Audi Drive Select (ADS) Summary
Note: also see post #14 for some clarifications..
I responded to someone who asked about how ADS works in another forum and thought it might be useful here as well, particularly for newer owners.
In a nutshell (for non-active suspension models) - applies to most U.S. later/current ADS equipped models:
The ADS has four driving modes in the MMI:
Comfort
Auto
Dynamic
Individual
The first three automatically set software directed maps for the throttle response, transmission gearing, steering effort, auto cruise control (if equipped) and seat belt tensioner. Individual allows for setting each of the those parameters to Comfort, Auto or Dynamic mode.
Modes
Comfort will provide for best fuel economy and smoother driving by changing upshifting gears sooner/downshifting later, a more sedate throttle response (more travel to the gas pedal for a given amount of gas if you will) and a lighter steering effort. Also a more "relaxed" seat belt tensioner. (See below for ACC).
Dynamic will provide a sportier feel by holding in each gear longer, up or down, spoitier throttle (more fuel applied for less pedal travel), a greater steering effort and a more aggressive seat belt tensioner. (See below for ACC).
Auto will vary somewhat in between the two modes above but note that in all modes, the parameters will vary in a predetermined amount depending on driver input, speed, etc..
Individual can set the parameters of each of the ADS Modes above to taste.
Cars equipped with ACC (Automatic Cruise Control), the Comfort, Auto and Dynamic settings will determine the rate at which the car will speed up or slow down as the detected car in front changes its speed (and based on the ACC distance setting on the steering wheel stalk). ACC can be set in the Individual mode as well.
Note that the D/S selection on the gearshift lever will override ADS settings, i.e. D=Auto and S=Dynamic modes for throttle and gear mapping only; ACC (if equipped), steering and seat belt tensioners remain defaulted to the ADS setting in the MMI. (There is no difference for throttle and gear mapping in D or S from respective Auto or Dynamic settings in the MMI).
Audi S models (and many models in ROW) may include additional ADS settings (adaptive suspension for example).
Final note. Sometimes you'll read in the forums that in S mode or Dynamic that the car is faster than D mode, Auto or comfort. It may seem faster but it's actually not so. There isn't a magic, hidden extra 50 HP with S or Dynamic modes (which would be nice but..no). Because the gas pedal is more sensitive to input, it provides more gas if the pedal pressed the same amount as in Auto or D modes making it appear faster in less than full throttle acceleration. If you are in any mode and you floor it off the line all the way to 70 mph, the elapsed times will be the same. Full throttle when the gears are not shifting until red line overrides any ADS or shifter mode.
Comfort
Auto
Dynamic
Individual
Modes
Regarding the "feel fast" I think is fair to say that IF the car shifts quicker in S the car is accelerating faster through the gears, maybe not in just one of them (not hidden horsepower) but a 0-100mph run will be slightly faster in S than in D, this of course if the transmission does shift faster in S vs D.
According to ZF website the transmission is capable of 200 milliseconds shifting, I do not know if that applies only to Sport or D does the same too.
http://www.zf.com/corporate/en/produ...enjoyment.html
D=Auto and S=Dynamic? as I see it is S=Dynamic/Sport and D=Non Dynamic/Sport (Auto and Comfort)
As to D=Auto and S=Dynamic for throttle and gear mapping, "Sport" or S mode is the same as Dynamic. It's semantics; S means Sport on the shifter but functions the same as Dynamic for the two parameters mentioned. D mode is the standard Auto mode which in one moment could be close to Comfort or close to Dynamic depending on how the car is being driven.
Bottom line, I stand by my statement that, all conditons being equal, if the car is under full throttle, pedal to the metal, there will be no difference in elapsed times in any selected mode. Time it. I have several times as I was unsure if there would be a difference. There wasn't.
Davidj22 (02-18-2020)
That's what I was trying to get across. Press the gas pedal halfway in Comfort/Auto/D mode, the car gets "X" amount of gas. Press the pedal halfway in Dynamic/S mode, the car gets X+ amount of gas. Press the pedal to the floor and the car gets the same max amount of gas possible regardless of mode selected. Outside of full throttle, It's a matter of pedal travel "sensitivity", if you will. The amount of throttle variance between the different modes decreases as pedal travel is increased toward full press.
Feralc, please reread my summary. I didn't say the gears shift faster in S or Dynamic, I said they hold longer in gear than Comfort/D mode. So, what I wrote in my summary is correct - gears shift later, not faster or sooner than Comfort or Auto. Your link speaks to the ZF transmissions ability to globally change gears faster but that is not what I was writing re the ADS modes.
On the other point I never implied you said it shifts faster in Dynamic, but I am wondering if this is indeed the case, maybe S/dynamic does shift faster than D, I know some other gearboxes do according of how much throttle you are giving.
Having said that MAYBE the 200 milliseconds shifting is capable only when the car is S vs D, we have to ask Audi or ZF
Also see the attached PDFs. Note that a lot of features are not available on US A6s such as the air suspension, dynamic variable ratio steering, the sport differential, and Efficiency mode (but can be enabled through VAG-COM). So out of the three features left on my 2.0T Premium Plus, the only difference between Comfort and Auto is the steering effort.
The engine (gas pedal response) and the transmission are actually the same in Comfort and Auto modes. The transmission will be in 'D' mode for both, but it still varies the "Dynamic Shift Program" depending on lots of factors like hills, cornering and driving style. Apparently there are up to 256 shift maps and the one being used at the time can be read using VAG-COM. See this webpage: http://www.audipages.com/Tech_Articl...nsmission.html
That said, perhaps you're right and I'm feeling a placebo effect but I sense a slight difference between Auto and Comfort (beyond steering), albeit less noticeable than compared to Dynamic mode. I'm not certain if the maps are in a range from comfort to something in between Comfort and Dynamic or employs settings in the middle (I suspect the former).
I guess the big question is, if there is no difference for the most important two performance categories, why does Audi have an Auto mode at all? Why not just Comfort and Dynamic and if steering is different in Auto mode, let it be adjusted separately through the Individual mode as it is now? I'm going to continue to dig deeper on this one.
BTW, I did mention in the summary it was for U.S. versions and that there are other ADS features available in S models and ROW. While I'm aware of the Efficiency mode, I wanted to stay with with U.S. stock settings and avoid Vag-Com mods that perhaps might confuse new owners.
