Winter Set
#11
Ha. Yeah, I get it. Almost no one has winter tires in central Indiana, and do very well with them. I would of course prefer to have good winter tires, but I'm weighing the $1,600-$2,000 for winter tires and wheels that would be a good fit for the S6. I suppose I can look at the tires like the tires are a wash since they prolong the life of all season. If for safety primarily, I should prioritize doing that on the van.
#12
Powerwheelspro.com has a good selection for just wheels from good sources, although varying inventory. Or, if you read the reviews on tirerack.com for wheels, you can find the highest rated ones....typically pressure cast. I've bought several sets of wheels from both of them with zero issues over the last decade+. I would never buy an OE wheel from the parts department as I know how badly I am being raked over the coals with pricing. I saw what we paid for them on programs I managed.
#13
You can also look at Michelin XIce xi3 for slightly better dry handling but a bit less snow/ice traction.
Tire Rack may question this application for load carrying (as they did when I first called - btw, ask for Archer...he went through this with me), as Audi specified an XL load rated original tire. But, check the door label on your car. My GAWR is approximately 2750lbs and each of these Blizzaks can carry just over 1500 lbs., so 3000lbs of tire load capacity per axle. Bridgestone confirmed that the load can be carried at 36psi cold, so even though it's not listed as a recommended size, I see that it will work. And, narrower improves traction in winter due to increased downforce psi. We don't load the car heavily so we should not come close to that limit anyway, as the max load for the vehicle allows for 1102 additional pounds of people and cargo. Make sure you're ok with the speed rating. We certainly are for the usage! This size also matches the original overall diameter very well.
#16
Yes....they do quite a business with Mercedes owners from the MBWorld forum. Bought 3 sets of wheels for both of our prior Mercedes and always had great results. But, styles and inventory can vary as they use the model of taking the excess production from high quality supplier sources, typically Chinese, but produced to specs. China makes some folks nervous or unhappy, but its more about the capability of the plant than where the building is located. I won't get into politics.
#17
I'm in Wisconsin and come winter months I don't want to deal with a cracked rim. So if the standard of quality is there, I'm accepting.
#18
As far as the wheels that TR sells, the ones to avoid (in order) if you are concerned about quality are Sport Edition, Moda, and MSW. I've had all three brands and Sport Edition are the worst of the bunch. Moda and MSW are passable, but barely. There are some decent brands that TR sells that provide good bang-for-the-buck like Enkei, OZ and Rial. Rial is hub centric which means that centering rings are not required.
#19
Getting back to my initial question- can an A4 rim fit on my A6??
#20
Good question, and also related to a question I have. The pricing listed above is pretty impressive. The S6 isn't offered with anything smaller than 19s, and it has 15.7" brakes in the front. The 18" wheels you've identified are really inexpensive, and I'm wondering if they'd work on an S6. Tire Rack's 20s are actually cheaper than their 19s, so I bet there are some decent deal 19s available too.
