no 8th gear in dymanic mode c7 a6?
cruising at 85mph for extended period of time, it still not at 8th telling from the rpm. changing to automatic mode immediately shifts to 8th.
at what speed does the car go to 8th gear in dynamic mode?
Despite myths to the contrary, the transmission doesn't "learn" anything. There are various software algorithms that are employed based on your driving style but they are not remembered. It's possible there's something going on in the software - have you had the latest transmission update and adaptation done at the dealer?
Here's one of the threads on the subject:
https://www.audiworld.com/forums/sho...php?p=24464616
Are you sure you're in dynamic mode when this happens, or not in cruise control? I don't believe the A6 we had would shift into 8th in dynamic at any of the highway speeds I drove. And the S6 doesn't shift into 7th unless cruise control is on when in dynamic at any of the highway speeds I drive.
Thanks snagitseven for the tsb number.
can more people chime in to confirm there is or there is no 8th gear in dynamic mode?
it is pretty easy to test.
80mph at 8th gear should have an rpm of less than 2k
80mph at 7th gear should have an rpm around 2.2k
