hit pothole,got bubble, replaced tires. alignment needed?
I don't feel anything wrong with the tires now. No pulling, no vibration.
However for the sake of preventative maintenance, should I go straight to a dealer or a really good shop for an alignment?
How is our car prone to misalignment after pothole encounter?
How was your tire wear prior to the mishap? It takes a lot to knock these cars out of align.
called shop and requested the owner to look at my old tires. He doesn't see abnormal wears, there were about 50% tread left. So I think I should be Ok. Thank you guys.
https://www.audiworld.com/forums/sho...hlight=pothole
I hit a major pothole than not only dented my wheel but cracked it as well..It was about 2 feet deep I would say. Luckily my tire didn't pop and only have minor bulging, may even be due to the lack of sidewall support for the tire.
Either way I was worried I would need a realignment and I didn't...
Check out my thread and corresponding pic...
It drives laser straight, no noticeable issues with the new rim on...
These cars are rock solid...
If your remaining tires only have 50% of their tread left, and if you don't notice any pulling, etc., then I'd say absolutely do not spend money on an alignment now and just wait until you get new tires installed.
If you can't sleep at night worrying that something might be wrong, then take the car to some shop that gives free alignment checks and see what they say. WARNING: take a copy of your alignment specs with you to the shop to compare them with what the grease monkey says the specs should be, because invariably those guys put the car model into the computer wrong and come up with some wacky result.
Also, a lot of dealers have a "toe machine" in the driveway or service area that you just drive over to find out if your toe is off. I've found that most of the time if you go inside and ask nicely, they will be happy to let you drive over the toe machine plates and will generate a one-page printout for you.
N'Syncro
33
02-16-2020 03:12 PM
CPLYONS
09-07-2015 07:19 PM
stormchaser1967
09-02-2015 08:48 AM
