Control unit not responding, ODBeleven
Has anyone else had this problem? I can't get past this error so I won't be able to enter the new battery code.
I just got this reply from ODBeleven support:"February 12, 2019, 08:26 +0000Hello,
this control unit does not exist in the car. Can't be accessible."
My 2013 per VCDS has a "Battery Monitoring Control Module"
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000761197
Coding: 00C1032900
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 71BCDDEC9126DA6FD27-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000001050618393
No fault code found.
Coding: 00C1032900
Interesting reply. I thought that it was in there. I wish they would have explained it a little better, maybe it is only for certain years. I have an Autel MK808 and it says it can program the battery for the car, including a 2012, but of course it doesn’t show what the process is that it uses.
I did get more of an explanation from them but it didn't help much.I believe you. But the thing is that the application didn't found this control unit in your car. Have you tried to perform the full scan?February 12, 2019, 13:03 +0000I have the Audi A6 prestige level trim with the 3L supercharged engine.
Every one of those cars produced that year has an energy control module to
regulate the power that comes from the battery and all of the cars
electronics. Other Audi owners who have your hardware and software are
able to program the energy control module for the new battery. How do I do
that? What options do I select that will allow me to do it?
