Has anyone installed a flat bottom wheel on their C7???
#21
Thanks, guys. With both of your thorough step-by-step explanations, I can picture how to do it before even attempting it. The only question I have is how do you do the reverse of the above steps when you're putting the airbag back on - do you just push the airbag and it pops in, or a screwdriver is necessary?
Some flat-bottom wheel may need different airbag, and the locking may be different?
#22
![EEK!](https://www.audiworld.com/forums/images/smilies/eek.gif)
#23
I've just purchased an RS7 3-Spoke for my A7 Premium (it currently has a 3-Spoke sports wheel). Were you able to reuse the airbag, or did you need to purchase a new unit?
If you needed a new airbag, can you tell me the part number?
Cheers,
John.
#24
Regarding whether you can reuse your airbag, I believe the answer is yes if you're moving from A7 3-spoke round to RS7 3-spoke round (North America version like mine), but no if you're moving from round to flat-bottom (based on what I recall in these forums from other's experiences).
#25
If anyone has a used C7 3-spoke Sport wheel w/airbag lying around that they've swapped out, please send me a note if you'd like to sell. I have the 4-spoke that i want to replace with 3-spoke. Thx
#27
Yes, I was able to swap it and it was fairly straightforward, thanks to the good guidance in this thread and a couple of others. I purchased an RS7 3-spoke wheel and airbag together (which was necessary since I was coming from a 4-spoke wheel).
You definitely cannot use existing airbag on a flat bottom upgrade.
Also, from experience, any recent flat bottom wheel will fit the A7, BUT the airbag is specific to the A7/S7/RS7 (I assume same as A6C7 but can't check) The airbags from other Audi models is NOT compatible as the multi plug connector, whilst similar is keyed specific to the model.
![](https://cimg7.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1124/airbag_53671a7a5d4fde8daf1291537f63f6f6dbc5ff0e.jpg)
Flat Bottom Airbag on the left, round on the right. Note different mounting systems (Pin on round, hoop on flat bottomed)
#28
Looks great. I concur with it being a simple DIY job.
One minor unforeseen thing in my swap job: My previous steering wheel was heated, and I apparently had the heat switched on when I removed it because now the car's efficiency meter thinks the heat is still on (even though my new wheel is not heated). There's probably a VAG-COM setting I'll have to change to get rid of that nuisance message...
#29
helix139
S4 (B8 Platform) Discussion
16
08-11-2013 02:46 PM
rkkolli
08-03-2004 10:23 AM
Mikey L
05-23-2004 08:01 PM
