Driver side noise - knock/grind
Old 02-02-2019, 05:27 PM
anon3000's Avatar
Default Driver side noise - knock/grind
2013 A6 Prestige, 55k miles on it now. This week started to hear a noise on the driver side, at first it sounded like something was loose inside the dash, or maybe the windshield (which was replaced 20k miles ago) was loose. Always well maintained, mostly highway miles.
Keeps making the noise even with pressure applied to various parts of the dash and windshield. Happens mostly in speeds under 10 miles an hour, maybe slightly more noticeable when on an incline or reversing down the driveway. Cars seems tight and handles fine. Don't see anything loose. I would characterize the noise maybe as a slight knock but at times there is a slight grind to it.
Anybody else with similar symptoms? I checked the cowl around the windshield wiper reservoir and everything is properly in place and tight. I would say definitely driver side, slightly lower than the steering wheel is where the noise originates. Don't notice it on highway speeds, but small speeds it is there, worse after cold start.
Old 02-03-2019, 03:45 AM
KevinGary's Avatar
Do you have HUD? It is a chronic noise maker on many of these cars.
Old 02-03-2019, 07:50 AM
anon3000's Avatar
Fixed it this morning. The metal cross brace under the front windshield cowl was loose, added felt tape under the piece that connects to frame and tightened all 5 bolts, one was finger loose.
windshield wiper reservoir was also flapping on top of ecu and ecu was not in the slots right, added thicker felt tape between reservoir and ecu, and re-assembled it all back. Noise gone.
the car was in for the fuel line recall and obviously
DFW audi did a really sloppy job on it
termite
Q7 MKII Discussion
13
05-05-2016 10:31 AM
wlaudi
Suspension Tuning Discussion
10-11-2012 08:52 AM
aj25
S4 (B8 Platform) Discussion
02-25-2011 06:13 AM
keithallis
10-05-2009 12:04 PM
tom nam
11-27-1999 06:45 AM
Quick Reply: Driver side noise - knock/grind
