When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I've seen a couple comprehensive hardwire install posts in the other discussion pages but thought I'd post this pic of the A6. The install was extremely easy. I opted for the home link wiring (Red/Black - positive and Brown - ground), using simple slicers. The cover off the ceiling panel comes off quite easily (I found its easier to pull off from the front) and only one hex screw holds the rest of the unit up. There's plenty of room up under the covers to stuff excess wires. I ran the 'phone line' power chord out the front underneath the roof liner and my detector is placed up high, just above the visor. The whole install took shorter than the time it took me to type this post.
Reason: Pic added
Hey Joe, I'm getting ready to buy this cable and install my V1. Do you happen to remember where (and which wires) you plugged the pins into please? Thanks in advance!
I do. Under my mirror, the plug from the top was the two wires in the upper left corner. They were directly next to each other. On my 2013 the brown is the ground, white and black hot (first pin upper left).
I did use a multi meter to determine what pin was what, I could not determine the colors easily. Also, you may have two plugs in the setup, I used the bigger of the two, probably 8 pins.
When I tried using my V1 in my 2016 A6 Prestige, I got alarms just sitting in the garage. Is the Audi Connect WIFI generating a signal that is confusing my V1?
It might be the side assist. If you have a newer V1, you can download the App and configure the V1 from your phone. Here is a video showing how to configure manually.
