When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Somewhere I read it's the same, not sure where. I think from an earlier post here. Haven't yet put it in, but looks good. It's just to clip through the flexible backing. Fit looks good
I made the cut out a little too big and had to use two screws to hold it in place:
And for those who are interested how it looks like without the trunk liner:
Do you have a pic of what the trunk looks like without the bracket installed over the liner? As I look at this pic above, it just looks like you should be able to cut ever larger and larger holes until the bracket can slide in and snap into place. Is that correct in your estimation? Thanks!
I was able to get this installed, and since this is an old thread, I created a separate one to document the specific instructions for installation: Warning Triangle DIY Instructions for A6 C7
