Fuel Rail/System Pressure Error
I ran a complete scan of my A6 and I found the below 2 errors. I've tried looking online but didn't understand them completely. Did anyone get these errors or know what is the fix for this?
I don't have an Check Engine light but when I read online, it said the below might cause Check Engine if not worked on.
2 Faults Found:
6237 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 107760 km
Date: 2019.10.27
Time: 18:20:43
Engine speed: 705.00 /min
Normed load value: 9.0 %
Vehicle speed: 0 km/h
Coolant temperature: 100 °C
Intake air temperature: 87 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.421 V
Unlearning counter according OBD: 17
Engine speed: actual: 672 /min
MAF_ENVD: 87.15294 mg/stroke
Coolant temperature (unfiltered): 100.50 °C
FUEL_MASS_REQ_I_CTL_ENVD: 34.546875
FUP_ENVD: 40755.5310 hPa
FUP_EFP_ENVD: 4773.4 hPa
16903 - Vapor Bubble Formation in Low-Pressure Fuel Circuit
P125B 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 107760 km
Date: 2019.10.27
Time: 18:20:43
Engine speed: 701.00 /min
Voltage terminal 30: 14.523 V
Engine speed: actual: 128 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 104.25 °C
Engine: operating status: ST
FUP_EFP_ENVD: 6819.14 hPa
Vehicle speed: actual: 0 km/h
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107760 km
Date: 2019.10.27
Time: 18:20:43
P125B 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 107760 km
Date: 2019.10.27
Time: 18:20:43
One may have caused the other.
Have you had this TSB done?
https://testing-public.carmd.com/Tsb...122031/A201796
"Intake air temperature is usually above 140°F (60°C) in the freeze frame data of the diagnostic log"
Yours is 87ºC so you are a candidate if you haven't already had it done.
I don't think this is done my vehicle yet. I'll call the Audi dealer to know more about this...
Since this is a TSB, they may not do it for free, which I have to check. Thank you for pointing
xandrevvx
A4 (B7 Platform) Discussion
07-18-2019 07:49 AM
WODT-Sanders
4.2 V8 Discussion
06-15-2019 07:46 PM
ceroberts75
03-10-2018 09:03 AM
