washer fluid tank capacity?
ALittleWiserNow (02-25-2022)
Be sure that stuff won't cause problems. I've read where some Audi owners have had clogging issues when using those types of washer fluid additives.
I don't know the capacity, but I can tell you I haven't had to fill mine in a year. I'm starting to think maybe Audi found the washer fluid dimension and the reservoir just tap into that.
That last part is just for comedic effect, but I seriously haven't had to fill it all year.
Your signature does not state where you are located. It's listed in the manual as 3.7 quarts unless you have a non-US model that has the headlight washers. The capacity will be 5.2 quarts. This information is listed in the Technical Data section of the manual under Capacities.
My light came on a few days ago to refill it. I bought a gallon container of that stuff and topped it off, started to overflow with about 1/10ths of the gallon left. So my guess is it's close to a gallon (which is in line with what someone else said about it being 3.7 qt.)
WECoyote-SuperGenius
Auto Detailing Discussion
06-13-2003 10:58 AM
06-13-2003 10:54 AM
MoBrazen
01-16-2003 08:33 AM
