C7: disable dual climate?
Does anyone know if it is possible to make the car act as one zone. The majority of my time in my car, is spent alone and I don't want to have to adjust two temperature ***** every time. I haven't found the button or had a chance to read the book, but I did notice a little black button next to the fan speed, I hope this Is what I'm looking for.
Thanks
Thanks
Hit "SYNC" make sure red light comes on
Do all adjustments from driver's side temp control - in 4-zone prestige car, all zones will follow driver's side with the sync enabled
On my Q5 I push in (and hold) the **** that sets the driver's temperature. After about 3 seconds of pushing and holding n the **** the other zone would switch to the driver's temperature and be "synched" with the driver's zone. Then any change you make to the driver's zone's temperature will also change the temperature for the passenger.
To get it out of "synch" mode, you would just turn the passenger temperature **** to a new temp and then the two zones would act separately again.
my guess is it will be similar in the A6. Let us know if it works.
