REPOST - back up sensors not showing - VCDS logs
Appealing once again to the collective wisdom of the Forum...
The VCDS logs show two potential error conditions:
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061303301787
Coding: A8CB05
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD7EDB126090F35F-8024
1 Fault Found:
1080340 - Parking Aid Speaker
B107C 14 [009] - Open or Short to Ground
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 114946 km
Date: 2020.07.27
Time: 07:00:24
__________________________________________________ ___
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J2ZG14L
Coding: 1080004
VCID: 2615F4B144E81EB790D-8072
1 Fault Found:
02203 - Audio / Video Input 1
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 113712 km
Time Indication: 0
Date: 2020.06.03
Time: 10:55:17
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Can anyone advise which error to pursue? Can the backup speaker disable the sensor's video arcs on the screen? What does Reverse OFF signify? (just that car is not in reverse?)
Have re-posted with more VCDS information above after getting the necessary... still same symptoms, 5 second shrill beep and no visual sensor arcs in rear camera display see below:
Coding: A8CB05
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 114946 km
Date: 2020.07.27
Time: 07:00:24
Coding: 1080004
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 113712 km
Time Indication: 0
Date: 2020.06.03
Time: 10:55:17
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
I had something similar except with the front speaker. I replaced the front parking alert speaker and cleared faults.
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061214301007
Coding: A8C305
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77BE308CCEA11DFC15-8022
1 Fault Found:
1111316 - Speaker for Front Parking Aid
B10F5 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 83
Coding: A8C305
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 83
Thanks back13a6,
By the way where did you find the backup warning speaker and what is your model year and type?
Capital Son
Capital Son
CapitalSon (09-04-2020)
Thanks Again Back13a6.
I finished today digging into the rear speaker/buzzer, which is on the outside of the rear passenger side plastic seat belt guide, facing and just under the triangular window. Replaced speaker, tested backup, road test for 30 minutes, no extra beeps (I used a reclaimed AUDI speaker from eBay, $20), buttoned all up, cleared the VCDS error, re-scanned and all is good now.
CS
CS
ltooz_a6_a8_q7
10-07-2013 01:46 PM
