ODBeleven
Can anyone confirm which of these mods listed can be done with ODBeleven? I want to ask the vendor but I cannot find out how to get in contact with them.
•Disable amber corner lights
•Disable NAV & Phone warning messages while entering data at speed
•Disable Seatbelt Chime
•Enable Adaptive brake lights
•Enable Automatic Gear selection shown in DIS
•Enable Double Disarm Beep
•Enable Hidden menu in MMI
•Enable Import CDs to MMI's HD
•Enable Independent Fogs control with high beams
•Enable Lap Timer
•Enable Remote Operation windows&sunroof
•Enable TPMS
•Enable VIM on MMI
•Set Audi parking system - Switch OFF Speed
•Adjust LED Brightness
•Beep on lock
•Adjust bluetooth microphone sensitivity
•Enable Auxiliary ventilation
•Enable Drivers Memory Seat
•Increase radio play time after car is turned off
•Enable coming home/leaving home function DRL
•Tail lights on with front DRLs
•Change the Adaptive Cruise Control Preset distance
•Enable power trunk to close from key fob
•Enable Lap Timer
•Enable TPMS
•Enable VIM on MMI
•Beep on lock
I can't confirm what works on your list, but I can confirm that I did the following with OBDeleven:
Enable Hidden menu in MMI*
[5F - Information Electr.]*
[Adaptation - 10] -> Channel 6*
change 0 to 1*
Use this hidden menu at your own risk.*
Caution: Keep away from the "Bootloader"*
Disable rear side markers in US vehicles*
[Select]
[46-Central Convenience]
[Security Access] enter 16017
[Adaptation - 10] --> channel 209 for left rear side marker
Document your existing number should you need to re-enable rear side markers later
Change existing number to 0
Channel 210 for right rear side marker
Change existing number to 32
Enable Remote Operation Windows and Sunroof*
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2*
Bit 2 - Set to 1
Enable Automatic Gear selection shown in DIS*
[02 – Auto Trans] [Adaptation – 10]*
Select “Single Gear Display” from top channel drop down menu*
Select “D on/S on” from New value drop down menu
Enable Adaptive brake lights*
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8*
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)*
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)*
Disable amber corner lights*
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10*
Submodule 0*
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)*
Disable NAV & Phone warning messages while entering data at speed*
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
change 0 to 1*
[Select]
Bit 2 - Set to 1
Submodule 0*
That actually helps a bit. Now all I need to know about is whether or not these can be done. If so I will be buying one:
•Enable Lap Timer
•Enable Lap Timer
•Enable Lap Timer
•Enable Lap Timer
I'm curious, did enabling that also get you the oil temp & current gear displayed? Not sure if you need the HUD for those to show up? I was under the impression that when you enable the lap timer these show up also, but I could be wrong.
You don't need the HUD for those to show up. You do need to set your DIS to LAP TIMER and they will appear. The current gear, D/S/M always shows in the DIS. It only shows in the HUD when you have the Lap Timer selected.
So the biggie left for me would be does "Change the Adaptive Cruise Control Preset dist" work with this device? Can anyone confirm it works?
for enabling automatic PDC...what is the hex value of byte 37... I went to enable it and bit 1 was checked already but the parking sensors aren't activating automatically.....
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250[/QUOTE]
under 5F and adaption, i don't see set channel 2 & 3 anywhere?
could you give more details, thanks
05whtaudia6
VAG-COM Discussion
05-11-2008 06:11 AM
MXHowes
08-25-2007 06:06 PM
Kurt
11-11-2003 09:04 AM
