Keyless go not working on Audi a6 c7
Hi,
Yesterday i bought Audi a6 c7 2013 (model 2014) Prestige model and the keyless entry doesn't work. The keyless start is working perfectly but idk why with the door handles I cant lock or unlock the car. I have this kind of keys for my car: http://www.audicarkeys.com/wp-conten...ors-Opened.jpg
In the handles I have sensors (that little 1cm by 1cm square). I tried change the batteries in both key but still nothing and I tried open the trunk but nothing. With the key fob I can normally open, close or open the trunk just the keyless entry not working with any door. Can you have solution with my problem? Thank you very much and excuse my bad English!
If the car sits for a long time, it will shut down some functions, and that is one of them (entry via touching door handle). Usually, if that happens to me all is normal again after I start and drive it, which charges the main battery in the car. So, I would check that your main battery is good enough to hold the required charge so that the car does not "shut down". I think after 3 weeks my A6 will do this, it is still original battery, which I am pretty happy with, almost 5 years now.
There may be an MMI setting too, not sure.
Hi,
Also i don't recall but there maybe a setting that enables and disables the keyless function of doors.
I will check tomorrow.
Hi,
The following 2 users liked this post by John Simcox:
Gareth Luty (08-17-2020),
Milos Zivkovic (05-05-2020)
Look as per John Simcox's suggestion. My build sheet is near the spare tire.
I checked in MMI:
If you go to Car:
- Car Systems
- Vehicle Settings
- Unlock Doors.
Here you can pick either Driver or All doors for unlocking.
I thought you could disable keyless entry but i dont think you can.
If you go to Car:
- Service and Checks
- Programmed Keys
See how many keys show up.
I checked in MMI:
If you go to Car:
- Car Systems
- Vehicle Settings
- Unlock Doors.
If you go to Car:
- Programmed Keys
Do you have chrome strip on top of the door handle or is it all painted in body color?
All A6 door handle has that square touch sensor but I was told the one with keyless entry has chrome strip on top of the door handle.
Mine does not have a chrome a strip, it is painted the body color, and it does have keyless entry. Maybe that hold true for overseas, Non-USA, models???
the chrome is on the INSIDE as well as on the TOP of the handle where your fingers touch when you grab hold of the handles.
The Metal part i think is capacitive and thats how it unlocks the car if the key is nearby.
The chrome part is plastic too, capacitive touch doesn't need to be metal as the square lock touch area is painted plastic too
