My 2012 VAG mod reasearch
#21
What are you using?
#22
#23
before
Sunday,19,August,2012,05:22:01:05985
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 4G0
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 34 36 3B 42 44 46
52 53 55 56 5F 62 6C 6D 72 88 89
VIN:
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
Address 01: Engine (J623-CGWB) Labels: 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 HW: 4H0 907 551
Component: 3.0l V6 TFSI H07 0007
Revision: --H07---
Coding: 0A250034052E01020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551 002010
ROD: EV_ECM30TFS0214G0907551.rod
VCID: E6C9117D19702C283B9
2 Faults Found:
6201 - Function Restriction due to Received Malfunction Value
U1113 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
6134 - Function Restriction due to Received Malfunction Value
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G1 927 156 D HW: 0B5 927 156 F
Component: 0B5 30TFSIRdW H10 0003
Revision: --H10--- Serial number: 0000000913
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 2E59295D71002468839
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 F HW: 4G0 907 379 F
Component: ESP PREMIUM H09 0250
Revision: -------- Serial number: --------------
Coding: 44A6C7012265E380CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
ROD: EV_ESPPremiAU57X.rod
VCID: 346D3B359F2C0EB8F5D
4 Faults Found:
0487 - Suspension Sensors
C104B 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
0604 - Tire Pressure Warning
C102D 00 [008] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 123
Mileage: 9467 km
Date: 2012.06.30
Time: 17:54:01
0629 - Tire Pressure Warning
C102D 00 [008] - Emergency position not reachable
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 123
Mileage: 9348 km
Date: 2012.06.13
Time: 18:42:06
0631 - Tire Pressure Warning
C102D 00 [008] - Commanded position not reachable
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 111
Mileage: 9327 km
Date: 2012.06.13
Time: 14:12:46
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BT HW: 4H0 907 064 BT
Component: BCM2 2.0 H31 0330
Revision: 00002001
Coding: 05A82F06000000000000
VCID: 7CFDD315FFFC06F87DD
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-BFS H04 0154
Revision: AA000000 Serial number: 00000014822614
Coding: C018320085006201000001010101112030303333283333
VCID: 3A71150DB548F8C82F1
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0062
Serial number: 29091100040260
Coding: 6601207E28
ASAM Dataset: EV_AirCondiComfoUDS 002033
ROD: EV_AirCondiComfoUDS.rod
VCID: 2855DF4553E47A58495
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001073446
Coding: 0907201009749FE009810084A0001800CF9CC308AE08012180 0108542F01
Shop #: WSC 00030 724 96011
VCID: 6ED9E95DB9806468C39
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 110918 H35 0051
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0030
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901126801031
Coding: 280306
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000.rod
VCID: 3D7B1E11AC66CFF00A3
Address 15: Airbags (J234) Labels: None
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG004GRGF
Coding: 30323436313330303432554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3669013D89501CA8CB9
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405D0OPMGAGGB
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405J0Q3SKB0Q3
Crash sensor for side airbag; rear driver side:
Serial number: 3515JRB405V0PIJQB072
Crash sensor for side airbag; rear passenger side:
Serial number: 3525JRB405R0PIJQHGJX
Crash sensor for front airbag; driver side:
Serial number: 3554VRB40690O010KO8A
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB40690O010IH1
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20111004001065
Coding: 000034
VCID: 3065372563343298915
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 931 C HW: 4G8 920 931 C
Component: TBenRdw H79 0375
Revision: 26181120 Serial number: 658300911591010
Coding: 53A609001B010008010000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K_AU57.rod
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000262228
Coding: 00CD073000
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 32613D2D65380088E71
Control unit for battery monitoring:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650629614
Voltage stabilizer:
1 Fault Found:
0267 - Optical data bus
U1049 00 [008] - Open circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Date: 2012.07.03
Time: 11:20:59
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018264747464545425363E
VCID: 336F382992220980EC7
