Transmission Malfunction ... you can continue to drive ...
i have a 2013 Audi A6 3.0T ...
This came up the other day ... and it wont go away ... i did a scan with VCDS .. see below.
IT ONLY comes up in P and R gears ... in N D S M the fault goes away ... what can be defective? anyone see this? any help?
thanks!
Wednesday,02,August,2017,07:45:38:11544
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
Ross-Tech: Home
VIN: WAUGGAFC5DN089734 License Plate:
Mileage: 56297km-34981mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55
56 5F 62 6C 72 8F 90
VIN: WAUGGAFC5DN089734 Mileage: 56297km-34981miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07---
Coding: 0A2A0032052601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551D 001003
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A5BEA124DD23116F4-807E
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 2D51E10E7C3C262E11-8078
1 Fault Found:
12545 - Signal Line for Tiptronic
P1890 00 [175] - Electrical Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 8
Mileage: 56231 km
Date: 2017.08.01
Time: 20:13:41
Unlearning counter according OBD: 40
Voltage terminal 30: 11.636 V
Voltage terminal 15: 12.1 V
Terminal 15 status: On
Driving position: R
Driving mode sensor-Hall sensor A: not active
Driving mode sensor-Hall sensor B: not active
Driving mode sensor-Hall sensor C: not active
Driving mode sensor-Hall sensor D: not active
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 44A78F0122E5F1805B00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3663CE62896A65F660-8062
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Revision: 00002001
Coding: 0DA82046000000000000
VCID: 7BF51F56FAC8789EDF-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000247987001
1 Fault Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 56214 km
Time Indication: 0
Date: 2016.11.12
Time: 07:57:01
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 4G0 820 043 AH HW: 4G0 820 043 AH
Component: KLIMA 2 ZONEN H11 0076
Serial number: 19111200110859
Coding: 6681201849
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 65C1592E644CDE6E19-8030
1 Fault Found:
0276 - Engine Off Timer Performance
P150A 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 241
Mileage: 56124 km
Date: 2016.11.11
Time: 00:29:28
Voltage terminal 30: 11.71 V
Terminal 15 status: Terminal 15 on
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001481147
Coding: 06002091063C9FE08100088380003908CF9CD208A609022100 0004406000
VCID: 6FED3B06BEB0143E63-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120617 H36 0080
Serial number: 120627221540
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20766037
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 21 11 2012 00000666
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R424G02
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 4C09CC56000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061232103326
Coding: A8C305
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 71E93D7EA08402CE75-8024
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002M1GM
Coding: 303234373131303030314A55304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3365F7769A1870DE47-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y120000M3HD0P
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40531LKFO99DR
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404T1M57I38AF
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40670Q8K4CG79
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB40511O70U91G+
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40104UOFCEP66
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40104UOFCN9C6
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LKN001O8
Coding: 000414
VCID: 387FC05A8B7E938672-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0010
Serial number: 03 10 2012 33302119
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 983 E HW: 4G8 920 983 E
Component: TBenUsa H79 0515
Revision: 28460208 Serial number: 658201112596050
Coding: 0BE609040B41D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 377DC3668E609CFE7B-8062
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000759755
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000001050635409
Voltage stabilizer:
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000044582900
Coding: 00581B0000006001000001010101102030303232203232
VCID: 77FD0366C6E05CFEBB-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA8201X926
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
1 Fault Found:
1048848 - Internal Voltage Measurement
U1408 00 [008] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 237
Mileage: 56124 km
Date: 2016.11.11
Time: 00:03:51
DCU_Internal_DTC: 10 01 10
Ignition Cycle Count: 9721
DCU Temperature: 21 °C
Voltage terminal 30: 0.0 V
Voltage VBG 22: 0.0 V
Debug Data: 00 00 00 00 00 00 00 00
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 306FF87AA30E4BC63A-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H01 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F22.11.1200H01000AMS15315ÿ
Subsystem 4 - Serial number: S15315ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011F17005E00628002000012
VCID: 479DB3A6F680EC7E0B-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0007033019
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BF272650279D64C-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0188377092
Coding: 0106023A00FA408580B0080402050E07000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000120322
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1934849C
Coding: 101F00
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F17005E00628002000002
Shop #: WSC 57814 001 1048576
VCID: 4487A4AAC7B6C766EE-8010
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000528874
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU57.rod
VCID: 2B55EF164228281E0F-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 121123-0002-120
Coding: 1221A6101002A500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156K.0C7671005
Coding: 020007020100000001
VCID: 224B02323DE2E956BC-8076
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 D HW: 4G0 035 746 B
Component: H-BNT-NA H50 0622
Revision: -------- Serial number: 194K50C7519823
Coding: 050200000003E0EF55128B1E00000003100001000000000000
VCID: 285F101A5BDE0306E2-807C
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDCD0002V5M
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LKQ000DQ
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0506
Coding: 010F17004000628002000002
VCID: 4999B59EE0941A0E1D-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J2XG42C
Coding: 1080004
VCID: 26431E2291CA1576D0-8072
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0506
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169FD7E600442CE35-8064
2 Faults Found:
12583694 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 56124 km
Date: 2016.11.11
Time: 00:05:01
12583946 - Reversible Belt Tensioner
B1202 F0 [137] - Function Not Available
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 56127 km
Date: 2015.10.26
Time: 11:32:48
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
3 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 56124 km
Date: 2016.11.11
Time: 00:05:01
12583699 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 56124 km
Date: 2016.11.11
Time: 00:00:02
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 56127 km
Date: 2015.10.26
Time: 11:32:48
End-------------------------(Elapsed Time: 06:03)--------------------------
thanks!
Ross-Tech: Home
Revision: --H07---
Revision: --H16---
Coding: 000002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 56231 km
Date: 2017.08.01
Time: 20:13:41
Driving position: R
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 56214 km
Time Indication: 0
Date: 2016.11.12
Time: 07:57:01
Coding: 6681201849
1 Fault Found:
P150A 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 241
Mileage: 56124 km
Date: 2016.11.11
Time: 00:29:28
Coding: 0045F7
Coding: 02006D
Coding: A8C305
Coding: 000414
ROD: EV_RBD4K.rod
Coding: 00CD073000
Voltage stabilizer:
ROD: EV_SARA2.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 237
Mileage: 56124 km
Date: 2016.11.11
Time: 00:03:51
Coding: 0000001
Coding: 101F00
Coding: 1080004
ROD: EV_RGS_L.rod
2 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 56124 km
Date: 2016.11.11
Time: 00:05:01
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 56127 km
Date: 2015.10.26
Time: 11:32:48
ROD: EV_RGS_R.rod
3 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 56124 km
Date: 2016.11.11
Time: 00:05:01
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 56124 km
Date: 2016.11.11
Time: 00:00:02
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 56127 km
Date: 2015.10.26
Time: 11:32:48
Looks like you have an issue with a controller or sensors in reverse.
BTW, no need to include the entire scan, just the items that show a fault. Makes it easier for a reader to find the potential problem.
Also, "bumping" a thread to get it on top of a forum is discouraged. Especially for a post made only a day before.
what kind of issues could that be?
I'll let you know, I did find this TSB, so maybe this will apply to me?https://www.cars.com/articles/2012-2014-audi-transmission-issue-1420688729620/
