Letter extending warranty for 2009-2013 3.0T engines? Not exactly..
#11
"Audi has determined that, under certain driving conditions, carbon buildup can occur on the engine cylinder head secondary air ports."
#13
I received my letter Friday and it mentions that the warranty extension is for the Emissions Control Systems and specifically for the engine cylinder head secondary air ports. I really have very little concern for this issue but if the problem should arise within this extended warranty period all the better.
#15
"If" your car has a problem, it's covered. Not much to worry about. How about the 4000 other things that could fail that wont be covered? :-)
Sorry , but life's too short
#16
For the life of me I don't know why unless you have enough good fortune to have nothing else to expend energy on.
#17
Several RS4 DIY'er have done both of the above with NO affect on the carbon build up as it still happened. A fuel system additive won't do anything as our engines are direct injection therefore fuel never hits the intake area like it did/does on port injection engines.
http://www.audizine.com/forum/showth...gathread/page3
#18
Read this thread. I have an 08 A6 3.2 and it suffers from the carbon build up issue. There does not appear to be a way to prevent it.
#19
I did a lot of reading on this issue prior to purchasing my A6 used. You could ignore it until it gets to the point of triggering a CEL for a poor cold startup. Then get the manual carbon cleaning done. It also seems that the other manufactures that utilize direct injection that don't have this issue also added a secondary port injector that still washes the valves.
What doesn't make sense though is how this issue still cannot be designed around 8+ years after direct injection has been around with a better designed crank case ventilation system.
#20
Received my letter today.
Since my intent has always been to keep this car for a long time, carbon build up is a concern for me. Glad Audi is stepping up to cover it (whether forced or not), but appears this could be a big ticket item if it manifests after the 100K miles. I really wish we knew definitively what the "conditions" are that precipitate the problem, or what can be done to help prevent it.
This is a reason why I don't regret buying the Audi Care - glad it will be serviced by Audi for a while yet. Ill plan on taking the letter with me for the 15K service (imminent) and see if service has any ideas for mitigation.
