NZ: Gearbox Malfunction error P187B 00
Hi guys,
I am new to this forum and hope someone can please help me with an intermittent transmission issue.
I own a 2014 Audi A6
2800cc Petrol with around 120,000kms on the clock.
A gearbox malfunction warning pops up when driving in traffic conditions. This happens only when on 2nd gear and when driving uphill/ downhill under 30kmph and you come to a complete stop the warning pops up and puts the vehicle in to limp mode. If I switch the ignition off and start the car back up the warning disappears. The car drives quite well and the gear shifting is also very smooth, so it is quite strange that it’s doing this.
I have taken the car to the dealership and the transmission fluid was changed and the cooler valve was also replaced. However, this hasn't addressed the issue. Now I have taken the vehicle to a transmission specialist and looks like they are also battling to figure out what’s causing this issue.
Please see scan below.
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G2 927 156 L HW: 0B5 927 156 K
Component: 0B5 28 FSIRdW H03 0004
Revision: --H03--- CVN: 0000B68D
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 372B291C8FCE47F356B-8062
1 Fault Found:
18011 - Gear Selector 2
P187B 00 [096] - Engagement not successful
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Mileage: 114530 km
Date: 2022.07.17
Time: 19:44:27
Engine RPM: 625 /min
Transmission input speed: 625 /min
Transmission output speed: 0 /min
Engine torque: 4 Nm
ATF temperature: 106 °C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
Unlearning counter according OBD: 38
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Mileage: 114530 km
Date: 2022.07.17
Time: 19:44:27
Engine torque: 4 Nm
Solution answer
Hi, I read the error. I have a similar problem. I would like to ask if the problem has been solved? What was the solution?
many thanks,
regards Attila
many thanks,
regards Attila
Hi guys,
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Mileage: 114530 km
Date: 2022.07.17
Time: 19:44:27
Engine torque: 4 Nm
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Mileage: 114530 km
Date: 2022.07.17
Time: 19:44:27
Engine torque: 4 Nm
I know this thread is a little old, but has anyone resolved this issue? Getting same P187B code and same symptoms where it only happens during the 2-1 downshift on slight declines/inclines. Also getting the 2-1 downshift bump in stop and go traffic. Otherwise, car shifts great and no issues.
tylerud22
S4 (B8 Platform) Discussion
31
12-27-2021 03:42 AM
fonzerella
Q5/SQ5 MKI (8R) Discussion
10
11-22-2019 03:07 AM
JRJ
08-02-2019 02:08 AM
Argelius
A4 (B8 Platform) Discussion
01-10-2010 06:35 PM
