Removing "etching" left from windshield label
On my '14 A6, when the sun hit the windshield the right way or the glass fogged up, you could see the imprint of a factory/manufacturer sticker (probably 8"x6") in the center of the windshield (interior side of glass) - no matter how many times I tried to clean the windshield with glass cleaner and a glass scraper, I could not remove it. Apparently it's a not uncommon problem as mentioned in the following thread:
https://www.audiworld.com/forums/sho...9&postcount=23
When I mentioned it to my service advisor, he said he'd seen this before and that Audi had no fix for it, but he'd discuss with the service manager - within an hour, he called back and said they'd been authorized to replace the windshield with an aftermarket glass (Safelite) at no charge. After giving it some brief thought, I declined the offer because of replacement windshield horror stories that I've read about. When I mentioned this issue to an engineer that I work with, he suggested that it was simply due to some kind of "molecular bonding issue with the adhesive" and said I should try some VERY fine [water-soluble] diamond abrasive compound, which he just happened to have for glass cleaning. Sure enough, after a good 10-15 minute polishing with the compound, I can no longer see any evidence of the sticker that was there. Needless to say, I was pleasantly surprised by this straight-forward solution, and extremely surprised that my dealer so readily got the OK to replace the windshield for what apparently is a common issue that Audi has no fix for (can't believe that some German engineer couldn't figure this out).
Anyway, for those of you who might have this issue, the product I used was Diamond Innovations compound #DMSY SJK-5 0-0.50 MWS 18.
amchuu (09-09-2019)
None that I can see. The engineer who recommended it told me that the compound was similar to toothpaste, but with even finer "grit"....he said he used it to repair scratched eyeglasses.
http://www.ebay.com/itm/160917087681...84.m1438.l2649
You might just try a glass polish. Far less likely to cause any problems. Griots has a couple and I have several in my supplies including one from Autoglym which has been outstanding on exterior glass. You'll be shocked how dirty your "clean" glass is after using this stuff ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
I had several ghost impressions on my car's (exterior) windshield from the huge suction cups they use when installing windshields. They've slowly disappeared over time.
