How to Defeat ACC Power-Off Timer?
Old 09-23-2015, 03:34 AM
subterFUSE's Avatar
Default How to Defeat ACC Power-Off Timer?
I have need to run my car on ACC Power for an extended period of time while connected to a charger.
However, when ever I leave the car on ACC Power the car eventually shuts itself down after a few minutes or so. I have not timed it, but it's probably about 20 minutes.
One thing I noticed is that if I open and close the driver door, it resets the timer. But if I leave the car alone it shuts itself down after a while.
Is there a way to override this feature, or maybe disable the feature in VCDS?
Old 09-23-2015, 09:20 AM
DB22's Avatar
With VCDS you may increase the delay to 30 minutes maximum.
Old 09-23-2015, 11:45 AM
subterFUSE's Avatar
Awwww man....
And there is no way to defeat it?
Old 09-23-2015, 07:51 PM
tenspeed's Avatar
Awwww man....
Put in a second battery and power your loads from it. Use a double pole switch so you can select Audi 12 volts or auxiliary battery.
Old 09-23-2015, 11:07 PM
subterFUSE's Avatar
How does that defeat the ACC Power timer, though?
The car is still going to just shut off after 20 minutes of inactivity, isn't it?
Old 09-24-2015, 04:13 AM
DB22's Avatar
Awwww man....
I do not know how to defeat the feature - sorry.
Where and what are you doing that requires the ACC on? If it's in a garage then with all of your audio gear in the car then surely you have audio in the garage too? If you have a charger plugged in then you also have access to AC power.
Old 09-24-2015, 07:47 AM
subterFUSE's Avatar
Installed new speakers in the car and need to get them broken in before IASCA/MECA Finals next month. Was hoping to run them in for about 100 hours, but I can't do it if the car keeps shutting itself off every 20 minutes or so.
Old 09-24-2015, 09:59 AM
DB22's Avatar
Pull the speakers out and run them on the bench.
You do realize that those speakers are only good for 100 hours don't you?
Old 09-24-2015, 10:05 AM
subterFUSE's Avatar
I don't have a bench with proper 12V power supply, nor do I want to pull the speakers and my amp at this time.
I'm not exactly sure what you are talking about?
The manufacturer specifically suggests a long break-in period for new drivers.
http://support.dynaudioprofessional....akers-in-means
Old 09-24-2015, 12:49 PM
DB22's Avatar
The guy selling the snake oil suggests running the speakers all night for a week. The power that you have will keep you and the neighbors up all night even at half volume.
I am open to new ideas but having worked in professional audio environments for over 40 years I am over the "Monster cable" bs and breaking in speakers is pretty close to the same hype.
I think that you have a great system and you should listen to it and enjoy it. If you can hear the difference after "breaking in" your speakers then you should be mixing audio for a living.
Quick Reply: How to Defeat ACC Power-Off Timer?
