TSW Nurburgring wheels
#11
I don't know about snow setips but aren't the 19x8.5 is big and wide? I always thought snow needs smaller rims and narrower tires
#12
Wider is better
generally, a wider stance is a more planted stance. To a point. The suspension is tuned for +45mm. By placing it 10mm shifted out, it will be non-optimal for how the suspension was designed or intended. The general guidance that is acceptable is 10mm shift is the max in either direction. My Porsche 911 came installed with a 5mm spacer from the factory. The extra 5mm creates a wider stance, fills out the wheel well, and adds a little aesthetics with the bright spacer. Porsche does not offer a 10mm spacer. I think it's for a reason.
I think 10mm is probably acceptable, but the suspension will not react tithe same way as 45mm. A 5mm shift is a no brainier. 10mm is more problamatic for me personally. I'm going to see if I can get a custom et45 from OZ.
I just noticed that I wrote 10 mm it's 13 mm as they are ET32
the 20's are 9 in wide I think so I cant use OEM spec tire size and pressure if someone know what will be the recommended tire size and pressure on the 20's I may give them a second thought
I like OZ but the mesh of the nurburgring is more appealing to me
#13
congrats on the car
13mm = 0.51 inch. 9 - 8.5 (OEM) = 0.5 inches. Due to the offset difference, it will push out the entire rim 0.51 inches towards to curb, but due to the extra with of the rim by 0.5 inches, it puts the inside rim 0.5/2 = 0.25 inches back back closer to its original position. If I think about the centerline of the rim, the inboard rim plane will be pushed out 0.25 inches from OEM and the outboard rim plane will be pushed out 0.76 inches. It's not balanced and it has a 0.5 inch delta from the OEM. The general accepted max offset difference is 10mm. 10mm = 0.39 inches. You are at 0.5 inches. I would reconsider. Call tire rack or another professional and see if they agree. Call Audi. It will fit yes, but I think it's too far out of spec.
One other aspect of this conversation is tire noise. You have an extra ~1/2 inches of rubber hitting the road depending on which tire you use. I'm told from others on this site, the tire noise is there. This will make it worse. I have not driven a S6. Mine arrives in 20 days. If others can comment on tire noise...
I like the mesh style of the TSW rims BTW. BBS has a similar style. I think it's the CH-R. I strongly considered that rim originally, but they don't have the rim spec I'm looking for
#14
You have two things to think about: offset and wheel width.
I could be way off base. Audi may have a wider spec tolerance. I'm using my experience and general principles. Just because a rim fits, doesn't mean it will hook up with the suspension in the right way. Some people don't care. To each his own in that case.
Do any of you guys know a similar wheel closer to OEM spec
#15
OEM: 5x112 45mm 20x8.5 255/35 tires
OEM: 5x112 45mm 19x8.5 255/40 tires
I think you need to research this some more. You are putting a 9" rim with a tire designed for 8.5. You are putting a 13mm offset. You have an unbalanced inbound/outbound delta. I think it will look weird with the tire not matching the rim and the rim sticking out 1/2 inch. All of this does not sound good to me. It might all fit, but wow. My 2 cents with friendly admonishment over
#16
Here is a link that allows you to play around with tire and rim sizes. http://www.rimsntires.com/specs.jsp
#17
If you look at my earlier response, I said "depending on which tire." If you use the same width tire for both rims, then obviously there is no difference. Putting a 255 tire with a 40 wall on a 9" rim is interesting... It will look funny and it might be stretching too much. Check the tire manufacturer recommended rim width. I assumed you were going with 20s. Below is the S6 spec if you have 19 or 20s.
I think you need to research this some more. You are putting a 9" rim with a tire designed for 8.5. You are putting a 13mm offset. You have an unbalanced inbound/outbound delta. I think it will look weird with the tire not matching the rim and the rim sticking out 1/2 inch. All of this does not sound good to me. It might all fit, but wow. My 2 cents with friendly admonishment over![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
anyway after some thinking and looking at the OZ wheels you chose they grew on me so what do you think of the 19 in wheel with same OEM spec tires? their spec is 19x8.5 ET38 the tires will be 255/40 R19
do you recommend a wider tire? I think 255 is maximum for the 8.5 (tire rack)
BTW 19&20 wheels for the A6&S6 are the same
I didn't think of the 20's as I already changed a wheel and have a damaged one because of the lovely roads we have so lower side wall would be a nightmare
#18
the nurburgring are 8.5 wide same size as OEM except for the offset which is +32 mm which mean they will be identical in every other aspect beside the offset as the tsw will stick out a further 13 mm
I think the 255 is good for 8.5. 255 for 9" is too small and generated my last response
What generated my response was a misunderstanding of wheel rim size for the same tire and 13mm offset. I'm sure you understand. Now, you only have a 7mm offset with the same size rim. Your golden.
#19
#20
I wanted the darker wheel to hide the brake dust as within a day it looks a little dirty and in 4 day I have gunmetal at the front and something between silver and gunmetal in the back
![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
