Remote windows and sunroof
I've enabled the remote windows/sunroof via vag-com, pretty easy.
2 things though; First, I enabled the remote windows on my son's 2008 Jetta and his will continue to go up/down after releasing the button, but will stop when the button is pressed again. Has anyone been able to do that with the C7?
Second, how do I get the sunroof to open instead of tilt via the remote? I've searched, but have only found a video of the sunroof opening (stevial).
Thanks for the help.
FYI, the Jetta will even close the sunroof if it detects rain with the rain sensor.
Could you give me the link to get the windows done. I need to get re vAgged. When I vagged my car lag August the programming for the c7 was not complete and missing certain codes.
And the rest here: http://www.audienthusiasts.com/VagCom.html
Here you are: http://www.audienthusiasts.com/VagComWindow.html
Yeah, I remember seeing a thread about it but couldn't did it again. And the feature is annoying. Because whether you're opening or closing everything via the remote, it ALWAYS tilts the sunroof up.
I seem to remember you can go into the Car settings and select remote control of the doors and sunroof activation individually?
check 46 in adaptions look channel labeled "comfort opening" then look for the sunroof option, at the vag com popup helper screen there should been an option for sunroof to slide, you have to add that value to your existing value, then save, if it still doesn't work go back and subtract the value for sun roof tilt, then save and check it again. Make sure you write down you default value before you make any changes. it should work.