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0062
Serial number: 01101100040601
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 2F673459760A2D6088F
Address 34: Level Control (J197) Labels: None
Part No SW: 4G0 907 553 C HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0779
Coding: 008000
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU57.rod
VCID: 2B5F204942125140A47
3 Faults Found:
455691 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 130
Mileage: 9329 km
Date: 2012.06.13
Time: 14:23:07
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:18
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0154
Revision: AA000000 Serial number: 00000014822659
Coding: C0183B0085016201000001010101112030303333203333
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA420251LT0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
VCID: 2D5B2E517C065F70BA3
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F1E205E00620202080002
Shop #: WSC 02312 785 00200
VCID: 418362E1D89EAB106EB
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 H HW: 4G0 909 144 G
Component: RCEPS H35 0007
Revision: 00001000 Serial number: 0018171414
Coding: 101000010000
ASAM Dataset: EV_RCEPS 006007
ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0159882777
Coding: 01000E2000B975858330088400010000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Subsystem 2 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Coding: 901E00
Subsystem 3 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Coding: 010000
1 Fault Found:
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 18
Reset counter: 126
Mileage: 8179 km
Time Indication: 0
Date: 2012.05.20
Time: 13:54:30
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 D HW: 4G8 959 792
Component: TSG BF H05 0212
VCID: 408567E5D394A218615
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000148445
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake.rod
VCID: 2A51254D4DE848485F1
Address 55: Xenon Range (J431) Labels: None
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 111004-0002-026
Coding: 11216F601002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU57.rod
VCID: 2C5D2355471C5678ADD
1 Fault Found:
120589 - Function Restriction due to Received Malfunction Value
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 056 C HW: 4G0 035 056
Component: Radio U STD H52 0079
Revision: AB001007 Serial number: 051IW0B7537332
Coding: 070003020100000001
VCID: 2143C26138DE8B100EB
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 754 E HW: 4G0 035 754
Component: H-BN-RW H47 0410
Revision: -------- Serial number: 430I/0B7509638
Coding: 050D00000003F1EF45028B2E00000003FC0001020000000000
Shop #: WSC 00030 724 51981
VCID: 2855DF455BE47A58495
Subsystem 1 - Part No: 8R0 060 884 AE
Component: ROW 2011 0301
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 A HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0203
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
1 Fault Found:
02067 - Optical Databus; Unpermitted Wake-Up Request
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Time Indication: 0
Date: 2012.07.03
Time: 11:18:45
Freeze Frame:
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 D HW: 4G8 959 795
Component: TSG HL H03 0212
Coding: 010F1C204000620202080002
VCID: 438F68E9C282B9007C7
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0090
Revision: 11001001 Serial number: 82330JF0008870
Coding: 0200000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 003019
ROD: EV_CamerSysteTopViewAUDI.rod
VCID: EAD1654D0D6808481F1
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4G5 959 107 A HW: 4G5 959 107
Component: HDSG-Modul H01 0038
Revision: 13001001 Serial number: 245100114
Coding: 111104C000
ASAM Dataset: EV_HDSGAu571 001001
ROD: EV_HDSGAu571_AU57.rod
VCID: 306537256B343298915
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0212
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00002225165601
Coding: 6620F2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels: None
Serial number: 00001146362302
Coding: 2620F2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
ROD: EV_IVBPasseSideFrnt_AU57.rod
End ---------------------------------------------------------------------
Chassis Type: 4G0
VIN:
Revision: --H07---
2 Faults Found:
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Coding: 000001
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 123
Mileage: 9467 km
Date: 2012.06.30
Time: 17:54:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 123
Mileage: 9348 km
Date: 2012.06.13
