Tire Questions / Recommendations??
#11
#12
Sorry for the confusion of my comment. For a moment I thought I was commenting on the Aston-Martin board. No warrantee issue with the A6, since they can be rotated no problem
#13
Thanks for all the replies. More tire research is in the cards for me (it seems many say avoid the P zeros).
Any issues with non-oem tires when doing a lease return?
#14
No, all they will check is Tread Depth. They could possible ding you if you go down in either speed or load rating, but most tire shops will not even allow you to do that for liability reasons.
Bottom line, you will be fine.
#15
And if you meant to say side to side, it's not an issue with the PSS at least since they are not directional. They only indicate which side should be the "outside" so you can swap left/right.
As a data point, I got 14K out of my PSS with relatively aggressive daily driving (S6 is a little heavier). Here is my experience with the warranty:
https://www.audiworld.com/forums/sho....php?t=2861091
#16
I don't understand this comment. The C7 comes with same size at all four corners (square setup) so why can't they be rotated front to back?
"Sorry for the confusion of my comment. For a moment I thought I was commenting on the Aston-Martin board. No warrantee issue with the A6, since they can be rotated no problem."
#19
Thanks again for all the replies. I'm leaning towards the Continental Extreme Contact DWs (max performance summer tire--it may never rain again here in LA). There were a couple of generally positive mentions of Contis above. Anyone else have anything good or bad to say about the Continental brand or this tire in particular??
Thanks!!
Thanks!!
#20
Thanks!!
Thanks!!
