Can't open fuel lid
Hello.
I have problems opening my fuel lid, it's about -10 degrees here in Sweden.
It seems locked, I've tried open it from my trunk (the red wire) and I still can not open it.
So, what is the problem when I can not open it with the red wire? I thought that was for emergencies so it would always open the lid.
Can the lock be frozen and that's why I can not open it with the wire, or something else?
Any other suggestions? I've unlocked/locked the car multiple times while also pulling the red wire and knocking on the fuel lid.
Greetings.
Greetings.
I recently had the same issue too, just to clarify the red string does not POP up the fuel lid but disengages the lock, so you do have to press on the lid to open it. So pull the string with enough pull, and then press on the lid to open it.
To get the assembly out you do have to partially damage the plastic piece that is around the gas tank neck. You have to break the rubber tabs and use a screw driver to release the internal tabs. I used a plier and pulled on the damaged actuator that released it partially and then i had to break one rubber tab to release the other tab.
The actuator failure is a known issue with audi/vw and other brands under the umbrella of vag.
May need to get to it from inside the trunk - doesn't hurt to try it in warmer area, let the car sit inside a warm garage for a bit.
Hello.
Greetings.
Greetings.
There is a youtube video with someone doing this with an A7, i would suggest you watch it before you change this yourself.
I followed a suggestion by a member here to pull the broken actuator and pry it off but i was not fully successful and broke the actuator, but in the end it worked out.
Well documented problem and pulling the red wire will not help as that is to release the central locking pin and the problem you have is that the pin that secures the flap is supposed to rotate when you release it and it stops doing that. I have had this happen on both my current and previous C7 and Audi has an official repair kit for this. Only solution (and this is what Audi Assist did when I called them out) is to insert something, ideally plastic between the flap and the bodywork and carefully force the flap off the locking pin. Once it is off you can then refuel but you will not be able to secure the flap. Requires a trip to the dealer who will then replace the accutator. You don't say how old your car is but I would expect Audi to be sympathetic to you if your car is out of wearranty as it is clearly a known problem.
Best,
Jeff
Can't get a password
01-27-2019 05:56 PM
seanwg
09-19-2009 04:32 PM
defenseman
10-09-2005 09:20 PM
EddieG
03-16-2003 10:50 AM
