I just checked my odometer accuracy
And the Odometer reads 2.1% low. In other words if I go 100 miles the odometer will show only 97.9miles. Looks like my warrantee will be good for 51,000 actual miles.
That also means that when you figure your MPG manually, your figures are off.
You may want to check your speedo as it is likely off too. Is there some chance that you changed wheels or at least tires since the car was new?
Usually if anything the speedo will read about 2mph higher than actual speed @ 70ish
.021 * 70 = 1.47 so he actually travels 68.53 miles in one hour but his speedo shows 70 mph, <STRIKE>or when his speedo thinks he's travelled 70 miles in an hour, he's actually travelled 71.50 miles (70 / (1-.021)), so almost the 2mph high you expected.</STRIKE>
Edit: boy I screwed that up
There was a time when odometers were not so tightly controlled, and often they would read higher than the actual mileage driven--which of course would negate the mileage warrantee sooner. I think the government stepped in and corrected that abuse by the manufacturers. Having an odometer read a little low, keeps the manufacturer on the safe side of the law.
I determined this error about 2 years ago on a trip from California to Virginia. In my case I came up with 2.5% error on the low side if using the stock tire size (255/35/20). When I use my 275/35/20 tires the error is just about 4.5% but my speedo error now is about 0.
Yes, with a "measured mile segment." Actually the segments along the highway I used were calibrated in 2/10ths of a mile and I went for a little over 5-miles. Sometime I'll try to check it over a somewhat longer distance.
