When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I have a 2012 Audi A6 with only 45k km on it. I have an intermittent fault where the steering warning light goes on and the steering goes heavy. I was told that it's a fault with the electric motor on the Power Steering Rack. The problem is that the motor itself cannot be replaced and I would apparently need to replace the Power Steering Rack it self, which costs close to $3000 and takes a few weeks to get.
Has anybody experienced this problem? Is there an alternative solution? Is there a way to detach the electric motor from the rack to replace or even repair it?
Thanks thespeed. I did have a look at a few threads but none seem to fit my problem exactly. My power steering is not notchy, it either works perfectly or not at all until I stop the car and start it back up. I'll try to get the error code from my mechanic, but it had to do with intermittent failure of the electric motor in the steering rack...
I had a same problem about 1 year ago and covered with warranty. I heard noise when turn steering wheel then intermittent multiple warning lights but OK to drive to dealer.
My 2012 A6 just started with these exact symptoms for the last month. Were you able to resolve the issue and how?
The codes I'm getting are:
Address 01: Engine (J623-CGXB) Labels: 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0010
Revision: --H07---
Coding: 0A2A0032052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 275D2F895E81747988-8073
1 Fault Found:
15428 - No Communications with Power Steering Control Module
U0131 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 153450 km
Date: 2017.06.07
Time: 20:47:32
Engine speed: 694.00 /min
Normed load value: 10.6 %
Vehicle speed: 0 km/h
Coolant temperature: 95 °C
Intake air temperature: 56 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.015 V
Unlearning counter according OBD: 38
Engine speed: actual: 704 /min
T_AST_ENVD: 1053.70 s
Gear: 0
Engine: operating status: IS
Battery voltage: 14.015625 V
Vehicle speed: actual: 0 km/h
Readiness: 0000 0100
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BC HW: 4H0 907 064 BC
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 09883006000000000000
Shop #: WSC 02391 785 00200
VCID: 6BD513B98AE990192C-803F
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H39 0046
Serial number: 2311000227430005
1 Fault Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Mileage: 152571 km
Time Indication: 0
Date: 2017.05.30
Time: 17:10:32
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001308768
Coding: 06002091063C9FE08100088380003908CF9CD208A209012100 0004402000
VCID: 6ED31AADB9FB65310B-803B
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 111020 H35 0051
Serial number: 111028171706
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11789593
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 16 11 2011 00000786
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R0XB102
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: AB08CBD5000000000001
1 Fault Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 153450 km
Time Indication: 0
Date: 2017.06.07
Time: 20:47:00
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000315048
Coding: 00C1033000
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467C8C59F570FE13D-8061
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790141791
1 Fault Found:
4906 - Power Steering Control Module
U101D 00 [008] - No Communication
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 91
Mileage: 151470 km
Date: 2017.05.17
Time: 21:51:48
Voltage terminal 30: 14.0 V
Voltage terminal 15: 14.2 V
Control Module temperature: 37 °C
System status: Terminal 15 on
IN ESP_standstill flag: no standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Mine seems to be triggered by cold weather. I've experienced it once or twice since my original post (all good since mid-january). I've decided to report the repair for another year, hoping it will not happen too often and/or someone finds a better solution than replacing the steering column.
Can anyone help me with this error code. And if anyone know whats an issue where is the fault. Is it steering rack or anyother part which is related to steering rack.
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 K HW: 4G0 909 144 G Component: RCEPS H36 0009 Revision: 00001000 Serial number: 0006373750 Coding: 101000010000 Shop #: WSC 90001 790 00000 ASAM Dataset: EV_RCEPS 007007 ROD: EV_RCEPS_007.rod VCID: 3169A0C36029530EB4-8064
i am going through the same issue. you can buy a steering rack for way cheaper online than the 3000 that audi charges and take it to a mechanic that can do it and has the necessary computer to reset it. the only thing is it won;t be covered by warranty. the work and part.
