brake Fault, Start-Stop System Fault, ESC/ABS Flt
![](https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/227862c9_e930_443f_89e4_ea3da230f4eb_dfd81d80e519f0b82aa62b21af604e40297e6bea.jpeg)
![](https://cimg0.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/4804de75_fda3_456a_af08_e397c508aaef_72ddfdf0ac09a88070b9d67a67167a06d2f448ed.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/fa075f57_68d5_466d_a6dd_4d19a69e7be8_2a0ddab603b64d6d415fd479200469d1f05e984a.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/9d61b63a_8878_432f_a9fd_5f675f639a14_187105f075f7fbb094981cd364d2e5c4fafa5b1d.jpeg)
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/8ee26b02_f154_4ab3_813d_f2e6c6489736_ed8d069e9a1c3725106240a13ff72899d2934af2.jpeg)
Hello,
Last night I was driving and these errors came up.
As you can see in the pictures there are 4 errors.
I have had this issue exactly one month ago, but I turned off the car and they went away, no issues after that. Then, a week later, they came up again, and I did the same thing, which “solved” the issue. However I have decides to put the tester on the car and see what’s going on and these 4 errors came up and they were “intermitent” issues, which I guess it means that they don’t show up all the time in the dashboard. I have erased the errors and everything was fine until last night. I’ve done the same thing of turning off the car and start it again which made the errors go away. However this moring they showed up again so, again the same turn off and on story.
My question is what actually makes these errors to come up? Someone told me that it might be a sensor that makes the system go nuts. Considering that these are intermitent errors there must be an issue somewhere with a sensor that must be changed considering that erasing the errors didn’t really do anything.
Some other things to mention about the errors:
-The parking brake does hold the car but when I press the clutch in, go in 1st gear and lift the clutch just a little bit, the parking brake deactivates. And there are times where it doesn’t do that and it basically holds the car. It seems that it works as an auto-hold most of the time now.
-The stabilisation control really is off, I did a small launch and the wheels spinned, but after I turned off and on the car the stabilisation control was back on and when I tried to spin the wheels it didn’t allow it, which is good.
-I have no idea about the TPS and how it really works and what it actually means. I only know that it tells me if a tyre is underinflated.
-The Start-Stop system works fine after the turn off and on of the car.
Sorry for the long post but I could really use some help and opinions.
Thank you
The following 2 users liked this post by Daniels097:
garethgill (01-14-2022),
Johnny close 36 (10-10-2021)
Is your car on its original battery? The C7 is very sensitive to battery condition and in most cases random and intermittment errors like the ones you are showing are down to the battery starting to fail. Would suggest getting the battery properly tested as a first step
goca17 (10-05-2021)
I had the same problem 2 years ago. An independent in the UK diagnosed speed sensor failure in the wheel bearing. If you think of all the faults listed they relate to wheel rotation. A good diagnostic tool should tell you which wheel is affected. It may be the rotating part of the bearing or the electronic speed reader..
John.
John.
Hello,
Thank you
Teddys55 (01-10-2022)
do u have any pics?
This can be caused from the connector on the air mass filter when you disconnect this plug all this problems can appear if the connector wires are loose or fried can do the same check for this connector
