Radio Volume
My 2016 A6 with every option but the Bose has a radio volume problem. Approximately 50% of the time when I start the car the radio volume is off and has to be turned up to hearing level. The other 50% of the time the radio volume is the same as when I turned the car off. Very annoying and the Dealer is of no help as the situation is unpredictable. I have tried rebooting the MMI.
Am I the only owner who has this problem?
No, but the dealer has no fix and leaving it long enough to demo an intermittent problem has not been worth the time/trouble. We've rebooted everything that can be done with guidance from the Audi Tech Support line. When it happens, we just turn up the volume. At least, we permanently conquered the Start/Stop so that is one fewer button to push each time, so the radio sometimes takes its place.
NightBlue/Sportstick–Any luck in resolving this issue? Exact same scenario in my '16 A6. And the intermittent nature of it is perplexing and annoying.
You guys know that you control the start/stop by how heavy you push down on the brake pedal at a stop. I think it's easily controlled, but maybe it's just I never mash the pedal to the floor at a stop. I can easily press it down a little harder at a long light and shut the engine down.
I wonder if it's something that can be changed with VCDS. I have B&O. If I had my volume turned up (to 20 for example) when I shut down, It always turns on at 12 if I was listening to Sirus and 13 if I was listening to Media, consistently. Can't remember but I want to say if it's less than 12/13 when I shut down, it stays at whatever level it was at. I've never had the volume not come on.
Sorry, but no. We gave up and are accepting it as one of the car's eccentricities. Being intermittent, it just isn't worth the time in either one of our schedules, so my wife just turns the volume back up. She is saving time anyway as she doesn't have to defeat the permanently dead start/stop each time any more, so this is the last ongoing PITA.
