C7 A6/S6 - Where can I plug in my radar?!
#11
it took me 15min to hardwire my V1. email me and I will give you details. super easy.
ellisina4@gmail.com
Yuri
ellisina4@gmail.com
Yuri
#13
I used a hard wire kit from www.safe-n-sound1.com on my DD.
I found them through a eBay auction and went to their site to see what their retail prices were before bidding. While I was on their site, I entered a monthly drawing and won. www.safe-n-sound1.com/Free%20GiveAway.html
The kit was all inclusive and their kits run from under $10 to under $20. They have kits for all the popular radar detectors. I keep the original power supply as a backup or for use in a different car.
#14
My apologies for poor markings on the pictures, but with 2 kids and a wife traveling constantly, not much time left for anything.
I think a picture is worth a 1000 words. Nine pictures are worth even more
First I tucked the V1 phone wire under the black headliner from the radar detector side to the driver’s side. You will have to pull headliner a little with a small screwdriver. And then just follow the dashed markings in the pictures. I simply tucked the wire under the weather stripping along the door opening.
To get access to the fuse box, pry open the fuse box cover with a flat head screwdriver (there is a notch on the bottom of the cover). As far as attaching the + wire to the power source, I remember I chose 40A fuse for a reason, I think that was a ignition fuse. This way V1 turns on as you start the car and turns off when you turn the car off. You can use a cleaner way to connect the + wire to the fuse, as described in the last 3 pictures, but I never bothered.
This is the same procedure as in my 2012 A6.
#16
That's one way to do it.
Although, it should not be necessary to run the phone cable all the way down to the fuse box. In my BMW 545i, I have simply tapped into one of the wires in my front dome light. You should be able to find a diagram with the color-codes for the wires. You just need to cut the sheathing on one of the wires that turn on/off with the ignition, and use the supplied splice caps that come with your Valentine 1. Takes all of 5 minutes to do once you know which wire.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
08-11-2022 06:51 AM