Time: 18:42:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 111
Mileage: 9327 km
Date: 2012.06.13
Time: 14:12:46
Revision: 00002001
Coding: 6601207E28
Coding: 0045F7
Coding: 02512B
Coding: 110000
Coding: 110000
Coding: 020300
Coding: 280306
Coding: 000034
Coding: 00CD073000
Voltage stabilizer:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Date: 2012.07.03
Time: 11:20:59
Revision: AA001002
Coding: 00
Coding: 008000
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 130
Mileage: 9329 km
Date: 2012.06.13
Time: 14:23:07
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:18
ROD: EV_RCEPS.rod
Coding: 901E00
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 126
Mileage: 8179 km
Time Indication: 0
Date: 2012.05.20
Time: 13:54:30
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Time Indication: 0
Date: 2012.07.03
Time: 11:18:45
Freeze Frame:
Voltage: 12.30 V
Coding: 111104C000
Coding: 6620F2
Coding: 2620F2
#24
after
Sunday,19,August,2012,05:33:43:05985
Chassis Type: 4G0
VIN:
Revision: --H07---
2 Faults Found:
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Coding: 000001
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 123
Mileage: 9467 km
Date: 2012.06.30
Time: 17:54:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 123
Mileage: 9348 km
Date: 2012.06.13
Time: 18:42:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 111
Mileage: 9327 km
Date: 2012.06.13
Time: 14:12:46
Revision: 00002001
Coding: 6601207E28
Coding: 0045F7
Coding: 02512B
Coding: 110000
Coding: 110000
Coding: 020300
Coding: 280306
Coding: 000034
Coding: 53AE09001B010008010000
Coding: 00CD073000
Voltage stabilizer:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Date: 2012.07.03
Time: 11:20:59
Revision: AA001002
Coding: 00
Coding: 008000
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 130
Mileage: 9329 km
Date: 2012.06.13
Time: 14:23:07
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:18
ROD: EV_SARA_AU57.rod
ROD: EV_RCEPS.rod
Coding: 901E00
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 126
Mileage: 8179 km
Time Indication: 0
Date: 2012.05.20
Time: 13:54:30
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Time Indication: 0
Date: 2012.07.03
Time: 11:18:45
Freeze Frame:
Voltage: 12.30 V
Coding: 111104C000
Coding: 6620F2
Coding: 2620F2
Chassis Type: 4G0
VIN:
Revision: --H07---
2 Faults Found:
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
U1113 00 [096] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Coding: 000001
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 123
Mileage: 9467 km
Date: 2012.06.30
Time: 17:54:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 123
Mileage: 9348 km
Date: 2012.06.13
Time: 18:42:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 111
Mileage: 9327 km
Date: 2012.06.13
Time: 14:12:46
Revision: 00002001
Coding: 6601207E28
Coding: 0045F7
Coding: 02512B
Coding: 110000
Coding: 110000
Coding: 020300
Coding: 280306
Coding: 000034
Coding: 00CD073000
Voltage stabilizer:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Date: 2012.07.03
Time: 11:20:59
Revision: AA001002
Coding: 00
Coding: 008000
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 130
Mileage: 9329 km
Date: 2012.06.13
Time: 14:23:07
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 9911 km
Date: 2012.08.13
Time: 23:35:18
ROD: EV_RCEPS.rod
Coding: 901E00
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 126
Mileage: 8179 km
Time Indication: 0
Date: 2012.05.20
Time: 13:54:30
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 9328 km
Date: 2012.06.13
Time: 14:13:32
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 136
Mileage: 9474 km
Time Indication: 0
Date: 2012.07.03
Time: 11:18:45
Freeze Frame:
Voltage: 12.30 V
Coding: 111104C000
Coding: 6620F2
Coding: 2620F2
#25
here they are and in my car I can't even see the lap timer in the DIS
I enabled it by ticking the laptimer activate in the 17-instrument panel > coding this is the right way, right?
#26
I see You have a euro instrument cluster that is you are in Europe. The scan will not help me much. I would suggest you edit out your VIN # from your post.
#27
I'm thinking something else needs to be enabled along side of it? We should see when our cars were made and compare it to who can and can't enable it. Mine was early 2011 I think, before the license plate lights where LEDs.
#29
what's the reason for hiding your VIN after all it's there on your windshield all the time?
#30
I hope someone with a NA car would chime in and post his scan
My car has the LED plate lights and it was built in October or November 2011
