Disable screen up/down motor
It would be very handy to be able to prevent the screen from going up and down all the time. When put away, it just pops right back up if you put it into reverse, adjust the seats, ...
Therefore I want to put a switch to disable the up/down motion of the motor. Basically I would just interrupt the circuit that feeds the motor power. That way if its up, it stays up. If its down. It stays down.
Does anyone have access to the schematics or wiring diagrams for the A6(C7)?
When I put my MMI screen down and out of sight using the button to the left of the air vents it stays down. I can go into reverse and it doesn't pop up to show the the image from the rear view camera. Likewise, I can adjust the seats and it stays hidden away. It has been like that since I picked the car up so I assumed that was a default setting. I really have no idea why you have the problem you decribe or what you can do about it. Sorry.
Mine also always pops up when I put it in reverse even after pressing the button but will slide down again once I switch to drive.
I thought this was default and can't be overridden even by using a VAG-COM?
Before ripping open the dash on my brand new A6
It has to be a DC motor and Audi reverses the polarity of the two wires to facilitate the open and close functions. There should be a limit switch at both ends of travel to open the circuit unless it is timed or it measures the amperage load.
With regards to "reverse being absolutely necessary". That's an example where I would rather have a say so in whether that makes it pop up. Also if I press a seat pre-set button, that makes the screen pop up to tell me all about what it is that button does.
I don't like it moving up and down unnecessarily. I feel like it will wear out after a while. But even if it doesn't, it still would bother me just as if say the windows were going up and down unnecessarily (or the engine shut off and turned on all the time
Certainly you have the right to be annoyed, but I could suggest a limited solution. Let the screen stay up and then it does not pop up and down when you touch seat pre-sets, put the car in reverse, etc. To be quite honest, I felt the same way initially but have learned to (forced myself to) live with it being up all the time. You need the MMI screen for Navigation, for the radio, for the phone, so why not leave it up all the time. I decided to think of it as a fixed, built-in screen that has the ability to be hidden once in a while. I am one of those “old school” guys who generally feel there is too much of the driving experience being taken over by the robots, so I do understand your concern. Give it a try: let it come up and stay up.
